Author Topic: Point Blank in MAME  (Read 7593 times)
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Point Blank in MAME
« on: March 19, 2008, 05:55:15 pm »
Anyone know how to change the number of lives you get in Point Blank in MAME? By default you only get 1 and it's a pain when all the others in the series (Point Blank 2, Zero Point 1+2) give you three. I know most versions I play in the arcades give you three so there must be a way to change it, but you can't do it with the dip switches in MAME.
Anyone? ???
Ummon
  • Trade Count: (+13)
Re: Point Blank in MAME
« Reply #1 on: March 19, 2008, 06:55:54 pm »
Does it have a service menu toggle?
Yo. Chocolate.
Stephen Hawking
Turnarcades
    • Turnarcades
« Reply #2 on: March 20, 2008, 10:34:06 am »
Nope.
Turnarcades
    • Turnarcades
« Reply #3 on: March 20, 2008, 10:37:39 am »
No worries - found it!
Turnarcades
    • Turnarcades
« Reply #4 on: September 04, 2008, 03:09:57 pm »
I've lost it again, so I'm resurrecting this thread. Anyone know how to do this?
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 08:18:16 am
« Reply #5 on: September 04, 2008, 09:27:15 pm »
try
TAB DIP SETTINGS
or
F2
Free VGA Breakout Cable
Turnarcades
    • Turnarcades
« Reply #6 on: September 23, 2008, 08:43:15 pm »
No, for some reason F2 does not access anything in this game. You can access the dip settings but all the dip does is open a test screen (test buttons, coin counter). In Point Blank 2 you press F2 to call up the full config menu where you can set coinage and free play as well as lives.
I've found this once before so why can'rt I find it again?!!!   :angry:
Can't anyone out there running light guns (or not), just quickly boot this game and press everything they can think of? I've tried to no avail.
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
« Reply #7 on: September 23, 2008, 08:55:26 pm »
Once you get into Service Mode, you use the '9' key (in most games, this is the service key) to jump to the next adjustment/test screen.  "1" (1P Start) is used to select an item to change on that screen while "2" (2P Start) will allow you to change that item you've selected.
Turnarcades
    • Turnarcades
« Reply #8 on: September 23, 2008, 09:37:13 pm »
THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!THANKYOU!
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« Reply #9 on: January 05, 2014, 03:26:18 am »
Any idea how to get point blank to save high scores ?
I think its something to do with the "Initialize highscores" setting in the service menu set to "no", Ive tried changing it to yes but it doesn't stick.
EMDB
  • Project RetroCade
« Reply #10 on: January 05, 2014, 06:11:04 pm »
Are you using a 'highscore patched' version of MAME?
Connorsdad
« Reply #11 on: January 06, 2014, 02:09:52 pm »
Yes, everything else saves the scores fine.
