Author Topic: crt still has a faint glow when off  (Read 1953 times)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« on: August 06, 2013, 12:52:22 pm »
Ok I dont know so i am going to ask . I recently changed the picture tube on my arcade cabinet monitor. It works perfectly the chassis is a u2000. But after I turn the cabinet off the crt has a dim and very faint glow to it on the whole screen then goes away after about 20 secs. Is something I have done wrong is this a problem? The horizontal and verticle ohms are almost identical to the original tube. I only replaced the tube because it is old and weak. (no problem with glowing from the original tube.)
« Last Edit: August 06, 2013, 12:54:35 pm by adidas1984x »
Drnick
  • Plodding Through Life
Re: crt still has a faint glow when off
« Reply #1 on: August 06, 2013, 02:38:49 pm »
I am fairly sure this will be normal. some Crt's glow for longer then others but pretty much all tubes will do it. See the following.
http://www.repairfaq.org/sam/crtfaq.htm#crtagl
ed12
« Reply #2 on: August 06, 2013, 04:40:33 pm »
no thats a very normal thing
most ppl just do not see it
rember it is a crt,and it heats up
nothing to fret about
ed
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #3 on: August 06, 2013, 04:52:35 pm »
Should just be residual phosphor glow. I had a TV a few years ago that had a faint afterglow but you had to have the room dark to notice it.
