Author Topic: U360 restrictor kit and standard dust guard.  (Read 1114 times)
dfwpiper1
  • Last login:July 08, 2015, 11:39:22 pm
    • My project
« on: October 01, 2014, 08:52:46 pm »
Unless I'm missing something glaringly obvious, I assume these two cannot be used together? I suppose the dust guard could just float on top of the restrictor halves. But that would have to be above surface. And that would just be wrong...
I guess my ultimate question is how would one using the restrictor kit bezel the hole in the control panel. Seems like you'd have an exposed (somewhat) edge.
« Last Edit: October 01, 2014, 08:57:09 pm by dfwpiper1 »
kixfan
  • Last login:May 22, 2018, 06:59:26 pm
Re: U360 restrictor kit and standard dust guard.
« Reply #1 on: October 01, 2014, 11:27:00 pm »
Yes you use them together.   The restrictor plate goes under the cp in the u360 and the dust cover floats on top of the cp.
dfwpiper1
    • My project
« Reply #2 on: October 02, 2014, 12:49:35 am »
Yeah I just checked it again. It's all flush with 3/4" wood panel. I was going to rout it to have a higher joystick but that would make the rp too high. Oh well I think I'm digging the joystick height now anyway!  ;D
kixfan
« Reply #3 on: October 02, 2014, 06:30:37 am »
I want to retract my first answer.   I now see Ultramarc makes a top mounted restrictor plate u360.   I have the original.
dkersten
« Reply #4 on: October 03, 2014, 05:40:49 pm »
the top mount restrictor itself sits above a 3/4" CP, so if you use the dust guard it will "float" a little, about 2-3mm above the CP.  I just left them off so I have easy access to the restrictors.
