Author Topic: Can I use a Dremel to cut the slot for t-molding?  (Read 10724 times)
TBullet
  • Last login:February 11, 2012, 03:18:17 pm
« on: March 30, 2010, 12:51:58 pm »
I don't have access to a router but I do have a Dremel. Has anyone had any success using one to cut a slot for t-molding?
Later.
D.E.
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
Re: Can I use a Dremel to cut the slot for t-molding?
« Reply #1 on: March 30, 2010, 03:18:22 pm »
I definitely wouldn't suggest it! You could always hire out a router for the day ?
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
« Reply #2 on: March 30, 2010, 04:40:43 pm »
I have a dremel with router attachment/base and is doesn't have the guts to do any serious work.
Epyx
  • "You're an oddity"
« Reply #3 on: March 30, 2010, 04:50:35 pm »
Borrow or rent one if you can. Although if possible, place a new one on your Birthday/Xmas list ;)
Last Project
Epyx Tutorials:
Tutorials
TBullet
« Reply #4 on: April 02, 2010, 12:57:17 pm »
It looks like I'm going to have to get the slotted bit from t-molding with the t-molding I need. Are the bits universal on the 1/4" or 1/2" shank? I'll look at renting a router to get this one done.
Later.
D.E.
Wolfman5750
  • Last login:November 08, 2012, 09:27:20 am
« Reply #5 on: April 02, 2010, 05:26:37 pm »
You should check on craigslist for a router.  I found one on there for 20 bucks with bits.
tutone
  • Last login:August 03, 2016, 02:53:43 am
« Reply #6 on: April 03, 2010, 01:51:35 am »
Not sure what you are asking but maybe I'm reading this wrong.  Typical routers have 1/4 and/or 1/2 collets.  The bit you are ordering from t-moulding is the cutting bit with an arbor.  The arbor is 1/4 (I think) so you'll need the 1/4 collet for that.  Just   make sure that you have a collet for the router that matches the size of the arbor and you'll be OK.
Harbor freight has a set of slot-cutters in 1/4, and a set in 1/2 for under $30.  I think the single slot cutter from t-moulding is cheaper.
tutone
« Reply #7 on: April 03, 2010, 02:01:41 am »
tutone
« Reply #8 on: April 03, 2010, 02:01:49 am »
sorry for the triple posting.
« Last Edit: April 03, 2010, 02:04:59 am by tutone »
TBullet
« Reply #9 on: April 03, 2010, 12:14:58 pm »
What I'm asking is: I'll have to rent a router. I don't have one. Depending on what the rented router shank size is, 1/4" or 1/2", I was wondering if the 7/64" slot cutter is universal on both 1/4" or 1/2" shanks.
I'll have to find out what size shank the rented router is and go from there. I just checked and it looks like they have a 1/2" collet on the router.
Thanks.
Later.
D.E.
tutone
« Reply #10 on: April 04, 2010, 02:18:18 am »
The router will have a collet (1/2" as you've found out) and will probably not come with a shank (arbor).  The arbor usually comes with the slot cutter.  The slot cutter will _either_ fit on a 1/4 arbor, or a 1/2 arbor, but not both.
The arbor is a 1/4 or 1/2 diameter shaft that is threaded on the end.  you install the slot cutter (and shims and bearing) on the end of the arbor and put the nut on it.  Now you take this whole tool and put it in the collet on the router and tighten it down.
I think the slot cutters from t-moulding come with the arbor and bearing, etc.. so then you just need to make sure you have the right collet size for the arbor size.
Hope that helps.
TBullet
« Reply #11 on: April 05, 2010, 04:20:56 pm »
This will help a lot. Thanks.
Later.
D.E.
jbarnatt
  • Last login:March 19, 2014, 05:38:03 pm
  • I built it, now I have to push it.
    • Let me build your arcade cabinet
« Reply #12 on: April 09, 2010, 05:07:16 pm »
I say it can. It's a little harder to do though, especially on 3/4. You might need to do a little hand work to make it nice. I used mine to my T-molding. The major problem I ran into was making the groove wide enough. In fairness, my machines are built out of 1/2 MDF and they are only about 4 feet tall overall.
TBullet
« Reply #13 on: April 25, 2010, 03:47:50 pm »
Well, I ordered the 3 slot cutter from T-molding for the 5/8" molding I need. Now just to get a router and set it up. How deep should I cut the slot? 1/4" or just enough to have it fit?
Later.
D.E.
Hoopz
  • Last login:Yesterday at 09:59:38 am
  • Intellivision Rocks!
« Reply #14 on: April 25, 2010, 09:37:33 pm »
It doesn't matter how deep.  The t-molding will need to be pushed firmly into the slot and it sticks pretty firmly in there.
jmike
« Reply #15 on: April 28, 2010, 06:56:13 am »
Two things to remember
1st: you want to make sure you have the slot cutter the right side up.
2nd: Make sure you try cutting the groove on a scrap piece first, (insert the T-molding to make sure it's centered).
Good Luck
« Reply #16 on: April 28, 2010, 07:26:04 am »
+1 on that. Testing on scrap is the BEST way to make sure you've got your setup right. Remember to lay down a piece of laminate there as well if you'll be laminating or putting anything on top of the CP, as it will effect the thickness slightly and you'll need to adjust the slot cutter position as appropriate.
Epyx
« Reply #17 on: April 28, 2010, 11:24:01 am »
As per the tips above:
1) Smoke = bad and is usually and indication you have the cutter the wrong side up.
2) Ensure you are hand routing in the proper feed direction.  For outer edges like T Mold slots make sure you are routing in a counter-clockwise direction so you don't jump. Concentrate on keeping the pad of the router down as even a bit of lift will offset your slot. This is best achieved with a slow but deliberate pace where you maintain as much pressure keeping the router flush as you do guiding it along.
As per above practice this with scraps first until you are comfortable...don't rush it!
Last Project
Epyx Tutorials:
Tutorials
