Author Topic: PortaMAME - Arcade in a Briefcase  (Read 31545 times)
adrktemplar
  • Last login:June 26, 2016, 03:27:10 am
« on: December 22, 2014, 04:27:35 am »
Hi everyone.
First post and first project as well. Stumbled upon this forum back in November (2014) when I was searching for materials for my build and been a regular visitor since then. I'm astonished at the wealth of information and level of knowledge sharing in these forums!  :applaud:
I named the project, PortaMAME. First name I thought was PortaCade but there's already a traffic barricade brand that uses the trademark so I settled with PortaMAME.
Project Name: PortaMAME - Arcade in a Briefcase
Background:
I first got the idea of building an arcade machine when I got an Injustice fight stick on sale and saw in the interwebs that a Raspberry Pi can power an arcade machine. For the proof of concept, I installed EmulationStation on the Pi and had the fight stick detected and I was playing some MAME games immediately.
I started planning and getting parts for integrating the Raspberry Pi into the fight stick when I saw Rasmus' and this website. I thought that even if I get the Pi and fight stick contraption, it would have to be connected to a TV/display when playing. Inspired by how folks here are building full size cabinets, bartops, etc., I decided to go all the way! I shelved the Pi and fight stick project and decided to build a machine powered by Windows instead.
I have never built an arcade machine before or any other similar furniture/machine/equipment. The closest experience I could relate to is scale modeling which I have not done in the last 6 years! My cost/benefit analysis convinced me that from the nostalgia value alone, this project is really worth investing time and money. Plus, it's a good way to put into use my recently acquired small set of power tools and a good excuse to acquire more tools as I build the machine.
Objective:
Since we're only staying in one-bedroom apartment where we have limited space, building a full size cabinet is simply not an option. A bartop seemed to be the perfect solution, however, once built, it would still be a challenge stowing away the machine when not in use. That's when I thought of building an arcade in a briefcase.
Requirements:
A. Must-haves
- Must be portable
- Must be compact and have a small footprint
- Must have compartment for power cord, extension cable (optional), joystick handles, small keyboard, mouse (optional)
- Must have 15" or larger display and full sound for the best arcade experience
B. Good-to-haves
- 2-player button layout
- ports for USB, LAN, earphones, etc.
- lit marquee
- lit buttons
CP Layout:
Since the case is black I decided to keep it consistent and went with a black theme. I thought of making the panel look more like a high-tech scientific equipment rather than an arcade machine.  :D
I considered getting a yellow version of the case and have a Pac-man theme for the control panel. However, since there isn't a space for the marquee, I felt that it won't be complete so I went the black theme route.
Here's the CP art. Too bad the reproduction didn't turn out as I imagined it here. The dark areas on the corners were printed as plain black areas losing the carbon fiber pattern detail. :(
Challenges:
I thought that since I didn't have to start with building a case from scratch, the build would be easier and will have few challenges. I was wrong. Due to the fact that I don't have a custom case made for the components but rather starting off with a pre-made case, fitting and mounting the components is more challenging! Below are the challenges and lessons learned along the way.
Challenge #1: Choosing the best briefcase for the project - SOLVED!
I first thought of using an aluminum briefcase as this is what's commonly used today for transporting hobby kits, photography equipment, etc. However, I saw reviews that said these cases are thin, flimsy and not rigid enough for my needs. I want the machine I'm building to last for a long time as I'll be putting so much time, effort and money in the build.
In my search, I came across the Pelican cases. While it seemed to be the best case for the job as reviews say that the material is sturdy and durable, I feel it's too expensive. In my search for a cheaper alternative, I came across the Seahorse brand of cases which uses the same material as the Pelican but is cheaper. Both Pelican and Seahorse cases' lid fully opens to slightly over 90 degrees (approx. 110 degrees) which provides good viewing angle compared to regular briefcases which only opens up to 90 degrees max.
In addition, the Seahorse cases accommodates for custom panels as the sides of both the lid and bottom compartments already has screw holes to mount the panels! Not to mention that it's also waterproof as the Pelican cases. I don't intend to test if they're really waterproof but it's good to know that once built, my machine has some level of protection from water leaking in.
Challenge #2: Getting the correct dimensions to get the panels fit - SOLVED!
Unlike regular briefcases and aluminum cases, the Seahorse case's edge isn't straight and has sharp corners. Instead, the corners are curved and the sides also has slight curves. I thought that it would be challenge getting the proper dimensions.
It's a good thing that the folks at Fuerte Cases where I ordered the case are very accommodating and they provided me paper templates of both the bottom and lid when I requested for one. The templates even have the screw holes already marked! Thanks Fuerte Cases! One challenge easily solved.
Challenge #3: Choosing the motherboard, power supply, speakers and other components - SOLVED
Motherboard and PSU
If I settled on my initial hardware specs of using a Raspberry Pi to power this machine, I won't probably have challenge no. 3 as the Pi is so tiny and would only take a very small amount of space. However, I wanted the machine to have more processing power so I settled to using Windows instead. I thought of using a netbook but the motherboard would occupy a wide area. My next option is a mini-ITX desktop board -- more compact but takes more vertical space than a laptop motherboard. Since I went the mini-ITX route, I used a mini PSU rather than a full desktop PSU.
Here's how the components look so far... I'm yet to trim down and tidy up the wires.
Push Buttons
Choosing the buttons is also critical. I definitely cannot use the Happ-type buttons as it's too tall for this build I wanted the scew-on buttons but the shortest is still too tall for this build. In the end, I settled for the Seimitsu PS-15 Low Profile buttons.
For the admin buttons, I chose the small push buttons so I can fit at least three (3) without taking so much CP real estate.
Here's how the CP panel looks underneath. I'm still yet to trim and tidy up the wirings.
Encoder
For the encoder, I used the Xin Mo 2-Player USB encoder. Initial testing with the Xin Mo encoder showed no lag whatsoever. I tested on Galaxian and Terra Cresta and I find it very responsive.
Here's how it looks like with the CP on top of the components. Really cramped! As you might noticed, instead of using PCB mounting feet which I find is still too high, I used Perler Beads which quite works well and with really low footprint.
Speakers
In choosing the speakers for the audio, I opted for USB-powered speakers. I thought that doing so will spare me the headache of finding for a small speaker that would fit and small amplifier to go with it. I saw Rasmus use a Logitech z110, which I find has ample sound power. It has good mids and highs but not too much bass. Still, it's a better speaker compared to other small speakers that I tried and owned.
Rasmus' bartop has enough space to fit the z110 with the original housing -- he simply epoxied the speakers to his bartop. However, since I have very limited space, I had to take out the speakers out of the housing. Searched the net and I didn't find anybody who has disassembled the z110.
For lack of visible screws and openings on how to disassemble the speakers, I used a Dremel cutting bit to and drilled a small hole so I can peek at the insides before I continue drilling and cutting the housing. I drilled two (2) holes first -- one where I can peek inside while the other, for inserting through a small LED. After determining the "safe zone" for cutting, I cut the housing around the sides and successfully extracted the speakers and tiny amplifier.
Challenge #4: Fitting and mounting the components and buttons with limited vertical space - PARTIALLY SOLVED
Since I wanted not to damage the Seahorse case, I thought of using a thin plywood to act as base for screwing in the components on the bottom compartment. I will further secure and attach with Velcro underneath.
Here's how the base looked like initially without the components. It appears spacious but quickly got crowded when I started putting in each components.
With the back panel and CP cover visible...
Back Panel
As I wanted the setup to be upgradeable as possible, and I figured that I would be tweaking the system often, I decided to make the back panel complete with all the necessary ports as any desktop computer would have.
Below is the back panel planned using Sketchup.
Sketchup template printed for cutting the holes into the plywood.
Here's how the back panel looks so far... Next is sanding/finishing, priming and I'll have it painted black as well.
Challenge #5: Closing the lid when the bottom compartment has joysticks sticking out - SOLVED
Perhaps anyone trying to build an arcade using a briefcase as the housing will come across the challenge of the joystick stabbing display/lid when closed.
Good thing I discovered early on about The Link from Phreak Mods. A bit pricey if you ask me but it does the job well. You won't feel any difference from the stock shaft. I used the JLF version (The Link comes with a Seimitsu version too). The stock dust cover and shaft cover won't fit in the link though so I had to sand the stock JLF dust covers.
Joystick handles attached...
Joystick handles removed...
Handles stowed in the compartment...
Test if the briefcase can be shut with the panels attached...
It does!
Challenge #6: Mounting the display - IN PROGRESS
Challenge #7: Getting the VGA, power and audio cables into the display/lid - PARTIALLY SOLVED
More details to follow.
« Last Edit: December 26, 2014, 04:55:23 am by adrktemplar »
Sjaak
  • Last login:June 02, 2026, 09:19:06 am
Re: PortaMAME - Arcade in a Briefcase
« Reply #1 on: December 22, 2014, 04:31:14 am »
Nice job, looks fantastic!
« Last Edit: December 22, 2014, 05:33:42 am by Sjaak »
adrktemplar
« Reply #2 on: December 22, 2014, 04:56:54 am »
*post no longer needed*
« Last Edit: December 22, 2014, 05:17:29 am by adrktemplar »
Louis Tully
« Reply #3 on: December 22, 2014, 05:38:11 am »
« Last Edit: February 12, 2015, 06:39:54 pm by Louis Tully »
menace
« Reply #4 on: December 22, 2014, 08:21:53 am »
Nice--more details on the joystick mounting please!  Are they spring loaded clips, screw on (although I don't see threads).  How do they feel when attached?
« Reply #5 on: December 22, 2014, 08:44:19 am »
in addition to the concept, I love the clean look and lines of the artwork.
  • Last login:Today at 11:31:10 am
« Reply #6 on: December 22, 2014, 10:14:48 am »
Looks like "The Link".
There was The Link.
« Reply #7 on: December 22, 2014, 11:43:48 am »
Nice build!  Any plans on a bezel for the top portion to cover things up?  I would consider getting some Lexan (more durable than Plexi and less likely to crack), cutting it to size, spray painting the back and mounting it with long screws to the wood pieces using homemade stand-offs (use the plastic tube from a BIC pen cut to size).
This gives the bezel a nice shiny look to match the control panel.
DeLuSioNaL29
« Last Edit: December 22, 2014, 12:33:51 pm by DeLuSioNal29 »
rablack97
« Reply #8 on: December 22, 2014, 11:53:45 am »
He put the pics out of order....you missed it here.
adrktemplar
« Reply #9 on: December 22, 2014, 11:57:29 am »
Fantastic project. I was just talking with someone at work about trying to shoehorn an arcade into an SKB case or something.
The SKB case should also work. The only advantage of the Seahorse case is that has provisions for mounting custom panels. I think the designers created the Seahorse cases with custom panels in mind on the get go. Unlike the Pelican and SKB, you have to purchase the mounting joints separately and has to be screwed to the case, making the case loose that waterproof ability.
I used Seahorse SE-710 case without the foam insert.
I was stuck on how to keep the joysticks from stabbing the monitor. Well done, man.  :applaud:
Yes it is indeed The Link. A bit pricey if you ask me but it does the job well. You won't feel any difference from the stock shaft. I used the JLF version (The Link comes with a Seimitsu version too). The stock dust cover and shaft cover won't fit in the link though.
Edit:  Link fixed by moderator (other link was dead).
« Last Edit: December 22, 2014, 12:38:15 pm by DeLuSioNal29 »
adrktemplar
« Reply #10 on: December 22, 2014, 12:01:53 pm »
I used the The Link from Phreak Mods. A bit pricey if you ask me but it does the job well. You won't feel any difference from the stock shaft. I used the JLF version (The Link comes with a Seimitsu version too). The stock dust cover and shaft cover won't fit in the link though.
« Last Edit: December 22, 2014, 12:37:59 pm by DeLuSioNal29 »
« Reply #11 on: December 22, 2014, 12:16:36 pm »
What are your plans for the monitor area?
adrktemplar
« Reply #12 on: December 22, 2014, 12:18:07 pm »
I considered getting a yellow version of the case and have a Pac-man theme for the control panel. However, since there isn't a space for the marquee, I felt the them won't be complete so I went the black them route.
adrktemplar
« Reply #13 on: December 22, 2014, 12:35:41 pm »
This give the bezel a nice shiny look to match the control panel.
DeLuSioNaL29
My plan is to spray paint the reverse side of plexi. I already marked the area to be painted. I tested the vinyl spray paint onto a scrap piece of the plexi and it appears that it's holding well.
Initially, I planned to use a 17" widescreen laptop display which is thin and very light and I mounted it in the plexi itself. However, I recently got a 17" 4:3 NEC monitor on a visit to Goodwill and decided to use it instead as it produces bigger video from an arcade game standpoint.
Since the monitor is thicker and heavier I decided to not mount it on the plexi alone. I cut a thin plywood and attach it to the lid using Velcro and hot glue to provide a base for the screws. I don't want to bore holes and damage the case.
Thanks for the Lexan and BIC standoff tips! I thought Lexan is just a brand of plexi and would consider it my later builds. I used a 0.093" thick plexi that I got from Home Depot. As for the BIC standoffs, would definitely consider it! I was actually scouring Home Depot and Radio Shack for standoffs and didn't thought of using a ball point pen shaft as substitute.
adrktemplar
« Reply #14 on: December 22, 2014, 12:44:19 pm »
Right now is mounting a piece of plywood to the lid using Velcro and hot glue the edges of the wood to reinforce the adhesion. As for the bezel, painting the reverse side with black vinyl spray paint.
The challenge I have right now is how to get the flat VGA cable pass through the bezel. I don't want to de-solder the cable as I might damage it. For now, I'm thinking of cutting a small groove to slide the cables in and then secure the groove with a screw and metal bracket.
« Reply #15 on: December 22, 2014, 01:15:44 pm »
What are your plans for joystick handle compartment? I'd assume it might scuff things up if they can sit loosely. Are you gonna make form fit slots to hold them?
adrktemplar
« Reply #16 on: December 22, 2014, 02:53:40 pm »
Agree. I plan to use a medium pouch made of cloth to put the joysticks, power cord, small keyboard and perhaps a mouse.
« Reply #17 on: December 22, 2014, 03:13:26 pm »
Good to hear. Fix that monitor area, and that thing will be aces.  :cheers:
  • Last login:Today at 10:09:02 am
« Reply #18 on: December 22, 2014, 03:56:57 pm »
This is really neat. :cheers:
mcseforsale
  • Creepy Mario Dude
« Reply #19 on: December 22, 2014, 04:35:45 pm »
Interesting.  Subscribed!
AJ
adrktemplar
« Reply #20 on: December 24, 2014, 07:33:58 pm »
Main build log updated with new pics of the following:
  • components
  • CP buttons and encoder
  • back panel
adrktemplar
« Reply #21 on: December 26, 2014, 04:45:13 am »
Managed to make some progress in the last couple of days...
Challenge #6: Mounting the display - IN PROGRESS SOLVED
But first, let's talk about the NEC LCD monitor that I used for this build and why I chose it over the 17" widescreen laptop LCD I have.
The NEC L174F4 (perhaps other models in the series as well) comes with a number of features that's great for hacking.
For one, with the "hover" control buttons, I didn't have to drill holes in the bezel to access the control buttons. Just by hovering my finger over the "button" will activate it. See it in action below.
No button lit/touched...
And here's after I "touched" a button. Notice the volume level indicator in the screen...
Second great feature of this monitor is that it has audio in and out which makes controlling the volume done thru the monitor's controls which eliminates the need for dedicated volume buttons or knob.
Audio in and out beside the power jack...
Lastly, the monitor's back has a soft blue glowing "NEC" logo when turned on -- very similar with the glowing Apple logo on Macbook lids. The soft glow is actually achieved by a "light bar". I imagine the light bar can be used to light up a small marquee but since this build didn't have room for a marquee, I ended up not using the light bar.
NEC monitor's back
the "light bar"
With all these features, I will definitely use this monitor again in future builds.
Mounting the display, inverter and controller into the case's lid
As I originally planned, I used Velcro to mount onto the case the plywood base where the LCD will be screwed. After a day of leaving the LCD/display/lid upright, the Velcro is still holding the display well. I tried detaching the plywood and even with good amount of force, I still cannot remove the plywood from the case. If I force it further, I feel that the plywood would crack. The bubble on the leveler didn't change a bit after leaving it overnight! I don't think gravity alone would be able to remove the LCD. I guess this Velcro tape can live up to its claim as being "industrial strength".  :applaud:
Next is mounting the inverter using 3M Command adhesive foam tape
To mount the display control buttons, I used a Papermate ballpoint pen barrel as standoff. Big shout out for DeLuSioNal29 for the tip!
To mount the standoff to the case, I used hot glue. As Ben Heck would say, "If Apple can [hot] glue their products, so can I!"  ;D
And here's all the display components mounted on the lid.
Below is how the "touch" buttons look like underneath the painted bezel.
Here it is in action!
Will the buttons activate?
Look mom, no holes!  ;D
I plan to add hexagonal labels to the buttons to keep with the overall theme.
It would be an eye sore if I just get the VGA, power, audio in and out cables running through the bezel so I used a flat VGA cable for the display.
For the power, audio in and out cables however, I had to fabricate a wire harness using a 14-pin ribbon cable and jumper wires. See picture below. The ribbon cable is rated for 300V so I figured that it should be able to handle the 12V power that the monitor requires.
To get the two (2) ribbon cables through the bezel, I had to make a slit where I can route the ribbon cables.
To get the other ends of the ribbon cables to the motherboard, I will have them pass underneath the plywood base thru a hole.
Here's how the ribbon cables look so far. I'm thinking of spray painting the ribbon cables black but I'm afraid that it might damage the cables and/or get scratched over time making it look worse later.
Challenge #8: Removing paint overspray from plexi/acrylic bezel - NEW / OUTSTANDING
Just when I thought I'm about to finish this build, I'm presented with a new challenge -- overspray in the bezel!
I didn't thought of adding masking tape to the backing sheet before I sprayed the black vinyl paint over the plexi glass. Bad move.  :cry: I didn't expect the paint would cause the backing sheet to react to the paint and peel off.
As a result of my stupidity -- overspray!
I'm thinking I have three (3) options:
1. Make another bezel - I don't want to go this route if I'm still able to salvage the finished one.
2. Use a solvent to remove the overspray - Since I used vinyl spray paint, I'm not sure which solvent or thinner I can use to remove the overspray. I'm also afraid that the solvent might eat the plexi causing more damage.
3. Lightly sand the overspray and polish the plexi - I think this is the safest but I'm not sure if I can polish plexi to the level that no scratches can be seen afterwards.
Any suggestions?
Anyways, here's how the PortaMAME looks so far...
« Last Edit: December 26, 2014, 12:44:39 pm by adrktemplar »
a1pharm
« Reply #22 on: December 26, 2014, 05:15:02 pm »
Overspray sucks, man.  I did the same thing on the Green Bay Bartop I built for the father-in-law.  You're right - you only have 3 options:
1. Make a new bezel (apply tape DIRECTLY to the plexi - don't put it over the top of the plastic protector)
2. Use a solvent to remove overspray (I did this with 91% Isopropyl Alcohol and Q-tips).  The "treated" area does have a slightly smoky appearance because of the solvent reacting with the plexi.  It is pretty hard to notice, especially when playing.
3. Sand the overspray.  Even if you lightly sand with 600 grit paper, you will still get micro scratching.  Perhaps flame polishing (with a small pen torch) or using a very light acetone application would reduce the appearance of scratching.
If you have any scrap left over, test your methods before working on your current bezel.  Only if you really mess it up should you just make a new bezel (you really have nothing to lose by trying to fix your current one).
Post what you end up doing so others can learn (you're not the first this has happened too...)
Cheers!
