Author Topic: SF2/MK/NEO GEO cp layouts, 7 buttons or ???  (Read 3809 times)
transfan
  • Last login:April 07, 2011, 11:38:37 am
« on: July 24, 2010, 07:51:19 pm »
I'd like to get feedback on how folks set up their fighting control panels, and reasoning.
I've seen 7 buttons where the top 6 are standard japanese but then there is one on the bottom left that is used for button A (thereby making buttons 4,5,6 = b,c,d respectively)   also what about mortal kombat block?
Just curious!
Re: SF2/MK/NEO GEO cp layouts, 7 buttons or ???
« Reply #1 on: July 24, 2010, 10:28:48 pm »
in terms of the 7 button layout for MK, the middle two attack buttons in SF can both be used to block in MK and the 7th button is for run, at least thats how I used it.
shfifty
  • Last login:September 21, 2017, 08:03:39 am
« Reply #2 on: July 24, 2010, 10:53:20 pm »
i would pick the layout depending on the games that you play most. I just used the standard jap 6 button layout cause i mainly play capcom fighters, i left out the 7th button cause i dont really play enough snk games to warrant it.
Probably stick with the 7 button layout you have described, that covers everything except mortal kombat but you can easily play MK as malenko said
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Last Edit: July 25, 2010, 06:36:38 am by kowal »
eds1275
  • Last login:March 11, 2026, 11:07:08 am
  • Rock and Roll!
« Reply #4 on: July 25, 2010, 01:15:31 pm »
I'll be going with the 7 button layout - I love MK but not enough to have a goofy control panel that's unplayable for other games... so a street fighter layout with a run button, if that makes sense.
transfan
« Reply #5 on: July 26, 2010, 12:42:36 am »
Thank you all for your replies.
I think I am going to go with something very similar to taito vewlix
The top 4 buttons will be ABCD, and I'm assuming the lone button on the right could also function as RUN in MK
Also I noticed something when I put my hands on my blank CP in order to determine the layout:  My hands feel more comfortable if they are pointed diagonally rather than straight at the monitor.  So I may wind up tilting my layout counter-clockwise.
To see what I mean, rest your hands on your keyboard.  My right index finger falls on N, middle on K, ring on L or O, and pinky on ; or P
May just be from years of typing, but that's how mine fit.  Anyone else?
« Last Edit: July 26, 2010, 12:51:29 am by transfan »
