Author Topic: How long does your cab take to boot up?  (Read 1956 times)
shfifty
  • Last login:September 21, 2017, 08:03:39 am
« on: April 13, 2010, 11:27:07 am »
As the title says, i'm interested in the boot times for various systems, especially newer linux & shelled windows cabs. You will need a stop watch of some sort. Since i got CPS3 working in dos, my only real motivation to upgrade the OS and frontend lies with a better boot time... otherwise ill keep it old school
  • Time is measured in seconds from the moment you hit the power button untill the cab has loaded the front end and ready to boot games.
  • Exclude any startup videos etc
Also include:
  • CPU type
  • RAM
  • O.S.
  • Frontend
  • Anything else you reckon effects it
I guess i should get the ball rolling...
- 23 Sec
- AdvanceMenu straight up through dos
- P4 2.0 Ghz
- 256mb SD ram
Thenasty
  • Last login:February 03, 2026, 08:27:56 pm
Re: How long does your cab take to boot up?
« Reply #1 on: April 13, 2010, 01:52:01 pm »
Flick the switch on and counter starts. Took 18 Secs to the AdvMenu FE.
DOS 7.1
P4 (forgot)
1GB RAM
Advmenu FE
Advmame Emulator
OTHER: It takes 0 sec to shutdown   >:D
« Last Edit: April 13, 2010, 01:54:02 pm by Thenasty »
Free VGA Breakout Cable
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: April 13, 2010, 02:05:03 pm »
AMD 2 GHZ
256 Mega de RAM
WINDOWS XP
ATOMIC FE
=>  11 seconds
Same Machine  but with :
DOS 6.2
ADVMENU
=> 15 seconds
NOTE: the machine is dedicated to the cab.  i don't use the machine for something else. (no internet for instance)
« Last Edit: April 13, 2010, 02:07:30 pm by youki »
atomikbohm
  • Last login:January 22, 2018, 11:33:35 am
« Reply #3 on: April 13, 2010, 05:57:44 pm »
Not to hijack the thread but how do you cut your boot up time down so low?  I haven't timed my boot yet but I know it's way longer than 11 sec (and most likely longer then 23 secs).
I'm forgetting my exact system specs but my cab PC is something along the lines of:
AMD Athlon XP 1.6GHz (sound about right)
768MB DDR RAM
Windows XP (32 bit)
Mala FE
I know that you can disable services Via - My Computer -> Manage -> Services and Applications -> Services.  But am unsure which ones I can do with out.  Can anyone offer some advise?
youki
    • Atomic Front End
« Reply #4 on: April 14, 2010, 03:36:08 am »
I have removed all things at start up.
And i stopped all not usefull services.
To know which ones to remove.
Some are obvious
for other i look on internet what is the purpose of the services and when make sense stopped it.
And for other, i tried one by one.  I stop one, reboot, look if it still work as i want. If yes, i stop the next one , if no i restart the service and stop the next one.
I tooks time, but at the final it boots in 11secondes.
I have also disabled all device driver i don't need.
« Reply #5 on: April 14, 2010, 07:23:31 am »
AMD Athlon x2
ASus m3n78-vm mobo
4 gb ram
1.5 tb 7200rpm drive
Windows Vista
Takes about 45 seconds from cold to running Mala
Not great, I suppose, but not too bad considering I've done very little tuning yet.
It's also still running the full network stack so I can admin it remotely.
