Author Topic: Outrun Cab Salvage (Dash complete. Speakers in the seats upgrade)  (Read 97040 times)
BobA
  • What Me Worry?
Re: Outrun Cab Salvage and scratch Build
« Reply #40 on: May 31, 2011, 09:12:29 am »
Looks great.   Has a really sleek profile.  :applaud: :applaud:
SNAAKE
  • Trade Count: (+29)
« Reply #41 on: May 31, 2011, 04:27:31 pm »
what are these bolts called? the stuff you used to mount the tv with that piece of wood.
http://i224.photobucket.com/albums/dd9/gbeef/Outrun/IMG_0045.jpg
everything looks great so far :cheers:
gbeef
    • arcadepix.com
« Reply #42 on: May 31, 2011, 04:33:07 pm »
I dont know the bolt name but i do know there metric.
I using a 32" LCD and used "M6" bolts. 30mm The bolts do range in size from M4-M8. M8 is what you would use on a larger LCD's like 40+.
My cabs
4 Player Arcade
X-men Arcade Remixed
gbeef
    • arcadepix.com
« Reply #43 on: May 31, 2011, 11:44:51 pm »
Another update. Did a test trial found that the base is too close the TV therefore i have to re mount the Seat ARGGGGH!!!!... But i did play dirt2 and GT3.
Bezel is on and TV is mounted top is bolted down!
My cabs
4 Player Arcade
pinballwizard79
« Reply #44 on: June 01, 2011, 10:50:26 pm »
Dude build me one
« Reply #45 on: June 01, 2011, 10:56:30 pm »
Keep at it!  It's worth the effort.  :cheers:
A quick game just turned into an hour and a half of playing on my driving cab when I should have been finishing other projects.  :D
gbeef
    • arcadepix.com
« Reply #46 on: June 04, 2011, 12:19:12 am »
Peddles are dry mounted and I've figured out how to mount the dash board.
My cabs
4 Player Arcade
gbeef
    • arcadepix.com
« Reply #47 on: June 05, 2011, 11:55:48 pm »
Another update working on the Shifter and E-brake part. Heres a cardboard mock, the final has a couple changes to the design but wanted to get the right look.
My cabs
4 Player Arcade
gbeef
    • arcadepix.com
« Reply #48 on: June 10, 2011, 01:34:57 am »
Well after all that work Ive decided to scratch the shifter idea. I'm going with a mounted on shifter like the arcade instead ill have to do some major hacking on the wheel. Im going this route because i wasn't happy with the look of the shifter it look balky. Im still going to build an E-brake into the seat.
Ive also re design some of the artwork and ill probably do it again before the project is complete (im picky). The initial design was too red, also i didn't like the style of the old school cab. Add some sex appeal and voila.
« Last Edit: June 10, 2011, 01:40:15 am by gbeef »
My cabs
4 Player Arcade
Corbo
  • Last login:June 24, 2019, 07:49:12 am
  • I've not seen such bravery
    • Minicade - Mini Gauntlet MAME project
« Reply #49 on: June 10, 2011, 03:46:54 am »
Outrun - Milf Hunter Edition?
Outrun can never be too red!!  :applaud:
_____________________
Wizard needs food, badly!
My mini arcade project:  http://minicade.blogspot.com/
« Reply #50 on: June 10, 2011, 10:57:37 am »
It ain't easy coming up with a theme.  I still haven't.
(your pin theme is total perfection btw)
How about ditching the red completely and making it all black with palm trees against the evening sky?
It could be Outrun Black Edition or Night Edition or something.
....maybe bling it up with some chrome t-molding.
gbeef
    • arcadepix.com
« Reply #51 on: June 10, 2011, 11:09:48 am »
Yeah im still playing with ideas, like i said ill probably do some other concepts. Im not a Fan of the Outrun 2 artwork, i was looking into that but i don't like the CG aspect. Also the size of the one side is a tough one because of the size its hard to design for.
 No biggie.
Ill probably end up adding lights to the back. Im trying something different with the dash today.
My cabs
4 Player Arcade
gbeef
    • arcadepix.com
« Reply #52 on: June 15, 2011, 12:36:55 am »
Big changes to the cab i decide to toss the original idea out the window and redo and reinvent how to approach this thing.  I'm mounting the Steering wheel behind the dash also im using the old frame to mount the G27 Shifter. In order to do such tasks i have to take a buzz saw to everything.... I'm almost read of paint i need to finish the steering and dash and im ready to roll.
Peddles now hard mounted.
My cabs
4 Player Arcade
pinballwizard79
« Reply #53 on: June 15, 2011, 02:15:51 am »
I am not sure whats going on so hurry up
dexxy
  • Last login:March 21, 2012, 05:52:36 pm
« Reply #54 on: June 15, 2011, 06:53:09 am »
good call on mounting the body behind the panel, gotta admit its pretty gutsy to slice up your setup!  I like your red cab best btw, but all your graphics are fantastic.
Keep up the great work!
If its interesting I'm interested!
« Reply #55 on: June 15, 2011, 09:46:55 am »
 :applaud: The dashboard looks much better.
It takes some balls to cut up a G27  :cheers:
This thing is going to set some standards.  :)
SNAAKE
« Reply #56 on: June 15, 2011, 03:13:04 pm »
digging the milf artwork lol :cheers:
chris77
  • Instant C
    • visual pinball
« Reply #57 on: June 15, 2011, 06:15:59 pm »
the MILF artwork rocks :D  :cheers:
Generic Eric
« Reply #58 on: June 15, 2011, 09:11:42 pm »
Looking forward to more pics.  Can't believe the wheel went under the knife like that!
gbeef
    • arcadepix.com
« Reply #59 on: June 26, 2011, 07:48:54 pm »
Ok so cabinet is all painted in parts i'm cleaning the parts up for rust. I'm working on the artwork still and i have to figure out how to build the speaker grill? any suggestions.
Here's a mock of the cabinet of what i would like it to looks like once complete. I plan to add lighting to the cabinet an a topper inside and lower parts of the cabinet.
My cabs
4 Player Arcade
geomartin
  • Last login:July 13, 2017, 08:55:24 am
« Reply #60 on: June 26, 2011, 08:26:04 pm »
A fantastic looking build and a great Dashboard.  Only one request :laugh:
Please!  Give me the good news first!
NiN^_^NiN
« Reply #61 on: June 26, 2011, 10:08:47 pm »
Loving the cabinet and art work nice choice using the GTA 4 girls it works well.
As for the speaker grill you could get some plexiglass with the speaker design added in then the sega logo could glow.
You could use some small off cuts of wood and make two frames then just slot the wood inside the frame to have the look you want.
gbeef
    • arcadepix.com
« Reply #62 on: June 28, 2011, 12:29:48 am »
Thanks for the idea on the plexi,  this cabinet feels like its taking forever. I have to do some repo some stickers for this thing also. Today i refurb some of the floor i also clean a ton of rust off the base and stainless steel parts.
Waiting for the base to dry so i can mount the seat. Ill put an order into groovey game gear for some T-track. Over the past weekend i painted the final coat clean out all the trash, rust and dust from the base, it was pretty nasty. Thank god for the pressure washer.
Here's some updated pics.
« Last Edit: June 28, 2011, 12:32:38 am by gbeef »
My cabs
4 Player Arcade
NiN^_^NiN
« Reply #63 on: June 28, 2011, 03:51:35 am »
That's looking fantastic :)
Can't wait to see the finished product but it's looking very nice as is  :applaud:
segalee
  • Last login:July 10, 2011, 12:38:16 pm
« Reply #64 on: June 28, 2011, 04:12:54 am »
that looks so nice i wish i had some plans for a cab like that ino its from a original cab but i have always wanted a dedicated racer
« Last Edit: June 28, 2011, 01:57:12 pm by segalee »
gbeef
    • arcadepix.com
« Reply #65 on: June 28, 2011, 12:59:59 pm »
Badmoon will be posting dimensions shortly i think he's working on something for you guys.
My cabs
4 Player Arcade
« Reply #66 on: June 28, 2011, 01:25:10 pm »
driving cab info link in my sig
Not really plans, but enough dimensions to get someone started with their own design.
I add more info fairly often, but usually don't bump it.
I'll add "last updated" back to my sig so people are aware that it's been updated.
That diamond plate looks awesome btw.
« Last Edit: June 28, 2011, 01:28:49 pm by BadMouth »
shrunkenmaster
« Reply #67 on: June 28, 2011, 01:27:16 pm »
Looking sharp my man, I bet you can't wait to get in the seat!
segalee
gbeef
    • arcadepix.com
« Reply #69 on: July 10, 2011, 12:22:29 am »
Seat dash installed, waiting on my T-molding and artwork to arrive, it will still be a couple weeks before completion. Ive installed the lighting i can change the light to any color a i want and also have it cycle.
Im modifying the coin box on so i can store the computer inside, Because with the bass shaker the whole machine moves.
My cabs
4 Player Arcade
« Reply #70 on: July 10, 2011, 01:35:21 am »
Nice job! It's looking pretty awesome all put together. With the artwork applied, this is going to look really sharp!
dexxy
« Reply #71 on: July 10, 2011, 11:23:03 am »
Great work, if you can whip up your grills into a cad file I can cut em here for ya.
Dex
« Reply #72 on: July 10, 2011, 03:39:33 pm »
 :drool
btw.....M2 Emulator v1.0 will go widescreen if you select Custom (set in .ini) under the video tab,
then set your resolution in the EMULATOR.ini file.
FullScreenWidth=1440
FullScreenHeight=900
WideScreenWindow=1
AutoFull=1
I've only done a little testing with Daytona since I don't have a widescreen on my cab.
The attract mode is widescreen, then it switches to 4:3 for the track and transmission select.
Then the game is in widescreen.  Doesn't look stretched or anything, just like it was made for widescreen.
It looks sweet!
gbeef
    • arcadepix.com
« Reply #73 on: July 10, 2011, 07:10:29 pm »
Dex
Thanks Dex i may take you up on that offer but i dont know CAD. But i do know EPS? vector formatting.
:drool
WideScreenWindow=1
AutoFull=1
It looks sweet!
SWEET!
Trying it now
My cabs
4 Player Arcade
dexxy
« Reply #74 on: July 10, 2011, 10:07:52 pm »
I can convert eps to dxf, which will cut fine, but if you want it in 3D instead of 2D, whip up a perspective sketch and I can see what I can do with it.  2D is east as pie.  I'd be glad to help on so cool a project!
sqwirral
  • Last login:May 06, 2021, 06:48:09 am
« Reply #75 on: July 27, 2011, 10:55:39 pm »
This is truly amazing, great job.
BurgerKingDiamond
« Reply #76 on: July 28, 2011, 11:44:30 am »
This looks like something you'd actually find in an arcade. Great job dude.
you're gonna be running a PC and PS3?
-Welcome to the Fantasy Zone.
gbeef
    • arcadepix.com
« Reply #77 on: July 28, 2011, 11:37:24 pm »
I have both hooked up but i play PC the most
 GT5 can't compare to the graphics on NFS2 or DIRT3.
My cabs
4 Player Arcade
gbeef
    • arcadepix.com
« Reply #78 on: August 09, 2011, 07:51:09 pm »
I had a problem with the buttons. there too long (deep) so what i did was cut about 1/4 off each button its kinda tricky because you have to take off a 1/4 in between the button. If you remove the back part you lose the molding that holds the micro switch and the spring.
After some shoegoo and crazy glue the buttons hold up nicely.
Also the artwork has finally ARRIVED!!!!!!! WOOT!
I can finally finish the rest of the cabinet with the wiring and tweaks to the wheel, im also planning on hacking the original shifter so it works with 6 speed.
Heres a teaser.
The colors came out great.
« Last Edit: August 09, 2011, 10:00:56 pm by gbeef »
My cabs
4 Player Arcade
chris77
  • Instant C
    • visual pinball
« Reply #79 on: August 10, 2011, 03:51:28 am »
WOW, I love it!  :applaud:
