Author Topic: 5/8" VS 3/4" for a slim cab  (Read 3377 times)
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
« on: March 12, 2010, 04:12:22 pm »
Is there a standard for side panel width? My cab-in-the-making is a slim [23 3/4"] and wide [28 3/4" inside width not including the sides] design [6' tall]. I am torn between the added rigidity or 3/4" yet feel that 5/8 will be more than adequate. Any input on this?
SammyWI
Re: 5/8" VS 3/4" for a slim cab
« Reply #1 on: March 12, 2010, 05:59:18 pm »
Most cabs use 3/4". One reason is because it's far more available than 5/8" material.  1/2" material (the next step down that is wildly available) is probably too thin.  Also there are a lot more options for T molding in 3/4" than 5/8".
If I had easy access to 5/8" material, I'd use it.  But I'll probably be using 3/4" sanded (one side) birch plywood for my cab since it's fairly close to the same cost as 3/4" MDF locally but quite a bit lighter.
RobbyMac
  • Last login:January 05, 2019, 06:48:50 pm
  • My New years Resolution is 1400 x 900.
    • My cabinet build
« Reply #2 on: March 12, 2010, 06:25:12 pm »
I'd use 5/8" for a slim if available.
I built my UAII clone using 5/8" and it's more than 'bulky' looking. 3/4" on a slim might be a bit thick in appearance.
I've been tinkering with the idea of building a 'mini' for my son... if I did I'd probably use 1/2". even 5/8" would appear too thick for it I think.
eds1275
  • Rock and Roll!
« Reply #3 on: March 12, 2010, 06:53:50 pm »
I guess I'm lucky - 5/8 and 3/4 are both readily available where I live. I guess I'll use 3/4 on the sides and 5/8 for the rest to try and minimize the weight.
Epyx
  • "You're an oddity"
« Reply #4 on: March 12, 2010, 08:14:02 pm »
The main question I would ask is are you going to laminate?
If you are going to laminate...hands down go with 5/8"...use 3/4" T molding and 1/16" Laminate (Wilsonart/Formica etc).  Your T Molding will be flush over the laminate.  The laminate also adds to the rigidity.
If you are going to paint...go with 3/4".
« Last Edit: March 12, 2010, 08:16:37 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Michigan Classic Arcade
  • Last login:July 06, 2010, 10:46:58 pm
« Reply #5 on: March 13, 2010, 10:38:07 pm »
We build our cabinets out of 3/4 material, it's stronger and very much available in Home Depot or Lowes.
It makes for a heavy cabinet tho. I have 1 t-molding slot cutter available if anyone is interested in it please visit our site.
« Last Edit: March 13, 2010, 10:40:26 pm by Michigan Classic Arcade »
