Author Topic: Possible to play videos with microxp?  (Read 5243 times)
jimmy2x2x
« on: August 03, 2010, 07:38:19 pm »
I have been playing around with video support for hours now, I cant get anything to playback.
Animated GIF's - no problem at all, but cant manage .avi files
I assume its a codec related issue or possible a missing component from MicroXP installation.
I have installed xvid codec with support for FourCC (xvid, divx,dx50, mp4v)
v1.22 from http://www.xvidmovies.com/codec/
Any suggestions?  Thanks
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
Re: Possible to play videos with microxp?
« Reply #1 on: August 03, 2010, 08:23:07 pm »
I haven't a clue  ???    :dizzy:   ...... but recall seeing ffdshow codec mentioned in a couple of recent(ish)  threads....err this one and that one.  Also mentioned is a possible missing dll.
Good luck!
« Last Edit: August 03, 2010, 08:24:57 pm by EwJ »
jimmy2x2x
« Reply #2 on: August 04, 2010, 10:31:54 am »
No dice
I uninstalled the XVID codec, rebooted, installed ffdshow tryout (latest version), rebooted
and still no videos
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« Reply #3 on: August 04, 2010, 10:39:14 am »
Try installing WMP 11.
Please, discuss the results.
Greetings!
« Reply #4 on: August 04, 2010, 11:14:51 am »
I'm at work, so I don't have access to MALA at the moment, but I messed with codecs for a whole day before discovering a checkbox somewhere in the MALA options that needed to be checked.
It's been too long ago to remember the details, but I remember it being in an odd place where I didn't think it belonged.
Look at all the tabs and sub-tabs under MALA setup!
jimmy2x2x
« Reply #5 on: August 04, 2010, 02:22:01 pm »
Sounds promising, cant see anything here - hopefully you can find it!
WMP11 made no difference ;(
« Reply #6 on: August 04, 2010, 02:59:36 pm »
Still at work, but this might have been it.....
http://wiki.arcadecontrols.com/wiki/Image:Mala_OptionsGO.JPG
Doesn't seem that hidden.  I do remember feeling like an idiot after uninstalling and reinstalling codecs a few times when all I had to do was check a box.   :embarassed:
« Last Edit: August 04, 2010, 03:04:21 pm by BadMouth »
jimmy2x2x
« Reply #7 on: August 04, 2010, 03:02:44 pm »
Got that enabled, thanks for the effort!
I thought more people would be using microxp with mala!
empardopo
    • My personal forum
« Reply #8 on: August 04, 2010, 05:37:28 pm »
jimmy2x2x,do you have the same problem with different versions of MALA?
Could you try with a old version of MALA? I've read in a post about the bass.dll library! have you that dll in your system on MicroXP?
jimmy2x2x
« Reply #9 on: August 04, 2010, 07:37:01 pm »
bass.dll is present
I have just tried a fresh install a new folder with 1.0.5.8
No videos still
Then I copied the new beta into that folder
Tried again, no videos
loadman
    • MaLa
« Reply #10 on: August 04, 2010, 07:38:28 pm »
bass.dll is for audio for older versions of MaLa.
Stripped down versions of Windows have issues with some video codecs
jimmy2x2x
« Reply #11 on: August 04, 2010, 08:01:02 pm »
I suspected so
I will install full XP and try again
empardopo
    • My personal forum
« Reply #12 on: August 05, 2010, 04:51:46 am »
I don't know what is the problem of MicroXP with videos in Mala because the videos work fine in other programs.
Windows XP full version is not necesary. You can try with Suricata.
Sorry can not help more.
empardopo
    • My personal forum
« Reply #13 on: August 05, 2010, 07:35:39 pm »
I've been testing MicroXP.
I found another version of MicroXP. You can look at putting MICROXP_V0.82.rar in Google.
I've installed WMP 10 and Klite codec Pack 6.04.
I got the videos to be seen.
Greetings.
jimmy2x2x
« Reply #14 on: August 05, 2010, 08:00:25 pm »
Thats great news!
I will be sure to try that out, after explaining the issue to a friend of mine - he recommended Maximus Arcade front end, Im just trying that out at the moment
I will be sure to have a look into your solution though, thanks!
empardopo
    • My personal forum
« Reply #15 on: August 06, 2010, 04:32:51 am »
MALA is the best frontend! Remember that MALA is alive thanks to Loadman! :applaud:
And Maximus?
Yourself!
jimmy2x2x
« Reply #16 on: August 06, 2010, 04:42:33 am »
I fully support loadman, he is doing an excellent job!
And I have really enjoyed using Mala, I will try my 30 day trial with MA, then comeback to Mala - following your instructions for the videos
Long Live MALA!!
