Author Topic: Faulty ROM?  (Read 3752 times)
sapro
  • Last login:May 29, 2011, 09:22:01 pm
Faulty ROM?
« on: May 09, 2011, 12:06:48 pm »
I have been struggling to finish the software setup for my machine. I was running Hyperspin with MAME .141 and a couple of the games wouldn't run. These games are on the MAME "working" list and I verified I had the .141 versions of them, but in Hyperspin when I select them it would act like it was opening the ROM, then would go right back to the Hyperspin menu.
I thought it was a version issue so I updated to MAME .142 and tried again with the .142 ROMS, same problem.
This is with a handful of games that, again, are verified on the list of "working" titles for MAME. The other 40+ games work fine.
Any ideas?
Hoopz
  • Last login:January 24, 2026, 09:24:43 am
  • Intellivision Rocks!
Re: Faulty ROM?
« Reply #1 on: May 09, 2011, 12:24:26 pm »
What roms?  Do you have a complete set of .141 or .142 that you are using?  Could they need the parent roms to run properly?  Any error messages?
brad808
Re: Faulty ROM?
« Reply #2 on: May 09, 2011, 12:44:05 pm »
Update your hyperspin mame database to the same version as your mame. I was having this issue as well.Sometimes roms get renamed in different versions and won't work right
sapro
Re: Faulty ROM?
« Reply #3 on: May 09, 2011, 01:44:48 pm »
Metal Slug 3, Simpsons Bowling, and the 2-player version of TMNT off the top of my head. I have the complete .142 set. I don't think they need parent ROMs, but how would I find out? No error messages.
If you mean mame.xml within the Hyperspin /databases/ dir it matches the filenames exactly.
« Last Edit: May 09, 2011, 02:06:12 pm by sapro »
BobA
  • What Me Worry?
Re: Faulty ROM?
« Reply #4 on: May 09, 2011, 04:49:18 pm »
You can check your roms and what is required in detail at MAWS
Thenasty
  • Last login:Today at 11:34:20 am
Re: Faulty ROM?
« Reply #5 on: May 09, 2011, 09:38:46 pm »
MAME gamename -verify
it's been a while and don't think parameters in mame would be taken out.
Free VGA Breakout Cable
sapro
Re: Faulty ROM?
« Reply #6 on: May 10, 2011, 08:06:30 am »
Thanks guys. While I have the complete ROM set I was only putting the games I wanted into the folder within MAME. Duh... didn't realize the parents were required. I'm going to move the entire set in tonight and see if that helps but I believe that's the answer.
sapro
Re: Faulty ROM?
« Reply #7 on: May 11, 2011, 08:40:28 pm »
yeah, big duh on my part. copied parent roms in and all work now.
