Author Topic: Doom Original  (Read 1894 times)
SithMaster
Doom Original
« on: September 21, 2006, 10:56:40 pm »
im looking for the original set and im wondering how many floppies it came on.    i have the collector's edition but i runs not as well as i would have thought on my 2.7 ghz pc with xp.  the spectres are pink and white and a little blue and theres a pinkish border flashing around the game screen.  so ill kick it up old school so my laptop can play it.
so anyone know how many discs?
NightGod
Re: Doom Original
« Reply #1 on: September 21, 2006, 11:46:38 pm »
You using DOSBox to run that on your XP machine? If not, you should be, would probably fix the problems.
And I think the easiest way to get it to your laptop would be a) network or b) use WinZip's disk spanning feature to copy it to floppy.
Thenasty
  • Trade Count: (+17)
  • Last login:September 24, 2026, 01:17:38 pm
Re: Doom Original
« Reply #2 on: September 22, 2006, 06:17:01 pm »
Original DOOM I believe was 3 disk and DOOM 2 was 5 disk.
Free VGA Breakout Cable
SithMaster
Re: Doom Original
« Reply #3 on: September 22, 2006, 08:01:07 pm »
@nightGod now i mean the collector's edition designed to run in 95 has problems in xp.  its not the dos version but a remade one.  unless you mean instead of using the built in 95 launcher it came with then i will try that.
@thenasty ahh thanks.
was wondering since i want the orig floppy version for the hell of it.  and yes pun intended.
