Author Topic: AimTrak Light Gun issues with video projector  (Read 5306 times)
fatsgt
  • Last login:June 29, 2015, 12:22:01 am
  • Taito Type X, I hate you.
« on: June 27, 2013, 09:36:23 am »
Just received my Aimtrak Light gun and having some issues.  I'm trying to use it with my video projector which projects about a 9 foot image.  My computer is in the back of the room with my control panel which is about 12-15 feet away from the screen. With the standard length of the USB cord for the sensor bar I can only get the sensor about 3-4 feet in front of the gun.  Obviously this isn't working and I can't even calibate the gun correctly becaulse the sensor won't pick up at the sides.  Guess I should have read a little more about the functional size of the screen before I purchased.  So now for some questions.
1. Is it possible to get the gun working in this configuration?
2. If I manage to extend USB cable and put the sensor above the projected screen area will the gun work at this 12-15 foot range?
3. Does the sensor bar need to actually be plugged into the computer with the gun or could I power the sensor bar with an external USB hub not connected to the computer?
Thanks for your input!
FatSgt
Sjaak
Re: AimTrak Light Gun issues with video projector
« Reply #1 on: June 27, 2013, 09:41:12 am »
The sensor bar is just a bunch of infrared leds, so you don't have to connect it to the computer (just power)
I think there is a test utility included in the software which shows what the camera in the gun picks up, so you could use that to see how far back you can go.
fatsgt
« Reply #2 on: June 27, 2013, 11:27:46 am »
Good info. Thanks!  Do you think this sensor may help in this situation?
http://www.arcadeguns.com/index.php?main_page=product_info&cPath=2&products_id=225
Looks like it's made just for projectors/large screens.
