Author Topic: Do I have set diagonals in MAME?  (Read 3003 times)
Grimoz
  • Last login:August 06, 2018, 02:11:22 am
« on: August 03, 2011, 09:02:55 pm »
Ive just wired my control panel up and it is working good, i just want to ask one question. When in MAME do i have to set the diagonal joystick directions because I cant seem to do it. I have Happ Supers in 8 way mode but its really difficult to get the diagonal directions to register when playing games like street fighter 2. Do i maybe need to adjust something on the joysticks so that it registers both ways?
« Last Edit: August 03, 2011, 10:37:21 pm by Grimoz »
Thenasty
  • Last login:December 01, 2025, 04:30:09 pm
Re: Do I have set diagonals in MAME?
« Reply #1 on: August 03, 2011, 10:17:46 pm »
you probably need to flip the actuator. It's probably set for 4-way.
Free VGA Breakout Cable
Grimoz
« Reply #2 on: August 03, 2011, 10:36:12 pm »
Nah its set to 8 way, but i did just notice that the joystick itself is not centred which is quite strange, anyone else have this problem and know how to fix it?
Grimoz
« Reply #3 on: August 03, 2011, 10:49:59 pm »
Think i may have figured it out, when i installed the joystick I accidently put one of the caps on upside down, i'll have to take it apart and turn it around to see if that helps.  :hissy:
« Last Edit: August 03, 2011, 10:56:27 pm by Grimoz »
    • GroovyGameGear.com
« Reply #4 on: August 03, 2011, 10:59:00 pm »
When you get it back together, try it out.  If you still think it's soft in the diagonals, keep in mind that the blades on the switches can be tweaked a bit to offer the response you are looking for.  You'll probably find that you won't need to if the stick is assembled properly, but it's always an option.
Grimoz
« Reply #5 on: August 03, 2011, 11:07:36 pm »
Thanks mate, the blades are already sitting pretty good as far as I can tell but if after reassembling properly I dont see any improvement I'll definitely check those out again.
