November 27, 2025, 12:21:10 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Main Forum
Lost Keys for Happs Over/Under Coin Door
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Lost Keys for Happs Over/Under Coin Door (Read 2119 times)
SteveJ34
Trade Count:
+9
Full Member
Offline
Last login:January 06, 2024, 12:29:40 am
on:
February 21, 2010, 01:34:12 pm »
My first build took residence at my nephews for several years which now has moved to another family member's gameroom.
However, they've lost the keys to coin door which was originally purchased from Happ's about 8 years ago...like this one:
http://www.happcontrols.com/coindoors/40003800.htm
I searched on Happs but did not see "keys" as a part replacement.
Any suggestions on how to get replacement keys for my unit?
Steve
Logged
saint
turned to the Dark Side
Supreme Chancellor
Trade Count:
+6
Full Member
Offline
Last login:November 22, 2025, 12:26:51 pm
I only work in cyberspace...
Re: Lost Keys for Happs Over/Under Coin Door
Reply #1 on:
February 21, 2010, 01:47:07 pm »
Drill the lock, put in a new one. They're cheap enough. Vendors here sell them, or you can get them at hardware stores.
Logged
--- John St.Clair
Project Arcade 2!
saint@arcadecontrols.com
Thenasty
Trade Count:
+17
Full Member
Online
Last login:
Today
at 12:08:54 pm
Reply #2 on:
February 21, 2010, 09:28:50 pm »
someties going thru the back door, you can unscrew the latch from the coin door.
Logged
Free VGA Breakout Cable
daywane
Trade Count:
+4
Full Member
Offline
Last login:November 02, 2025, 08:43:36 pm
GRRRR!
Reply #3 on:
February 22, 2010, 05:48:25 pm »
once you go through the back and remove lock from door you can take the lock apart, remove pins, put lock back together and almost any key will work.
dummy lock it.
Logged
sk8ersublime
Trade Count:
0
Full Member
Offline
Last login:October 23, 2025, 11:13:39 pm
Reply #4 on:
February 22, 2010, 08:26:54 pm »
remove the lock, replace from home depot, or from arcade vendor. The cam locks they sell at lowes would not fit my coin door, they were too fat. But the ones from home depot fit perfectly
Logged
Drews Arcade
Trade Count:
+1
Full Member
Offline
Last login:July 28, 2018, 01:15:02 am
Reply #5 on:
February 24, 2010, 04:28:35 pm »
Some of happs locks have the key code marked on the outside of the lock. (example a05) If it does, order up a key from them.
Logged
Global Moderator
Trade Count:
+6
Full Member
Offline
Last login:
Yesterday
at 07:09:41 am
Build the impossible -"There is no Spoon"
Reply #6 on:
February 24, 2010, 05:28:28 pm »
I have the same coin doors and Tornado Terry's sells ones that are keyed alike. So one key will open everything. They go for about $3.15 or so.
http://www.tornadoterrys.com/surplus.htm
As far as getting them unlocked: +1 on accessing it from the back of the cabinet to remove the lock. Second option would be to drill them out. Basically you drill a hole right where the key would go into on the front of the lock. Once you drill all the way through it, the lock will turn so that you can open it. The third method would be to jimmy it open, but I DO NOT recommend that, since it will damage your door.
DeLuSioNaL29
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
