February 24, 2026, 09:53:55 pm
Here is oneShuttleXpressThere are others on Amazon as well.
Quote from: BobA on September 02, 2010, 12:45:21 amHere is oneShuttleXpressThere are others on Amazon as well.these also have the cord coming out the side and are designed to sit on a desktop , im after something that can be mounted to a vertical piece of mdf (my jukebox)
Quote from: egosbar on September 02, 2010, 01:57:40 amQuote from: BobA on September 02, 2010, 12:45:21 amHere is oneShuttleXpressThere are others on Amazon as well.these also have the cord coming out the side and are designed to sit on a desktop , im after something that can be mounted to a vertical piece of mdf (my jukebox)thats an idea , what i was thinking is not only will i have the volume but apparently you can push and turn for an action , so if i map it to push in right for next song and push in left for clear cue i wont have to add any more buttons to my jukeif you come across it please let me knowYou can hack a Griffin Powermate to do that. I can't remember where I saw the write up...might even have been here in the juke forum.
Griffin disassembled for panel mount:http://forum.arcadecontrols.com/index.php?topic=63751.0
As mentioned, you can take it apart and do a lot with it. I have taken apart dozens of them now and have it down. It can be accomplished without even removing the wires from the board.Here is how I mount them on a vertical surface. Hope this helps. http://forum.arcadecontrols.com/index.php?topic=79817.msg838440#msg838440
