Author Topic: Confused about D9800 Convex/Flat  (Read 2765 times)
Shecky
  • Last login:November 25, 2014, 07:20:22 pm
« on: April 28, 2010, 06:37:06 pm »
Iam looking into getting a Wells-Garner D9800. When shopping around I found that xArcade sells this monitor in (2) versions; Convex and Flat. Then I went directly to the Wells-Garner website and I found out that I can buy directly from them, but I can only find the flat screen version of the D9800. Am I missing something? I put the links below. What are the Pros/Cons? Any help would be greatly appreciated.
xArcade:
http://www.xgaming.com/store/arcade-parts-and-accessories/product/wells-gardner-27-d9400-monitor/
Wells-Garner:
http://www.wellsgardner.com/products/details.asp?iCat=2&iSubCat=47
ahofle
    • Arcade Ambience Project
Re: Confused about D9800 Convex/Flat
« Reply #1 on: April 29, 2010, 12:01:36 am »
Are you sure they sell it with a curved screen (ie. that's the older D9400 not the D9800)?  You should contact XArcade, I'm guessing the picture is wrong and they only sell the D9800 now (which only comes with a flat screen).
« Last Edit: April 29, 2010, 12:04:43 am by ahofle »
gatordad
  • Trade Count: (+11)
  • Last login:February 15, 2026, 10:34:21 am
« Reply #2 on: April 30, 2010, 10:01:51 am »
d9800 is flat tube only
d9400 is discontinued and came with a curved tube
Epyx
  • "You're an oddity"
« Reply #3 on: April 30, 2010, 10:45:53 am »
Yep flat tube only. I have two of them and so far great monitors.
Last Project
Epyx Tutorials:
Tutorials
Shecky
« Reply #4 on: April 30, 2010, 11:25:02 am »
I sorta want the authentic old school Convex look , but am I correct in saying that since it is flat and not curved there is less distortion in the corners of the screen?  Anyways I am glad to hear you like the monitor and I will be buying this monitor once the funding comes in. Thanks for the help!
Epyx
« Reply #5 on: April 30, 2010, 11:46:48 am »
There are still options for that.  You can try NiemanDisplays for example.
I got these monitors (D9800) because of the tri-sync capability. I play a mix of emulators and PC games and wanted the range of resolutions.
Last Project
Epyx Tutorials:
Tutorials
