Author Topic: what do they call it? Any recommendations?  (Read 2287 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« on: October 04, 2010, 11:34:41 am »
For my Juke project, I have a hinged front door that swings open, hinged at the bottom.
I'd like to add a "piston"(?) to the door to control it's opening. It's kind of heavy and could use a little assitance, but I don't want it to just fall open either.  I'm thinking like what is used on a car trunk (gas strut(?), the name just came to me as I was typing).
Anybody have any experience with these? (besides opening your trunk!  :laugh2:)
I'm looking for one that is about 16" closed and 21" open. I have some flexibility on the mounting locations, so the sizes can vary +/- an inch or so.
I was thinking a hardware stor originally, but after my car trunk example, I think I'll try an Auto Parts store too.
just Thinking out loud, it helps!
Thanks!  MPTech
MPTech
   Better living thru technology!   ;-)
jimmy2x2x
MPTech
Re: what do they call it? Any recommendations?
« Reply #2 on: October 04, 2010, 11:59:55 am »
Thanks.
yes, that's what I had in mind. I did find a couple sites that seem pretty technical (ie: expensive), since I figured out what they're called now.
One of the sites had a model that could be adjusted for pressure, I think since I'm experimenting, that would be a good feature.
I don't want the door shooting open!
all suggestions are greatly appreciated.
MPTech
bkenobi
« Reply #3 on: October 04, 2010, 12:40:48 pm »
Also search for "rear hatch strut" or just "hatch strut".  I found quite a few available, but they all seem a lot more expensive than what you found already.
Thenasty
  • Trade Count: (+17)
  • Last login:November 24, 2025, 04:30:42 pm
« Reply #4 on: October 04, 2010, 03:01:29 pm »
junk yard is your best cheap solution.  ;D
Free VGA Breakout Cable
MikeyMerse
  • Last login:September 30, 2011, 03:39:52 pm
« Reply #5 on: October 04, 2010, 03:47:39 pm »
Go check out Screen Door Closers. They will help with the weight of the door and I'm sure it's much easier to install.  Since your door is hinged at the bottom, I would think you want a piston that will be normally compressed.  Also, if you want it to stay open, there is a metal lock nut you slide down the piston to lock it in place.
Something like this: http://www.amazon.com/01-3810-136-HYDRAULIC-SCREEN-STORM-CLOSER/dp/B000H5O608/ref=sr_1_10?s=hardware&ie=UTF8&qid=1286221556&sr=1-10
It's available at any local hardware stores.
MPTech
« Reply #6 on: October 04, 2010, 04:11:47 pm »
That's kinda what I had in mind.  Thanks
MPTech
Rusty Shackelford
  • Last login:April 20, 2013, 02:02:09 pm
« Reply #7 on: October 04, 2010, 05:11:47 pm »
Ive fitted gas struts to a machine at work that had a heavy lid that we needed to stay open. They had a very small allen key bolt which keeps the presure (gas+oil) in to adjust for weight etc. Hold a rag over the bolt when you undo it and do a bit at a time because you cant put it back in!
