Author Topic: Project64/MameWah Help  (Read 7493 times)
jardine
  • Last login:May 12, 2025, 05:09:12 am
« on: July 04, 2008, 03:50:33 am »
Hey guys,
Would realy like some help on getting this going. Searched the threads for some time but can't seem to find a good walkthrough for a dill like me. If there is one just point me to it and i'll follow it.
Meantime, can i ak a few questions please. (gonna anyway...i'll presume someone said yes)
1)...what is a wrapper and do i need it. Some threads say yes and others say no
2)..my .ini file i downloaded is way different to this one (see mine attached) http://forum.arcadecontrols.com/index.php?topic=46294.0  is it updated and confusing for a reason? What do i need to chage outta all this.
3)..and where do i actually put all the files i downloaded ie: project64_v_1.6_esc, PJ64_RDB&GameFAQ_v16016, cpv2.rar These i got from either the offical Project 64 site or CPViewer...and lastley (i think)
4)..how do i get mamewah to talk to project 64?
Thanx for helping me out....this is all still very new to me  (as im sure my posts prove) but any help is greatly appreciated.  ;D
« Last Edit: July 04, 2008, 06:07:54 am by jardine »
gonzo90017
Re: Project64/MameWah Help
« Reply #1 on: July 04, 2008, 04:13:17 pm »
This is what your ini file should look like. Just modify it to reflect your paths.
Code: [Select]
### n64.ini (mamewah v1.62) ###
emulator_title                            Nintendo 64
### List Generation Settings ###
rom_path                                  C:\juegos\n64\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      C:\juegos\n64\Project64Wrapper.exe "[rompath]\[name].[romext]"{dosbox}{safelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       C:\juegos\n64\snaps
movie_preview_path                        C:\juegos\n64\videos
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file                          auto
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               0
select_random_game                        0
saver_type                                saver_commandline
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
You also have to edit the file Project64Wrapper.cfg with your paths. In my case:
Code: [Select]
*** Do not remove these lines preceeded with ***
*** Full Path to Project64 Installation Folder ***
C:\juegos\n64
*** Full Path to Project64 Executable ***
C:\juegos\n64\project64.exe
You have to put all your downloaded files in the same folder as Project 64.
jardine
« Reply #2 on: July 04, 2008, 08:28:53 pm »
Cheers...will give it a go thank you...the Project 64 folder can be anywhere, yes...so how does it generate through mamewah...i'm missing something here.
And as for the wrapper...does this act as the application to launch project 64?
gonzo90017
« Reply #3 on: July 04, 2008, 10:05:08 pm »
I have no idea what you're asking here. Maybe you're asking how it generates the gamelist?
Code: [Select]
rom_path (empty) the full path of the location to your rom files
rom_extension zip the file extension(s) that your roms use
list_generation_method rom_folder_vs_listxml (rom_folder / rom_folder_subfolders / dat_file / rom_folder_vs_dat_file / rom_folder_vs_listinfo / verifysets_vs_listinfo / rom_folder_vs_listxml / verifysets_vs_listxml), how Mamewah generates its game list
This page can explain it better than I can http://wiki.arcadecontrols.com/wiki/Mamewah_Ini#General_about_mamewah_ini.5Ccfg_files
If you don't understand something just ask.  :)
Yes.
jardine
« Reply #4 on: July 06, 2008, 07:32:34 am »
Code: [Select]
Thanx Gonz...guess what i was trying to say was how, when i load mamewah does project 64 show up? Do i change one of the folders allocated as zinc/nes/fusion to N64 and use the cfg file found in this folder to point to Project64 location/roms/exe etc...?
gonzo90017
« Reply #5 on: July 06, 2008, 03:08:52 pm »
You have to modify Project64Wrapper.cfg with the location of project 64 emulator.
Code: [Select]
C:\juegos\n64
Then with the ini file you have to put the paths to your snaps, videos, roms, and project64wrapper.exe
Code: [Select]
rom_extension                             zip
dat_file
nms_file
catver_ini_file
movie_artwork_no                          1
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline
music_path
current_list                              0
Code:
C:\juegos\n64
jardine
« Reply #6 on: July 07, 2008, 07:14:00 pm »
Thank you..been sick so wil give it a go today and see what happens... :applaud:
jardine
« Reply #7 on: July 08, 2008, 03:58:22 am »
Gonzo..thank you..all seems ok..on the surface!!!
Set up and did cgf file...loaded some games and thought i'd give it a try. Mamewah found list and geneated it fine.
However when i load a game nothing happens?? Could this be a problem with my cfg file??
Message in mamewah says {flags=210} after it tries to launch..mean anything to you?
I'm guessing that all my command lines are correct otherwise it wouldn't have generated a list at all.
Thoughts anyone?
gonzo90017
« Reply #8 on: July 08, 2008, 11:33:38 am »
Post your ini file and Mamewah.log
jardine
« Reply #9 on: July 09, 2008, 05:12:38 am »
ok...here you go...no doubt its something easy that i have missed. After staring at thr same thing for so long you kinda go blind.
MAMEWAH FIRST:
7/8/2008 5:55:14 PM MAMEWAH v1.62 launched
7/8/2008 5:55:14 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
7/8/2008 5:55:14 PM Desktop colour: 9981440
7/8/2008 5:55:14 PM Wallpaper filename: C:\Documents and Settings\Jarrod\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
7/8/2008 5:55:14 PM Desktop display mode: 800x600 @ 60Hz, 16bit colour
7/8/2008 5:55:14 PM Decimal symbol: '.'
7/8/2008 5:55:14 PM Games list read: N64-0.lst
7/8/2008 5:55:15 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/8/2008 5:55:15 PM Layout selected: C:\mamewah\config\layout.lay
7/8/2008 5:55:15 PM No. joystick devices attached: 0
7/8/2008 5:55:15 PM Ctrlr file selected: C:\mamewah\config\mamewah.cfg
7/8/2008 5:55:15 PM Keyboard enabled
7/8/2008 5:55:25 PM Games list read: winuae-1.lst
7/8/2008 5:55:31 PM Games list read: mame-1.lst
7/8/2008 5:55:33 PM Current drive/directory selected: C:\Mame
7/8/2008 5:55:33 PM Commandline run: C:\Mame\mame.exe wboy {flags=201}
7/8/2008 5:55:37 PM Application quit: C:\Mame\mame.exe wboy
7/8/2008 5:55:38 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/8/2008 5:55:39 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/8/2008 5:55:41 PM Mode 800 x 600 @ 60Hz, 16bit colour selected after 1 attempt(s) at 1/2 second intervals.
7/8/2008 5:55:41 PM MAMEWAH quit
7/8/2008 7:49:36 PM MAMEWAH v1.62 launched
7/8/2008 7:49:36 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
7/8/2008 7:49:36 PM Desktop colour: 9981440
7/8/2008 7:49:36 PM Wallpaper filename: C:\Documents and Settings\Jarrod\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
7/8/2008 7:49:36 PM Desktop display mode: 800x600 @ 60Hz, 16bit colour
7/8/2008 7:49:36 PM Decimal symbol: '.'
7/8/2008 7:49:36 PM Games list read: mame-1.lst
7/8/2008 7:49:37 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/8/2008 7:49:37 PM Layout selected: C:\mamewah\config\layout.lay
7/8/2008 7:49:37 PM No. joystick devices attached: 0
7/8/2008 7:49:37 PM Ctrlr file selected: C:\mamewah\config\mamewah.cfg
7/8/2008 7:49:37 PM Keyboard enabled
7/8/2008 7:49:43 PM Current drive/directory selected: C:\Mame
7/8/2008 7:49:43 PM Commandline run: C:\Mame\mame.exe wboy {flags=201}
7/8/2008 8:13:59 PM Application quit: C:\Mame\mame.exe wboy
7/8/2008 8:13:59 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/8/2008 8:14:00 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/8/2008 8:14:03 PM Mode 800 x 600 @ 60Hz, 16bit colour selected after 1 attempt(s) at 1/2 second intervals.
7/8/2008 8:14:03 PM MAMEWAH quit
.INI NEXT:
### N64.ini (mamewah v1.62) ###
rom_path                                  C:\Mame\roms\N64
rom_extension                             zip
dat_file
nms_file
catver_ini_file
emulator_commandline                      C:\Program Files\Project64 1.6\Project64Wrapper.exe "[rompath]\[name].[romext]" -{dosbox}{safelaunch}
artwork_image_paths                       [emuexepath]\snap
movie_preview_path                        [emuexepath]\previews
movie_artwork_no                          1
enable_fuzzy_search                       1
history_dat_file
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
music_path
current_list                              0
AND MY N64 CGF:
C:\Program Files\Project64 1.6\project64.exe
Ok, a couple of quick things to double check on.....i removed the 1.6 bit in my program files line section...remember a while back setting up mamewah it didn't like that sort of thing with dots...still no luck. Also, the N64.ini is located WITHIN mamewah, C:\mamewah\cfg\p64  is this right?
Hope this sheds some light...thanx for the help again... :)
gonzo90017
« Reply #10 on: July 09, 2008, 11:34:38 am »
The ini files for any emulator should be inside the Mamewah\config\  folder.
Also remove the "-" in front of {dosbox}:
Code: [Select]
jardine
« Reply #11 on: July 09, 2008, 06:52:19 pm »
Will try it tonight (my time)...thanks again for all the help gonzo....hope this fixes the problem!!
jardine
« Reply #12 on: July 10, 2008, 02:56:23 am »
no good gonzo...didn't launch with that small alteration... :badmood:  :banghead: :banghead: :banghead: :banghead: :banghead:
wonder what else to do...if you give up so do i...... :dunno
gonzo90017
« Reply #13 on: July 10, 2008, 03:12:44 am »
Well there's a Mamewah package i've been working on that comes with most of the popular emus setup and ready to go. You can download it here. http://www.marcianitos.org/foro/showthread.php?t=10321
All you have to do is unzip inside your C:\ drive and put all the roms, snaps, and videos in their corresponding folders.
