Author Topic: Does "no isolation transformer needed" means it can plug directly in the wall?  (Read 3771 times)
ebo0763
  • Last login:May 23, 2016, 12:37:58 am
I don't have an arcade power supply since I'm making a mame arcade from scratch. Anyways. I have a WG k7400 which in the book says that no isolation transformer is needed.
My easiest solution, if possible, would be to just plug the power to the regular 120V AC plug from the wall. Or do I need an "arcade power supply"?
BTW, actually I would like to plug it on a surge protection bar.
« Last Edit: September 02, 2011, 06:36:29 pm by ebo0763 »
grantspain
can plug direct into wall socket
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
That model has a switching pwr supply so you can run it directly off wall current.
FYI, most arcade monitors (WG 4600,4900,7000, Electrohome G07, etc) *do* require an isolation transformer, so if yer not sure, check into it or ask someone who knows monitors. You can damage a monitor that needs an iso xfmr by trying to run it without one....
Subconscious
  • Last login:August 27, 2022, 06:35:21 pm
    • Press Start News
not to thread jack but i was wondering if anyone knows if a makvision 2425 monitor needs an isolation transformer to power it. the one i have has an ac connector on it but it looks like someone added it. i was told that it came out of a soulcalibur 2 cabinet. i cant find any manuals or real details about this monitor other than that its discontinued and not supported by makvision.
Press Start News. Your news source for all things gaming.
http://www.facebook.com/PressStartNews
Twitter: @pressstartnews
boardjunkie
From the schematic I found online it is hot chassis, so yes you need and iso xfmr with that monitor.
Subconscious
    • Press Start News
thanks. i had that feeling. that added ac plug didnt look like it belonged there.
benll64
  • Last login:November 07, 2024, 03:37:15 pm
If you don't need the isolation transformer, is there any way to power an arcade monitor directly with your PC's ATX power supply?
Thenasty
  • Last login:Yesterday at 04:30:09 pm
If your monitor is 12vdc/5vdc, yes you can (ATX/PC Power Supply are not 120VAC)
OP: You can hook up your Monitor to the ISO it won't hurt it. Thats what I did with my WG72xxx monitors.
Free VGA Breakout Cable
benll64
Ok, great. Thanks!
Domolover
  • Last login:October 26, 2011, 10:19:52 pm
I have the Monitor Made by DYNAMCO LTD KTM-F33 !!  Its used to be a Tekken 4 Cabinet, DO i need the Isolation? i try to Google it but no luck
I have some pictures too !!!
please see below:http://www.flickr.com/photos/68621793@N08/6236424177/#in/photostream/\
Thanks Guys !!
