Author Topic: Slow Down Issues - With Certain Games  (Read 1903 times)
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
« on: March 16, 2013, 09:31:12 am »
Again I mentioned in another post last night was the 1st time I really tried out my Cabinet with my Brother-in-law and Stepson.  For the most part the games seemed to play ok.
MK2 we played about 35 minutes
Track Field we played about 30 minutes
Shinobi we played about 20 minutes
KungFu I played about 20 minutes
And those all seemed fine But a couple games seemed to lag after a bit
Double Dragon started out fine but by the time we got to the second level...it just seemed to lag
Elevator Action 2 just seemed laggy from the get go
NBA Hangtime seemed to let us play a full game fine but midway through the second it started to lag.
Is there anything I can do about these types of issues?  I had not really noticed it until last night.
Thanks,
Rich
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 02:40:58 pm
Re: Slow Down Issues - With Certain Games
« Reply #1 on: March 16, 2013, 10:38:24 am »
Some games has slow down in the real arcade/hardware - this is emulated correctly (dunno which ones).
If said games are not those games, try lowering down the samplerate to 44khz instead of default 48khz or even lower it down to 22khz.
But then again, you might have some heat issue or underpowered machine.
Free VGA Breakout Cable
rtkiii
« Reply #2 on: March 17, 2013, 08:19:41 pm »
I know how to set those settings in mameui32 but how do you do it with mame.exe?
Thenasty
« Reply #3 on: March 18, 2013, 08:41:13 am »
edit the MAME.INI file.
rtkiii
« Reply #4 on: March 18, 2013, 01:37:11 pm »
Find the game in the list when I open the .ini in notepad?  then edit audio settings?
rtkiii
« Reply #5 on: March 18, 2013, 07:59:50 pm »
editing the mame.ini only seems to do it for all games.  I just want to change the specific games that are having issues.  Ids that possible?
rtkiii
« Reply #6 on: March 18, 2013, 08:05:21 pm »
And changing the volume does not help Elevator Action 2...just a fyi
Thenasty
« Reply #7 on: March 18, 2013, 09:53:34 pm »
dunno the exact line but something along this
GAMENAME/Samplerate 22050 or make GAMENAME.INI and change it there only.
Need to start RTM.
