Author Topic: Monitor burn ... Now what ?  (Read 2005 times)
Jasonmm
  • Last login:July 30, 2021, 01:07:46 pm
« on: June 27, 2010, 05:56:51 pm »
Okay I got monitor burn , now what ? Can it be fixxed ? Repaired ?
Wells Gardner , 19in.
Throw it in the trash ?
thanks J
Thenasty
  • Last login:February 03, 2026, 08:27:56 pm
Re: Monitor burn ... Now what ?
« Reply #1 on: June 27, 2010, 07:32:05 pm »
it can be repaired (not worth it) just buy a new one.
you can place a SMOKE Plexi as your Bezel and you won't even see it.
Save the PCB and find another one that you can swap the monitor with.
Free VGA Breakout Cable
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: June 27, 2010, 09:05:29 pm »
Nicely done...tell the guy to replace something that's not being made any more just because of some burn!  There are a finite amount of these in the world.  Even though there are plenty NOW, the more these keep getting tossed because of minor repairable issues the less there will be in the future.  And that future will come sooner unless we're conservative.
If its light burn - I'd just live with it, its hard to notice when the game is on.
If it's heavy burn, you can replace the tube, or try the smoked plexi like was suggested.
Thenasty
« Reply #3 on: June 28, 2010, 07:47:02 am »
WG don't make 19" anymore ?
I guess the k72xx series is out then. I bought mine 3-4 years ago.
Jasonmm
« Reply #4 on: June 28, 2010, 11:42:49 am »
opps wg 19k4914 19in
yes the burn is bad , real bad , its sooo bad it looks okay as it is one solid burn , without seeing any actual figure or text
i already ordered stuff for it , cap and vga conv cable
man
i wish i know what to do
MonMotha
« Reply #5 on: June 28, 2010, 01:19:36 pm »
If it's that bad and you can find a suitable "donor" tube from a TV or a similar monitor beyond repair, you can attempt a tube swap.  Hardest part is often verifying that the yokes match (or swapping them, if they don't).  CRT burn is unfortunately irreparable from a practical standpoint, and new CRT monitors are really hard to come by.
