Author Topic: Bending wood  (Read 6604 times)
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
Bending wood
« on: April 08, 2014, 06:37:12 am »
Woodworking noob here!!
I went ahead and had a cabinet cut at a CNC place with a curved control panel without really thinking about the fact I would have to bend some wood to achieve the sidepanelling. Does anyone have any tips for how to do this and what wood to use (the rest of the cabinet is MDF for what it's worth).
  • Last login:Today at 12:16:24 am
Re: Bending wood
« Reply #1 on: April 08, 2014, 07:21:04 am »
Pics and/or diagrams showing the radius of the curves might help here.   :dunno
A 12mm radius curve and a 120mm radius curve call for very different approaches.
Also, many people let the curved part hang out like a diving board.
« Last Edit: April 08, 2014, 07:28:41 am by PL1 »
eds1275
  • Last login:June 28, 2026, 01:02:11 pm
  • Rock and Roll!
Re: Bending wood
« Reply #2 on: April 08, 2014, 11:31:25 am »
Yeah without seeing what you're talking about it's hard to say.
s_busby_uk
Re: Bending wood
« Reply #3 on: April 08, 2014, 02:29:27 pm »
Fair enough, see attached!
The dimensions of the piece are about 684mm x 320mm (at the longest part of the curve - 223mm at the shortest part of the curve (the sides)).
Drnick
  • Last login:July 03, 2026, 01:57:35 pm
  • Plodding Through Life
Re: Bending wood
« Reply #4 on: April 08, 2014, 03:42:11 pm »
If you have a tablesaw
EightBySix
Re: Bending wood
« Reply #5 on: April 08, 2014, 04:07:59 pm »
If you don't, Google bendy mdf.
JDFan
Re: Bending wood
« Reply #6 on: April 08, 2014, 04:24:42 pm »
eds1275
  • Rock and Roll!
Re: Bending wood
« Reply #7 on: April 08, 2014, 04:28:04 pm »
A few layers of hardboard it the back and sides are good enough structurally
s_busby_uk
Re: Bending wood
« Reply #8 on: April 08, 2014, 05:19:24 pm »
This stuff looks viable
http://www.wickes.co.uk/MDF-Flexi-Board-6x607x1220mm/p/190139
Anyone know how structurally sound this stuff is though? And is it easy enough to cut length-ways to get the right height?
Re: Bending wood
« Reply #9 on: April 08, 2014, 10:09:20 pm »
You can do the front in a 1/4" piece of hardboard.  Just soak it in hot water then ratchet strap it around a bucket and let it dry.  Its a kinda fun way to do things.
s_busby_uk
Re: Bending wood
« Reply #10 on: April 09, 2014, 11:17:12 am »
Once bent, what's the best way of attaching the wood to the sides of the control panel? Is this the best method?
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=92156.0;attach=188202;image
(Credit: markc74s amazing Terminus cabinet)
Re: Bending wood
« Reply #11 on: April 09, 2014, 03:42:34 pm »
If you can hinge it in the back like the picture you posted you will save yourself a lot of headache.  I tried hinging mine in the front and ran into way too much trouble.
http://forum.arcadecontrols.com/index.php/topic,116519.msg1292849.html#msg1292849
s_busby_uk
Re: Bending wood
« Reply #12 on: April 09, 2014, 03:46:34 pm »
I like the hinges you used - what are they?
Re: Bending wood
« Reply #13 on: April 12, 2014, 06:30:45 pm »
They are called box hinges.  I picked them up here.
http://www.hardwaresource.com/index.php?l=product_detail&p=4070
It is a real nice hinge but did not end up working for me.
s_busby_uk
Re: Bending wood
« Reply #14 on: April 13, 2014, 02:39:17 pm »
No reason they shouldn't work at the back of the CP tho right?
Re: Bending wood
« Reply #15 on: April 14, 2014, 02:27:29 am »
Just make sure the joysticks don't break the bezel/monitor when you open the CP that way.   :angry:
s_busby_uk
Re: Bending wood
« Reply #16 on: April 14, 2014, 10:47:53 am »
Ha, good point!
Re: Bending wood
« Reply #17 on: April 14, 2014, 11:21:38 am »
Probably not.  Take a look at the pictures here -
http://forum.arcadecontrols.com/index.php/topic,116519.msg1295494.html#msg1295494
I had to notch the box so that the hinge would be flush with the front otherwise the lid would not clear.
