Author Topic: UltraStik 360 is acting weird, is this a hardware or software issue?  (Read 1280 times)
upper2bits
  • Last login:December 20, 2011, 05:52:45 pm
Brand new, one works great one wont go fully to the right.  :censored:  Is this normal, is there something wrong with it?
« Last Edit: August 17, 2011, 12:31:34 pm by upper2bits »
Crono22
  • Last login:March 31, 2014, 07:09:07 pm
Re: UltraStik 360 is acting weird, is this a hardware or software issue?
« Reply #1 on: August 17, 2011, 05:13:04 pm »
Ya seems normal, I have the same problem with one of my ultrastiks. Its the magnet itself hitting the metal bracket. I dont use analog I have all the ultrastiks setup for 8way 4way etc. So a slight movement to UPR registers. Try moving the joystick very slowly and see if it will reach all the way.
upper2bits
« Reply #2 on: August 17, 2011, 05:53:23 pm »
I have mine set to 8way too and that's what I started looking into it. I was trying to play fighter games and I couldn't go diagonal so I started looking into it and switched my joysticks and the other one works fine.
DashRendar
« Reply #3 on: August 18, 2011, 09:56:38 am »
There was a known issue with the little ring that goes around the stick.  Some people were getting little shavings coming off that which was causing the symptom you're describing.
I think Andy changed the materials to address that.  There's a number of threads on BYOAC about this.
Anyway, that might be what you're running into.
syph007
« Reply #4 on: August 18, 2011, 12:08:15 pm »
None of the four I've owned do that.  I'd ask Andy, he's pretty quick to respond to emails.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: August 23, 2011, 10:17:38 pm »
This is an analog mode issue relative to the tracking of the magnet underneath, and where the shaft centers.
-Banned-
