Author Topic: Yet another ArcadeVGA problem  (Read 3640 times)
Hoopstar
  • Last login:June 12, 2004, 11:35:59 am
    • Hoopstars Garage
« on: June 11, 2004, 08:46:19 am »
OS: XP Pro
Monitor: Sony 21" G520
Card: ArcadeVGA
When computer boots the screen is black and the computer just keeps rebooting - there is nothing on screen, just a black.  I have actaully done a clean fresh install of XP with another card and then tried swapping in the AVGA without any luck...  I get no BOIS, no posting screen nothing.. but the computer seems to be going through the complete boot as I hear the Windows welcome tune.. I've tried this on two completely different motherboard/cpu/memory/hdd combos with exactly the same result
Please help me.. :(
krick
  • Gotta have blue hair.
Re:Yet another ArcadeVGA problem
« Reply #1 on: June 11, 2004, 09:58:37 am »
Boot into safe mode and install the ArcadeVGA drivers.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Hoopstar
    • Hoopstars Garage
« Reply #2 on: June 11, 2004, 10:01:39 am »
How when I can't see a thing that is going on..??  Should I do this with the "old" video card installed, shut down and then put the AVGA card in..
krick
« Reply #3 on: June 11, 2004, 11:30:40 am »
I haven't actually had to do this myself (I don't use windows XP) but I believe that when you boot in safe mode you will get a picture.
If not, you can try booting into safe mode with the "old" card installed and installing the drivers.  I'm not sure if this will work, however.
Just checking....  Do you have your arcade monitor connected to the lower connector on the ArdadeVGA card?
You might want to post in the Ultimarc forums as someone there might have already solved this problem...
http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=ultimarc
Hantarex Polo 15KHz
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #4 on: June 11, 2004, 12:01:46 pm »
That is a computer monitor. You need to hook up the arcadevga to a arcade monitor to install.
After you get that running, then you can connect a pc monitor to the secondary port.
Later,
dabone
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 10:09:41 am
« Reply #5 on: June 11, 2004, 12:34:49 pm »
I don't think SONY make Arcade Monitors so, this must be a PC monitor.
ArcadeVga are only for Arcade Monitors not for PC monitors.
Free VGA Breakout Cable
Hoopstar
    • Hoopstars Garage
« Reply #6 on: June 11, 2004, 10:11:31 pm »
Ahh... that'd be it then cause the Sony is a PC monitor only...
So can I use the S-video port to set up at this stage or do I have to use the RGB => SCART setup from the start (ie. from installation)
krick
« Reply #7 on: June 12, 2004, 07:31:17 pm »
I don't think the S-Video port shows anything until the Windows drivers load.
Hantarex Polo 15KHz
seibu
  • Last login:March 28, 2007, 12:55:34 pm
« Reply #8 on: June 14, 2004, 05:12:10 am »
It sounds like the BIOS is failing the monitor test, because you're trying to drive a VGA monitor at 15Khz! You need an arcade monitor or a SCART TV to view anything from the Arcade VGA.
When you have one of these, wire it up and try again.
Nath
  • Newbie
  • Last login:May 01, 2004, 06:36:26 am
« Reply #9 on: June 19, 2004, 05:38:41 pm »
I belive you will get some sort of a picture from the AVGA on a pc monitor, it wont be readable tho ...
I just bought an AVGA of my own, and have this exact same problem, i have a D9200 and get no picture what so ever. I belive  there may be been a bad bactch of cards released
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« Reply #10 on: June 19, 2004, 09:24:52 pm »
More modern PC montiors don't show a picture when the signal is out of range.  This may be the black screen problem you are having?
Continual reboot sounds like default "incorrect" drivers installed by XP is causing a blue screen.
Easiest way I found to get the AVGA card happening on XP was:
- Get an old PCI based card.  I used a old S3 card with about 2mb of RAM.... 7 or so years old.
- Place it in the PC.... do not install the AVGA card yet.  Set the BIOS to use the PCI video card as the primary.
- Build XP with a normal monitor, as you are using a PC based card.
-  Apon completion, shut down and install the AVGA in the AGP slot.
-  Boot into Safe Mode.... F8 like mad after BIOS init screens to access the Safe Mode menu option.
- Cancel XP's "found new hardware wizard"... and install the drivers from the CD.
- Reboot the PC, and go to the BIOS.  Set AGP to the primary video card slot.  Save the BIOS, exist, and and shutdown the PC.
- Removed the PCI card.
- Reboot and whammo... all is done and should be working correctly.
EDIT:Typo
« Last Edit: June 20, 2004, 09:01:56 am by wonderboy »
libref
  • Last login:November 14, 2017, 08:26:56 am
« Reply #11 on: June 19, 2004, 10:47:27 pm »
Hi all,
I've seen this problem posted a few times on BYAOC and the Ultimarc site... Wonderboy and krick have it right. Here's a section of the AVGA installation page from the Ultimarc site (http://www.ultimarc.com/avgainst.html):
"Blue screens and re-booting in XP after plugging in the card:
XP is trying to use it's built-in ATI driver. Either re-start in safe mode and then install the ArcadeVGA drivers OR delete the file ATIMTAG.SYS in the Windows/System32/drivers folder. Then install the ArcadeVGA drivers."
Let us know if this fixes your problems Hoopstar & Nath.
StephenH
« Reply #12 on: June 24, 2004, 04:11:43 am »
Reboot in safe mode, and try to install the arcadeVGA drivers.  Windows could be trying to use the stock ATI drivers.
Additionally, reboots and unexpected shutdowns shortly after startup can also be a sign that your computer is infected with the Sasser worm, especially if you did not install the KB835732 security patch yet.  You can get this patch from WindowsUpdate.microsoft.com, and the removal Tool from Microsoft.com, Symantec.com, and McAfee.com.
vader
  • Last login:December 27, 2025, 08:14:42 pm
  • I can't breathe in this thing !!
Re: Yet another ArcadeVGA problem RIDICULOUS
« Reply #13 on: March 03, 2005, 10:27:21 pm »
THIS SUCKS.....
Total install......drivers load fine.....reboot reboot again and again.......
What the hell am I doing wrong
Will
  • Last login:April 08, 2012, 03:32:27 am
  • Finished Lurking.....
« Reply #14 on: March 03, 2005, 11:15:37 pm »
Just to make this perfectly clear as dabone said you cannot display a arcade vga card on a normal pc monitor.I have tried it you will get no picture.
« Last Edit: March 04, 2005, 02:14:23 am by Will »
vader
« Reply #15 on: March 04, 2005, 09:17:14 am »
LOL....didn't even notice ....I posted on the wrong thread....see what happens when you stay up to late.....I'm all good now....
Tim
