Author Topic: Laptop repair, Can this be fixed?  (Read 1679 times)
gonzo90017
« on: August 12, 2008, 02:40:39 am »
My neighbors brought me this none working laptop that was given to them.
The hard drive was removed. After looking at one of my laptops as reference it seemed to me
that when they removed the hard drive but instead of pulling it back then up,
they just pulled it up and broke the connector. Can it be fixed?
« Last Edit: August 12, 2008, 02:53:29 am by gonzo90017 »
Singapura
Re: Laptop repair, Can this be fixed?
« Reply #1 on: August 12, 2008, 04:01:13 am »
It can be fixed but you'll need someone with fine soldering skills. You could use an external hard disk if repair becomes to expensive.
gonzo90017
« Reply #2 on: August 12, 2008, 01:46:27 pm »
Can you boot up from an external hd?
« Reply #3 on: August 12, 2008, 01:56:47 pm »
That would depend on the motherboard / bios I would think.  Can you get into the bios and check boot options?
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #4 on: August 12, 2008, 01:57:01 pm »
Check your BIOS.
Curls in the squat rack !?!?!
« Reply #5 on: August 12, 2008, 02:09:19 pm »
A lot of motherboards will not boot from external even if it has that ability if it fails the POST.
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 09:34:16 am
« Reply #6 on: August 12, 2008, 10:47:24 pm »
best bet for you would be to look for the same laptop with a broken LCD (but laptop works). So you can swap your LCD into the other one. I myself still lokking for a laptop with a MOBO but the LCD is good. Mine has a broken LCD but everything works.
Free VGA Breakout Cable
gonzo90017
« Reply #7 on: August 13, 2008, 02:47:07 am »
Guess I was wrong. Seems I need this Hard drive caddy. Does anyone know if I purchase the caddy if all I need is a regular laptop hard drive?
