Author Topic: No background music from layout....  (Read 6885 times)
bosco
  • Last login:July 12, 2020, 01:00:54 pm
« on: September 08, 2010, 02:27:44 pm »
I can't get sound from any layout with 1.71.  I have 'enable sound' checked.  and 'use background music from layout' checked.  I set the background music in the layout to the MP3 I want to play but I still get no background music when I launch MaLa.  I see the layout, but no music.  I'm using a Mala "tree".   Anything I could be overlooking with 1.71?  It works fine on my desktop with version 1.05.
Thanks in advance.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
Re: No background music from layout....
« Reply #1 on: September 08, 2010, 04:21:13 pm »
I've checked and everything works except the background music.
The content of my log is:
2010/09/08  22:09:51.57   Info: ##########################################################################
2010/09/08  22:09:51.57   Info: **** LOGGING AT DEBUG LEVEL *****
2010/09/08  22:09:54.91   Info: Starting MaLa 1.7.1.0
2010/09/08  22:09:54.93   Info: LoggingLevel =  2
2010/09/08  22:10:34.13   Info: FormClose: Video1 Window now Closed
2010/09/08  22:10:34.14   Info: FormClose: Video2 Window now Closed
2010/09/08  22:10:34.14   Info: FormClose: Muazc Not Playing
2010/09/08  22:10:34.14   Debug **: FormClose: FBGMusicVolume= 0
2010/09/08  22:10:34.15   Debug **: FormClose: FVideo1Volume= 99
2010/09/08  22:10:34.15   Debug **: FormClose: FVideo2Volume= 99
2010/09/08  22:10:34.15   Info: Writing params to ini file
2010/09/08  22:10:34.63   Info: Muzac: Saving Playlist from Memory to FILE : C:\MaLa171\mala.pls
2010/09/08  22:10:34.63   Info: Muzac: Saving Playlist. Number of Songs to save= 0
2010/09/08  22:10:34.67   Debug **: FormClose: KillExternal Apps
2010/09/08  22:10:34.67   Debug **: FormClose: Kill Plugins
2010/09/08  22:10:34.67   Debug **: FormClose: Kill Hardware
2010/09/08  22:10:34.68   Info: FormActivate:
2010/09/08  22:10:34.68   Debug **: FormActivate: NOT FStarting
2010/09/08  22:10:34.68   Info: Screensaver: ScreenSaver Form Destroyed
2010/09/08  22:10:34.68   Info: FormClose: ShowTaskbar
2010/09/08  22:10:34.69   Info: Showing taskbar
2010/09/08  22:10:34.69   Info: Closing MaLa v1.71  [1.7.1.0]
2010/09/08  22:10:34.69   Info: **************************************************************************
2010/09/08  22:10:34.70   Debug **: CtrlExit: No exit option taken
I've tested with mp3 and wav file to background file.
Greetingd
« Last Edit: October 04, 2010, 01:09:51 am by loadman »
loadman
    • MaLa
« Reply #2 on: September 08, 2010, 11:28:54 pm »
Thanks in advance.
Please post log in debug mode
loadman
    • MaLa
« Reply #3 on: September 09, 2010, 06:05:09 am »
2010/09/08  22:09:55.25   Debug **: InitAudio: Muzac Volume set to 0
Greetingd
Thanks, I will check but you realize your volume is set to zero in any case right?
empardopo
    • My personal forum
« Reply #4 on: September 09, 2010, 07:52:38 am »
The rest of the layout can hear sounds fine except the background sound!
Do I have to do something special?
Greetings!
loadman
    • MaLa
« Reply #5 on: September 09, 2010, 10:13:28 am »
Greetings!
Have a look at the volume tab
empardopo
    • My personal forum
« Reply #6 on: September 09, 2010, 05:50:38 pm »
Loadman,
do you refer to this?
Music Sub Volume is disabled.
Greetings
loadman
    • MaLa
« Reply #7 on: September 09, 2010, 06:39:25 pm »
Yes, That means MaLa can't find the 'Wave' on your sound cards mixer. It needs that I think
empardopo
    • My personal forum
« Reply #8 on: September 09, 2010, 07:45:39 pm »
Loadman,
i'm sorry, but i think that my sound is OK. Here, i show you a screenshot
Greetings!
loadman
    • MaLa
« Reply #9 on: September 09, 2010, 07:54:38 pm »
Forget what I said   :banghead:
The TOP one is wav. If you move that you will notice that the windows wav moves too!!
I am not sure why the Music Sub Volume is dimmed? Need to check
« Last Edit: September 09, 2010, 07:56:46 pm by loadman »
bosco
« Reply #10 on: September 09, 2010, 09:47:40 pm »
My 'sub volume' is also greyed out.  I was able to raise it up after I unchecked 'use background music from layout'.  I then rechecked the box, the sub volume was at max but I still couldn't get any sound from the layout.  I hope I made sense :dizzy:
loadman
    • MaLa
« Reply #11 on: September 09, 2010, 10:26:26 pm »
Thanks Guys for the feedback info.
I need to check the background music code.  :'(
If you can be patient as that bit of teh code is a bit untidy. It may take a week or so  ;D
empardopo
    • My personal forum
« Reply #12 on: September 10, 2010, 03:07:05 am »
loadman, thanks very much!
Greetings!
loadman
    • MaLa
« Reply #13 on: September 24, 2010, 12:17:03 am »
I am working on this now
empardopo
    • My personal forum
« Reply #14 on: September 24, 2010, 02:19:20 pm »
Patience is the mother of all sciences ...
loadman
    • MaLa
« Reply #15 on: October 04, 2010, 01:05:37 am »
OK Try this
If it does not work as expected then please look at the logs at debug level for answers.
If still not working as you expect let me know.
* stale link removed *
« Last Edit: October 09, 2010, 07:27:23 pm by loadman »
bosco
« Reply #16 on: October 06, 2010, 09:52:30 pm »
Not much luck loadman.  The background music worked one time then didn't the next.  MaLa locked up on many occasions.  Had to control/alt/delete to get out of it.  It's virtually unuseable.  I don't think I'm doing anything wrong.
Here's my debug log....
2010/10/06  21:43:51.79   Debug **: KeyDownAction: Using Scrolling Acceleration. Current Interval = 200
2010/10/06  21:43:51.79   Debug **: CtrlStartGame: Game # 0
2010/10/06  21:43:51.79   Error: CtrlStartGame: FADE IN PROGRESS. Request Ignored
2010/10/06  21:43:51.89   Debug **: FormKeyUp: Key was 49
2010/10/06  21:43:51.94   Debug **: FormKeyDown: Key = 49
2010/10/06  21:43:51.95   Debug **: KeyDownAction: Using Scrolling Acceleration. Current Interval = 200
2010/10/06  21:43:51.95   Debug **: CtrlStartGame: Game # 0
2010/10/06  21:43:51.95   Error: CtrlStartGame: FADE IN PROGRESS. Request Ignored
2010/10/06  21:43:52.02   Debug **: FormKeyUp: Key was 49
2010/10/06  21:43:52.11   Debug **: FormKeyDown: Key = 49
2010/10/06  21:43:52.11   Debug **: KeyDownAction: Using Scrolling Acceleration. Current Interval = 200
2010/10/06  21:43:52.11   Debug **: CtrlStartGame: Game # 0
2010/10/06  21:43:52.12   Error: CtrlStartGame: FADE IN PROGRESS. Request Ignored
2010/10/06  21:43:52.18   Debug **: FormKeyUp: Key was 49
2010/10/06  21:43:52.27   Debug **: FormKeyDown: Key = 49
2010/10/06  21:43:52.27   Debug **: KeyDownAction: Using Scrolling Acceleration. Current Interval = 200
2010/10/06  21:43:52.27   Debug **: CtrlStartGame: Game # 0
2010/10/06  21:43:52.28   Error: CtrlStartGame: FADE IN PROGRESS. Request Ignored
2010/10/06  21:43:52.35   Debug **: FormKeyUp: Key was 49
2010/10/06  21:43:52.45   Debug **: FormKeyDown: Key = 49
2010/10/06  21:43:52.45   Debug **: KeyDownAction: Using Scrolling Acceleration. Current Interval = 200
2010/10/06  21:43:52.45   Debug **: CtrlStartGame: Game # 0
2010/10/06  21:43:52.45   Error: CtrlStartGame: FADE IN PROGRESS. Request Ignored
2010/10/06  21:43:52.54   Debug **: FormKeyUp: Key was 49
2010/10/06  21:43:53.10   Debug **: FormKeyDown: Key = 27
2010/10/06  21:43:53.10   Debug **: KeyDownAction: Using Scrolling Acceleration. Current Interval = 200
2010/10/06  21:43:53.10   Debug **: CtrlExit:
2010/10/06  21:43:53.10   Debug **: ShowExitMenu:
2010/10/06  21:43:53.24   Debug **: FormKeyUp: Key was 27
2010/10/06  21:43:53.39   Debug **: ShowExitMenu: FExitComfirm
2010/10/06  21:43:53.39   Debug **: InitExit Function
2010/10/06  21:43:53.39   Debug **: GetLayoutPath: all files in a defined directory in layout sub dirs D:\Games\MaLa\layouts\Welcome\standardstartH.jpg
2010/10/06  21:44:11.34   Info: FormClose
2010/10/06  21:44:11.34   Info: FormClose: There are no active plugins to close.
2010/10/06  21:44:11.34   Debug **: FormClose: Disable Timers
2010/10/06  21:44:11.35   Debug **: FormClose: Kill Window
2010/10/06  21:44:11.77   Info: FormClose: Video1 Window now Closed
2010/10/06  21:44:11.77   Info: FormClose: Video2 Window now Closed
2010/10/06  21:44:11.78   Info: FormClose: Muzac Playing
2010/10/06  21:44:11.78   Debug **: FormClose: FBGMusicVolume= 0
2010/10/06  21:44:11.78   Debug **: FormClose: FVideo1Volume= 76
2010/10/06  21:44:11.78   Debug **: FormClose: FVideo2Volume= 76
2010/10/06  21:44:11.78   Info: Writing params to ini file
2010/10/06  21:44:11.88   Info: Muzac: Saving Playlist from Memory to FILE : D:\Games\MaLa\mala.pls
2010/10/06  21:44:11.88   Info: Muzac: Saving Playlist. Number of Songs to save= 1
2010/10/06  21:44:11.88   Debug **: Muzac: Saving Playlist. Adding 0 D:\Games\MaLa\layouts\Welcome\mala.mp3
2010/10/06  21:44:11.91   Info: Muzac: StopBGMusic
2010/10/06  21:44:11.91   Debug **: Muzac: StopBGMusic FADES ENABLED- Fade Out Start
2010/10/06  21:44:11.91   Debug **: Muzac: StopBGMusic FADES ENABLED- Fade Out Finished
2010/10/06  21:44:11.91   Info: Muzac: Save current song and position
2010/10/06  21:44:11.96   Debug **: FormClose: KillExternal Apps
2010/10/06  21:44:11.96   Debug **: FormClose: Kill Plugins
2010/10/06  21:44:11.96   Debug **: FormClose: Kill Hardware
2010/10/06  21:44:11.97   Info: Screensaver: ScreenSaver Form Destroyed
2010/10/06  21:44:11.99   Info: FormClose: ShowTaskbar
2010/10/06  21:44:12.00   Info: Showing taskbar
2010/10/06  21:44:12.00   Info: Closing MaLa v1.71 BETA [1.7.1.8]
2010/10/06  21:44:12.00   Info: **************************************************************************
2010/10/06  21:44:12.00   Debug **: CtrlExit: No exit option taken
loadman
    • MaLa
« Reply #17 on: October 06, 2010, 10:40:31 pm »
Thanks for testing and reporting. I will recheck the BG Muzac code.
But also are you saying there is a major stability issue between 1.710 and 1.718? Does mala lock up on earlier versions?  That bit does not add up. Did you have two versions running in error.  I don't understand  :-[
bosco
« Reply #18 on: October 08, 2010, 08:48:36 pm »
I just replaced the MaLa exe file with the new one.  Then things started acting up.  Maybe I accidently did something wrong because I put the 1.71 back and I was having issues.  Do I need to delete something when replacing the MaLa exe?  I'm going to re-install both of the versions over the weekend and see what happens.  I'll keep them completely seperate folders.
Thanks Loadman.....
loadman
    • MaLa
« Reply #19 on: October 08, 2010, 09:48:31 pm »
I just replaced the MaLa exe file with the new one.  Then things started acting up.  Maybe I accidentally did something wrong because I put the 1.71 back and I was having issues.  Do I need to delete something when replacing the MaLa exe?  I'm going to re-install both of the versions over the weekend and see what happens.  I'll keep them completely separate folders.
Thanks Loadman.....
You should not have to do anything other than replace the MaLa's if using the same folder (it will need to be call MaLa.exe ) I certainly recommend running mala beta's in a separate folders
I appreciate your testing.   ;D
Latest Beta:
http://www.malafe.net/files/download/MaLa1720.zip
« Last Edit: October 17, 2010, 03:12:13 am by loadman »
