Poll
Need help picking a cabinet
A
6 (37.5%)
B
3 (18.8%)
C
7 (43.8%)
Total Members Voted: 16
Voting closed: December 16, 2011, 04:23:25 pm
Author Topic: Cabinet choices  (Read 2512 times)
iconone
  • Last login:December 12, 2011, 01:10:42 pm
Cabinet choices
« on: December 06, 2011, 04:23:25 pm »
I am new to the arcade world and this forum so go easy on me. My name is Vince and i'm 28 from Houston Texas. I have been reading for the last 3 weeks on everything arcade related. I have found a guy on Houston Craigslist that has 3 empty cabinets for 50$ each. They are 3 different styles and would like some input on which one to get if any. Do I really need a 4 coin slot cabinet? I would really like to build a multi game cabinet.
A
B
C
  • Last login:November 30, 2025, 12:59:41 am
Re: Cabinet choices
« Reply #1 on: December 06, 2011, 04:27:35 pm »
If you got the room, go with C. I like the coin door on it better and has a large control panel to give you many options.
DCsegaDH
Re: Cabinet choices
« Reply #2 on: December 06, 2011, 04:30:21 pm »
I would go with B or C, I like bigger control panels.
Paul Olson
    • Paul's Arcade
Re: Cabinet choices
« Reply #3 on: December 06, 2011, 04:35:11 pm »
I would go with B or C as well. Just depends what coindoor you like better. The CPs are attached with 3 bolts, so it is really easy to build a custom CP and throw it on there.
mgb
  • North East, US
Re: Cabinet choices
« Reply #4 on: December 06, 2011, 04:57:41 pm »
Personally, I like the looks of the z-back (A) the most but it really comes down to what your plans are. Being that you're 28, I'm thinking you may be more into the fighters in which case you will probably want the more roomy control panel of B or C.
I would take C over B because it looks like its in better shape and the single 4 slot coin door looks better than the double coin doors
Donkbaca
    • Slim built MAME/Xbox cab
Re: Cabinet choices
« Reply #5 on: December 06, 2011, 05:24:16 pm »
C +1.  I like dynamo cabs, but not the z-backs.  A big beefy CP is worth it so that you and your fat friends aren't so cramped :)
Re: Cabinet choices
« Reply #6 on: December 06, 2011, 05:32:17 pm »
Definetly the Z-back.  If you need more CP room build into it, that's half the fun of this hobby is ripping it apart to make it your own.  If you don't like that style go with C as it's in the best shape but the Z will give good wow factor.
dmarcum99
  • Last login:January 21, 2020, 12:02:36 am
Re: Cabinet choices
« Reply #7 on: December 06, 2011, 10:13:44 pm »
b or c...
mainly because the existing cp frame supports a larger playfield so a trackball won't be as cramped to the other controls when playing trackball games.
something you might overlook...option A is a metal cp, so you need higher degree of building/hacking skills compared to the wooden cp's of option B & C.
mgb
  • North East, US
Re: Cabinet choices
« Reply #8 on: December 06, 2011, 10:41:05 pm »
b or c...
True but metal CPs are cooler
Re: Cabinet choices
« Reply #9 on: December 06, 2011, 10:53:50 pm »
amendonz
Re: Cabinet choices
« Reply #10 on: December 06, 2011, 11:14:53 pm »
A
wizkid32
  • Last login:August 30, 2013, 07:27:03 pm
  • Portland Trailblazers, FTW!
Re: Cabinet choices
« Reply #11 on: December 06, 2011, 11:47:06 pm »
I'd go with B.  It has a nicely large control panel, two coin doors, and the marquee is lit w/ a standard Florescent/LED strip.
(\__/)
(='.'=) This is Bunny. Copy and paste him into your
(")_(") signature and help him on his quest for world domination.
Best,
Wizkid32
iconone
Re: Cabinet choices
« Reply #12 on: December 07, 2011, 09:33:01 am »
I think I'm going to go with C. It looks like it is in the best shape out of the 3. The guy said he would throw in a power supply and jamma harness along with the cabinet. Thanks for all the input and y'all will see a lot more of me.  :burgerking:
bkenobi
Re: Cabinet choices
« Reply #13 on: December 07, 2011, 11:39:02 am »
Which will help with...  The cab is gutted (no monitor, no controls).  You won't use the JAMMA harness and the power supply is of little use.  I guess you can put it up on B/S/T?
I'd go with A, but metal CP's are something that look complicated to work with when modifying (even though they look WAY better).  If a blank were available, metal would be a no brainer for me!
Blanka
Re: Cabinet choices
« Reply #14 on: December 07, 2011, 02:25:33 pm »
Go with A. It looks coolest and B and C are too much Mame-machines with floppy cantilevering wide wing CP's. CP's belong within the cab, not outside.
