Author Topic: What size monitor in an original Donkey Knog cab?  (Read 13333 times)
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« on: April 07, 2010, 08:05:33 am »
Does anybody know what size monitor an original Donkey Kong cab had?
RetroBorg
Re: What size monitor in an original Donkey Kong cab?
« Reply #2 on: April 08, 2010, 06:01:39 am »
Thanks mate.  ;D
HanoiBoi
  • Last login:April 13, 2016, 09:52:03 pm
Re: What size monitor in an original Donkey Knog cab?
« Reply #3 on: April 08, 2010, 09:25:33 am »
Wow javeryh, nice response!
Any chance in finding monitor size for Space Duel??
I tried your links, but didn't see SpaceDuel listed; http://files.flipperspill.no/Support/Arcade/Manuals/S/
I've got a PC monitor in the cab now, running MAME.  I think it's a 17".  I would love to know the largest I could fit in there (height, width, depth), but I haven't been able to quickly figure that out.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: April 08, 2010, 09:42:19 am »
Space Duel was a 19" monitor. Recall that 19" arcade monitor != 19" PC monitor. Your best bet is always to measure.
If you want to find manuals for games, check the Restoration Page In The Wiki it has every major source for arcade documentation that I am aware of.
* CheffoJeffo weeps for that classic Atari vector
Working: Not Enough
Projects: Too Many
Progress: None
HanoiBoi
« Reply #5 on: April 08, 2010, 10:00:35 am »
Thanks CheffoJeffo.  I can measure the cabinet...it's finding a comparable monitor (external measurements) that seem to have me baffled.  I don't necessarily want to decase anything if not needed and I don't think I want to throw a wide screen in there...
I guess I want something simple and cheap, and as big as will fit.
Veeb0rg
  • Last login:May 31, 2017, 07:34:27 pm
« Reply #6 on: May 03, 2010, 02:58:18 am »
This is a 19inch Viewsonic in an arcade mounting frame in my Space Duel Cab. If the monitor hadn't been free, I would have gone with a 21inch PC monitor. The viewsonic wouldn't fit until I decased it, without stripping it I could just barely fit a 17 inch in the opening. As you can see the Viewsonic tube is just a bit to small for the 19inch arcade bracket, the zipties just keep the tube in place, the weight is carried by the top 2 bolts.
Jeffo, Don't weap for my vector, when I rescued the cab it had been completely stripped and was scheduled for a sledgehammer/dumpster treatment. I do plan on fully restoring it to its vector glory if I ever manage to get the monitor. None of my mame "modifcations" are permanent and can be reversed, I've taken measures to ensure this.
« Last Edit: May 03, 2010, 03:09:03 am by Veeb0rg »
gatordad
  • Trade Count: (+11)
  • Last login:March 08, 2026, 12:36:20 pm
« Reply #7 on: May 03, 2010, 11:44:59 pm »
I believe that the tube number on the sanyo ez end in 51 which technically would be a 20 inch tube,
Tube number ending in 48 is a 19 inch tube
This is off the top of my head so don't hold me to it.
Both tubes the 19 (48) and 20 (51) should fit into a standard monitor frame as the mounts are identical
FrizzleFried
    • Idaho Garagecade
« Reply #8 on: May 04, 2010, 12:28:39 pm »
Yes... the Sanyo 20-EZ is...well... 20".
It's not a Sanyo 19-EZ afterall.
