Author Topic: Admin Buttons  (Read 4781 times)
stalemate
  • Last login:June 20, 2016, 10:42:41 pm
Admin Buttons
« on: July 14, 2011, 10:43:36 pm »
I am looking for some advice on what buttons I might need for my cabinet. I am keeping the cp very simple. It will have:
  • 2 joysticks and associated buttons
  • p1 and p2 start
  • pause game
  • exit game
I am planning on putting a couple of buttons on top of the cabinet where people won't stumble onto them. Specifically 1 button to power off the whole cabinet (wired to my computer power switch and everything plugged in to a smart strip) and another button to enter the MAME configuration menu (tab).
Will this pretty much cover it all? What else should I be considering?
wweumina
  • Last login:August 30, 2022, 04:56:31 am
Re: Admin Buttons
« Reply #1 on: July 14, 2011, 11:10:00 pm »
 [rant]
Please just do a search. This question has been asked and answered plenty of times. Almost word for word. Promise.
In the last couple of days we've had control panel tilt, why 7 buttons and now how many admin buttons threads. If we get an 'is this pc good enough' thread we'll have the set.
There is also an FAQ forum..
[end rant]
Ur setup is among the most common, followed by none with shifted keys and some who add volume controls or tab for setup.
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
Re: Admin Buttons
« Reply #2 on: July 14, 2011, 11:12:22 pm »
I'd leave it at pause and exit, then people can't mess it up. Having a keyboard in the coin door is the way to go.
stalemate
Re: Admin Buttons
« Reply #3 on: July 14, 2011, 11:15:08 pm »
Hmmm.. I didn't think about a keyboard in the coin door. I thought about having one but I didn't know where I would put it that wouldn't require me to build some kind of tray and wouldn't be way inconvenient. I also have VNC access into the computer. I'll have to ponder on that.
stalemate
Re: Admin Buttons
« Reply #4 on: July 14, 2011, 11:21:29 pm »
[rant]
[end rant]
Need a hug?
lastrega
  • Last login:January 03, 2012, 12:18:19 pm
Re: Admin Buttons
« Reply #5 on: July 15, 2011, 12:49:42 am »
My cab is a cocktail, each side has a Neo geo 4 button config. Each side also has a start and a pause.... On side back side above the key locked access door is another keylocked door. Behind that door is a red hepp button , I use this the mame menu button, With my shift key (player1 start) it is also "player1 coin or 5" beside that is 2 yellow happ button for system volume. Shifted Save/Load state. Next to them is a black Rod Switch for F2 service button. And finally beside that is a red micro switch for PC power and a Black Micro for PC reset.... To exit I set it be Shift Player 1 pause.......   Hope that helps , by doing it that way I have a very clean look.......   ML
Blux
  • Last login:February 17, 2024, 12:49:33 am
Re: Admin Buttons
« Reply #6 on: July 15, 2011, 01:05:12 am »
[rant]
[end rant]
I have an old 1ghz 512mb RAM pc, if I add a video card with the correct output would this be good enough?   >:D
Donkbaca
    • Slim built MAME/Xbox cab
Re: Admin Buttons
« Reply #7 on: July 15, 2011, 01:23:55 am »
Don't do the keyboard behind the coin door, instead do a wireless keyboard/mouse you can find them dirt cheap and put them away when you don't need them
ivwshane
    • My first mame cab! (WIP)
Re: Admin Buttons
« Reply #8 on: July 15, 2011, 04:19:31 am »
Pause and exit are all you need (although on my setup I use tab instead of exit so I can configure games on the fly) I added a trackball to my cab and the pause/tab also work as left/right mouse buttons. For exit, I have P1+pause or P2+pause, that way there are no accidental exits.
wweumina
Re: Admin Buttons
« Reply #9 on: July 15, 2011, 06:46:14 am »
[rant]
[end rant]
Need a hug?
All within the last few months:
http://forum.arcadecontrols.com/index.php?topic=107236.0
http://forum.arcadecontrols.com/index.php?topic=109994.0
http://forum.arcadecontrols.com/index.php?topic=111320.0
Just saying...
Hoopz
  • Last login:November 16, 2025, 09:21:03 am
  • Intellivision Rocks!
Re: Admin Buttons
« Reply #10 on: July 15, 2011, 08:27:43 am »
You need a button for "O" and "K" unless you custom compile to avoid that nag screen.
TopJimmyCooks
Re: Admin Buttons
« Reply #11 on: July 15, 2011, 09:15:14 am »
Wireless kb/mouse is a good idea, also don't forget about those floppy usb keyboards that you can roll up and stuff anywhere, like they use at your dentist's office.  They suck to type on but get the job done in a compact way.  Could fit inside your cp if it's hinged.
misfit1138
  • Last login:June 16, 2015, 09:17:25 am
Re: Admin Buttons
« Reply #12 on: July 15, 2011, 09:22:54 am »
No.
If you move the joystick left then right it also gets you past the nag screen. (I believe it even SAYS this on the nag screen.)
  • Last login:November 18, 2025, 01:53:58 pm
Re: Admin Buttons
« Reply #13 on: July 15, 2011, 09:36:23 am »
 :laugh2: Nice one.
Hoopz
Re: Admin Buttons
« Reply #14 on: July 15, 2011, 09:39:09 am »
 :laugh2: Nice one.
Glad you got it.  We need to bring Misfit1138 up to speed on general sarcasm.   ;)
stalemate
Re: Admin Buttons
« Reply #15 on: July 15, 2011, 10:08:20 am »
I think I'll just wire one button to be every letter and have a left arrow and a delete. I should be able to type whatever I want with those.
misfit1138
Re: Admin Buttons
« Reply #16 on: July 15, 2011, 10:47:10 am »
That'll teach me to post pre-10:00 am  :applaud:
lastrega
Re: Admin Buttons
« Reply #17 on: July 15, 2011, 11:42:06 am »
or just set a parameter in mame to skip intro.............. or even better MKchamp has a pre compiled mame that automaticly skips game intros AND even skip errors like yellow "this game has problems screen"  I use it , LOVE it, it has a few bugs that need to be worked out, I will hopefully get some help on it soon... But still a nice touch:)....ML
HanoiBoi
  • Last login:April 13, 2016, 09:52:03 pm
Re: Admin Buttons
« Reply #18 on: July 15, 2011, 11:53:04 am »
  • p1 and p2 start
  • pause game
  • exit game
I didn't see you specifically call out 'coin' buttons...
gabe
  • Last login:September 10, 2012, 12:44:38 pm
Re: Admin Buttons
« Reply #19 on: July 16, 2011, 03:36:35 pm »
[rant]
[end rant]
We officially have the full set:
http://forum.arcadecontrols.com/index.php?topic=113102.0
