Author Topic: Is illustrator the only software that can open .ai files?  (Read 3933 times)
syph007
« on: September 09, 2009, 08:49:01 pm »
I'm just asking because it's ridiculously expensive.  I just wanted to start fiddling around and open some of the vector art files available on the web, but was wondering if the only program that works is illustrator?
Ryglore
    • The Brush Wizard
Re: Is illustrator the only software that can open .ai files?
« Reply #1 on: September 09, 2009, 09:06:19 pm »
As far as I know Illustrator is the only program you can use for it. .ai basically means adobe illustrator....
Trebeck
  • "The Arcade" - Build #4
« Reply #2 on: September 09, 2009, 09:26:08 pm »
You can open them with Photoshop as well but it's not really editable anymore.
  • Last login:September 10, 2026, 06:32:31 pm
« Reply #3 on: September 09, 2009, 10:17:38 pm »
Corel Draw can import and modify illustrator files, you may be able to come by that more cheaply.
Ryglore
    • The Brush Wizard
« Reply #4 on: September 09, 2009, 11:00:32 pm »
ya actually the file you are opening in Photoshop of the .ai file is a pdf copy of the file.
Epyx
  • "You're an oddity"
« Reply #5 on: September 09, 2009, 11:04:35 pm »
@Syph007
You have a few options. I open .AI files in the free program Inkscape
You can do this one of two ways:
1)  Use a translator program to convert the .AI file into .SVG
http://sk1project.org/modules.php?name=Products&product=uniconvertor
or
2) Install plugins for Inkscape to open .AI files.
Other utilities to accomplish this:
http://wiki.inkscape.org/wiki/index.php/Tools#ai2svg.py
NOTE: These aren't perfect but its worked for me to open at least a dozen or so arcade files (marquees etc) with no issues in Inkscape.
Last Project
Epyx Tutorials:
Tutorials
Blanka
« Reply #6 on: September 10, 2009, 04:44:20 am »
I have to say that .AI is not .AI!
There's a zillion versions of .AI. If I would put .AI on the web, I would either do it as version 8 or lower of .AI (about the last real AI version) or as editable PDF (currect style AI) with PDF extension.
AI version 8 can be read by many vector packages like Inkscape, Freehand, CorelDRAW. Editable PDF as well, but it might loose layer-information.
If you have a modern AI that does not open, try renaming it as PDF, as that is actually what it is.
« Last Edit: September 10, 2009, 04:45:59 am by Blanka »
syph007
« Reply #7 on: September 11, 2009, 09:21:37 am »
Thanks for the help guys.  So far I'm finding inkscape pretty good to use.  And ive used that python script to convert ai files to svg.  So far so good.
Epyx
« Reply #8 on: September 11, 2009, 11:46:53 am »
Ya that has worked for me so far as well...im a total newb to vector based programs but so far so good.
Last Project
Epyx Tutorials:
Tutorials
syph007
« Reply #9 on: September 11, 2009, 12:42:37 pm »
Im not a computer newb, but a total artwork newb.  All I'm trying to do at this point is design my CP layout for a drilling template, then art comes after.  I got the shapes i wanted at the right scale, but now when i hit print only 1 page is printed, its to teh right scale, but i just get one corner of the CP being printed.  I expected it would have all been sent to the printer and Id have to tape it together.  Am I missing something stupid?
Epyx
« Reply #10 on: September 11, 2009, 01:28:07 pm »
Likewise...im an IT guy but most of any artwork I have done has been photoshopped (although would probably qualify as chopped hehe).
As for printing depends on the program...but you likely have it set in page setup to just print 1 page.  Most programs will let you adjust the printing so you can print out in tiles/multiple pages.
Last Project
Epyx Tutorials:
Tutorials
syph007
« Reply #11 on: September 11, 2009, 03:47:08 pm »
ah I finally found a solution.  Inkscape doesnt yet support multi page print, so what I did was export to a png file and print from another application.  Now I can finally mess around with control placements and do real world tests.
syph007
« Reply #12 on: September 11, 2009, 08:12:42 pm »
cool! it works.  I was trying to do my layouts and was using existing templates I found in svg format.  Well when printed none of them were quite right.  So I decided to make my own templates with careful measurements and create an svg file for each control i have.  Here is my test with the U360 mounting plate.  Worked perfect!   I know this isnt too exciting to you guys who know how to do this, but im pretty happy I tought myself inkscape today and that it actually worked out.  I'll make my svgs available if whem Im done.  If there was an existing good u360 template, i sure couldnt find it.
solid12345
  • Last login:December 31, 2016, 04:02:25 pm
« Reply #13 on: September 11, 2009, 08:15:12 pm »
If I could make a suggestion as well
One thing about illustrator, it has not progressed much in literally the last decade, most .ai files are usually exported in at least version 9 and up if not lower. If you can find an old copy of illustrator on ebay or craigs list you are good to go. If you can't find any that route, even try calling some of your local design agencies, I know when I interned at one the owner had been in business for so long he had boxes of old versions of software just sitting there doing nothing.
syph007
« Reply #14 on: September 11, 2009, 08:20:45 pm »
Ya I think they must have mostly been from old ai versions as the converters I found had no problem converting them to svg.
