Author Topic: rubik's cube: Where do I go from here?  (Read 3805 times)
pmowry
  • Last login:September 06, 2016, 11:57:00 am
« on: November 14, 2010, 09:06:13 pm »
I might just keep it this way Since I like how it looks.  But after solving the 1st and 2nd layers, I ended up with the top face complete, but 3 edge pieces out of place.  Where do i go from here?
Re: rubik's cube: Where do I go from here?
« Reply #1 on: November 14, 2010, 09:10:17 pm »
You are close but not as close as you think.  You need to make a blue "plus" on top and then solve the corners.
WhereEaglesDare
    • My HomePage
« Reply #2 on: November 14, 2010, 09:21:52 pm »
i got to where i could do one in 2 and a half minutes, it aint that hard...  took about a week to learn how to do it.
pmowry
« Reply #3 on: November 14, 2010, 09:25:29 pm »
A + or an H is how it usually ended up.  And here I was hoping it was "oh, you do these 3 twists and your done".  I'm suprised i like the way this looks.  I'm tempted to find a way to get all 4 edge peices out of place more than howe to solve it =)
HanoiBoi
  • Last login:April 13, 2016, 09:52:03 pm
« Reply #4 on: November 14, 2010, 10:27:47 pm »
Am I seeing an Orange side, but a Blue/Red piece?  So, there's a Blue/Orange on the back/right side?
I won't provide you an algorithm, but if you've got basic understanding of moves you can figure it out.
Holding the cube as pictured, you'll need to turn the orange face counter clockwise, then bump the blue/white piece out (left) to the middle layer, then return the orange face (clockwise).  Rotate the top as needed and move the blue/white piece to it's correct spot (occupied by the blue/red).  By doing that, you'll bump the blue/red piece out.
Rotate again as needed and then move the blue/red to it's correct spot (occupied by the blue/orange).  That bumps the blue/orange out.  Now all you have to do is put that one piece away and if you did it right, without unnecessary steps, you'll be done.
« Last Edit: November 14, 2010, 10:49:12 pm by HanoiBoi »
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
« Reply #5 on: November 15, 2010, 01:08:23 pm »
after you get the bottom completely right, and then the lower 2 levels correct, I believe you need to use formulas to solve the rest....
check youtube for videos...
Another Brilliant mind ruined by education....  :p
« Reply #6 on: November 15, 2010, 01:10:22 pm »
Peel the stickers off, replace in correct locations.  Duh.
HanoiBoi
« Reply #7 on: November 15, 2010, 02:49:45 pm »
Never peel the stickers.  If you MUST cheat, pop the pieces out.  Stickers are never the same after.
Thenasty
  • Last login:November 17, 2025, 12:54:16 am
« Reply #8 on: November 15, 2010, 04:53:41 pm »
Do it right, right here
Free VGA Breakout Cable
Gray_Area
  • -Banned-
  • -Banned-
« Reply #9 on: November 17, 2010, 01:02:25 am »
1980 - Pac-Man and Rubik's Cube.
-Banned-
Blanka
« Reply #10 on: November 17, 2010, 02:27:08 am »
You're at most 20 turns away!
danny_galaga
  • Last login:Today at 05:17:03 am
    • dans cocktail lounge
« Reply #11 on: November 17, 2010, 02:55:54 am »
" rubik's cube: Where do I go from here?"
pmowry
« Reply #12 on: November 20, 2010, 08:08:53 pm »
Hehe, at 11 it was peel the stickers. At 14 it was take it apart. Now at 39 I want to do it the right way.
TOK
  • The Game Always Wins
« Reply #13 on: November 20, 2010, 08:19:18 pm »
Throw it in the trash?   ;D
DaveMMR
« Reply #14 on: November 21, 2010, 10:22:54 am »
He actually updated that video and made it easier by breaking it down by steps:
Here's the first:
Here's the step you need:
This is what I used to learn how to solve it.  Once you memorize the algorithms (there's actually not all that many), it's ridiculously easy to solve from any state.
Ed_McCarron
« Reply #15 on: November 22, 2010, 10:42:09 pm »
pmowry
« Reply #16 on: November 24, 2010, 08:56:40 pm »
http://www.wrongway.org/cube/solve.html
Thanks, it shows me 40 moves away ;)
I found a java based cube I was playing with to solve it without much luck. When I get back to my PC I'll post the link here just to complement this solver.
Thanks again.
