Author Topic: Some days it isn  (Read 2250 times)
Bones
  • [Moderator]
Some days it isn
« on: May 31, 2005, 10:30:42 pm »
Breaky and a cup of green tea out of the way it was time to go to work. Jumped in my freezing cold kombi and started it. Moved
tommy
Re: Some days it isn
« Reply #1 on: June 01, 2005, 09:53:03 am »
Thats funny, whats even more funny is that you took a picture of "that thing" being towed.  ;D
On a side note "that thing" would make a nice Mame cab.  :D
« Reply #2 on: June 01, 2005, 09:56:43 am »
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 12:40:30 pm
« Reply #3 on: June 01, 2005, 10:05:02 am »
just call in sick. If they ask you whats wrong, you just tell them that you are SICK of WORKING   ;D
Free VGA Breakout Cable
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
« Reply #4 on: June 01, 2005, 10:12:28 am »
Normally you have either points OR an electronic ignition. (The do the same job, break the circuit on the coil so that the spark goes to the plug.) Do you have points with an electronic spark advance?
     Most older cars that had points also had mechanical spark advance rather than electronic.
Later
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
Stingray
Re: Some days it isn?t worth getting out of bed.
« Reply #5 on: June 01, 2005, 11:04:27 am »
Sounds like he's recently replaced his points ignition with an electronic ignition. I had a similar problem with a car burning points about once per month. Turned out the distrubutor shaft was slightly bent, causing it to spin out of true.
-S
btoddkelley
« Reply #6 on: June 01, 2005, 01:33:05 pm »
Ahhh, that would explain it. I would think that a bent shaft on a distributor would make it hard to set the dwell.
Todd
- Descartes
Bones
  • [Moderator]
« Reply #7 on: June 02, 2005, 03:02:42 am »
Yeah originally had points but I replaced them with electronics a few months ago. Now I have points again....
My shaft may have a slight bend but it still functions normally so there is no point dwelling on this.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #8 on: June 02, 2005, 08:58:40 am »
LOL! Best pun I've heard all week!
« Reply #9 on: June 02, 2005, 09:09:24 am »
That's not what your wife says, bro.
Zakk
  • Last login:June 21, 2026, 11:29:31 am
« Reply #10 on: June 02, 2005, 09:59:18 am »
And here I was thinking that Chad didn't have a sense of humour!!!  ;D
danny_galaga
  • Last login:Yesterday at 07:35:46 am
    • dans cocktail lounge
« Reply #11 on: June 02, 2005, 09:10:13 pm »
at least youll always have those pictures of the backpacking girlies to treasure forever, long after the combi is gone (",)
Bones
  • [Moderator]
« Reply #12 on: June 03, 2005, 04:02:04 am »
Ahhh yes... How could I ever be mad at my Kombi after being responsible for such a proud leg spread!  :P
Stingray
« Reply #13 on: June 03, 2005, 10:06:32 am »
You Aussies have all the fun. :)
-S
