Author Topic: Alchemy: Video Pinball Shmup Table  (Read 192148 times)
Drnick
  • Plodding Through Life
Re: Identity Crisis! : Morphing Pinball Shmup Table
« Reply #280 on: March 15, 2013, 04:11:29 pm »
Is it only in Hyperspin that it is doing this, or does it do it when playing the games themselves?
Are monitors 1 & 2 aligned along the top edge, Is the playfield set as Primary screen.
Are monitors 1&2 on the same card with 3 on the 2nd.
Is it all tables, and what format tables did you get,  full screen cabinet or other?
griffindodd
  • Builds Stuff
« Reply #281 on: March 15, 2013, 04:16:32 pm »
Only hyperpin. Primary is play field. Secondary aligned top with primary. Secondary to the right of primary. All three on one card as its a Kepler based GPU. If you alt tab through the windows you can see the back glass window sitting in the middle of screen 1 primary. But if you bring the window to focus it disappears
I drink and I know things.
Drnick
« Reply #282 on: March 15, 2013, 04:18:33 pm »
edited above whilst you were answering.  Which tables are you using?
griffindodd
  • Builds Stuff
« Reply #283 on: March 15, 2013, 04:21:35 pm »
The tables themselves are working in the future pinball for now, I still have some position and scaling to do but I feel confident I can work that out. For some reason Hyperpin doesn't recognize the secondary monitor properly, doing research.
Drnick
« Reply #284 on: March 15, 2013, 04:37:25 pm »
Did you change x/y for backglass image or are they set to 0,0
griffindodd
  • Builds Stuff
« Reply #285 on: March 15, 2013, 04:39:01 pm »
I think they are at 0,0
Drnick
« Reply #286 on: March 15, 2013, 04:43:17 pm »
In which case I am all outta ideas  :banghead:  I see you have posted over at Hyperpin.  Undoubtedly they will advise some of the same things I advised and then its play with different driver versions I guess.   When you fix it let us know the fix. If I ever have the cash to build one of these things I will need all the online help I can find  :laugh2: :laugh2:
Although please do try with monitors 1/2/3 all in a row like little ducks.
griffindodd
  • Builds Stuff
« Reply #287 on: March 17, 2013, 01:39:45 am »
Still fighting away with the stuff but getting closer to my goal.
The smaller monitor on the side represents the signal that will go to the side projectors, it can mirror either of the backglass screens or have its own content.
I'm getting future pinball on three monitors by putting the back glass in a window and having it oversized dpillinv down into the third monitor. It works quite but its not quite where I want it. Slow progress on these bugs.
griffindodd
  • Builds Stuff
« Reply #288 on: March 17, 2013, 02:00:53 am »
Keep getting it really close but then when reopening the table after saving the back trans light seems to like to move around, not very reliable
Here's my best proportions so far
« Last Edit: March 17, 2013, 02:12:37 am by griffindodd »
griffindodd
  • Builds Stuff
« Reply #289 on: March 18, 2013, 11:39:56 pm »
Finally got hyperpin uvp and visual pinball working with the 4 monitors, now we are getting somewhere
Love the giant dmd
« Reply #290 on: March 18, 2013, 11:41:57 pm »
The pinball part of the cab is looking good!  :cheers:
« Reply #291 on: March 19, 2013, 08:45:13 am »
I so need to build a VP cab like this.  Too many things in the queue first...
ids
  • Last login:July 22, 2026, 11:58:17 am
  • Fighter Captured
« Reply #292 on: March 19, 2013, 09:44:23 am »
me too
bearzilla333
  • Last login:August 15, 2024, 10:57:11 am
« Reply #293 on: March 19, 2013, 10:00:34 am »
Inspiring indeed!   :notworthy:
Shall we play a game? My Project
http://goo.gl/kfyfNu
griffindodd
  • Builds Stuff
« Reply #294 on: March 19, 2013, 10:52:16 am »
Here's a walk through of the four screens and how I'm trying to get them to work...
griffindodd
  • Builds Stuff
« Reply #295 on: March 19, 2013, 12:25:51 pm »
So I finally worked this out, and it is kinda annoying/disturbing to find the answer. The Hyperpin backglass works on the second screen ONLY if the third screen is not 'touching' the primary monitor, otherwise it jumps to the third screen. The reason non of them were initially working was my UVP server wasn't installed properly.
So to get around this I have the secondary monitor set to 1366x720 custom res and then the third monitor set to 1280x720 and I float it on the horizontal so it is centered underneath the 2nd monitor. This way the third monitor doesn't touch the primary monitor, very crazy and I'm concerned that the third monitor may be 'snapping' back to touch the primary on reboot.  :banghead:
Anyway, at least I'm starting to understand the nature of this very quirky set up, if it continues to give me headaches I may have to drop Future Pinball as that's the program that's forcing me to have my third monitor under my second one, unless of course I can find a way to get a DMD from FP over to the third monitor as an individual element rather than some weird extension of the second monitor..
PHEw.....too many monitors.  :dunno
« Reply #296 on: March 21, 2013, 09:54:22 am »
This makes me think that if/when I build mine, the backglass is going to a single monitor mounted vertically, with the back glass and DMD both showing up on 1 screen. Of course that will probably introduce exciting new difficulties!
build looks good so far, I wish I had the scratch to do one myself.
griffindodd
  • Builds Stuff
« Reply #297 on: March 21, 2013, 09:57:13 am »
I highly recommend taking the single monitor approach on the back as it is way less complicated than this. I would have done it myself but I need to be able to mirror my DMD to the side projectors so it needed its own physical screen.
Re: Re: Identity Crisis! : Morphing Pinball Shmup Table
« Reply #298 on: March 21, 2013, 10:21:45 am »
That's an interesting approach. I'd like to see that one implemented.
« Reply #299 on: March 21, 2013, 11:40:13 am »
I did a little math on how much smaller basic VP cab would cost.  I'm talking something with a PC just like griffindodd's and a two monitor setup (27" and 19").  No fancy addons or pinball cabinet hardware.  No matter how I jiggle the numbers it comes out to around a grand assuming all newly purchased parts.   Some hardware recycling could bring it down to the 800 range.  And that's a cabaret sized VP cab.
griffindodd
  • Builds Stuff
« Reply #300 on: March 21, 2013, 12:02:06 pm »
Yeah the screens are a bit of a money burner, despite buying refurbed bargains I've still got almost $1,500 into this just for screens and PJs alone  :dizzy:
Finally got HyperPin, Visual Pinball and Future Pinball playing the way I want them to with the screens and ironed out some of the glitches with the setup, so I'm confident enough in the software to make some more decisions on cabinet dimensions and alignment.
« Last Edit: March 21, 2013, 12:03:47 pm by griffindodd »
rablack97
« Reply #301 on: March 21, 2013, 10:01:31 pm »
 :badmood: Too many words, need more pics....
griffindodd
  • Builds Stuff
« Reply #302 on: March 21, 2013, 11:15:18 pm »
Here...
griffindodd
  • Builds Stuff
« Reply #303 on: March 22, 2013, 12:02:47 am »
Its becoming apparent that the amount of reshaping and adjusting I've been having to do means I'll have to do the sides again for structural rigidness. So I'm going to frame out the pattern then use it as a routing guide.
« Reply #304 on: March 23, 2013, 09:26:30 am »
Agreed on redoing the sides.  Less sexy work but nonetheless very important.   :cheers:
rablack97
« Reply #305 on: March 23, 2013, 11:20:49 am »
He's making major improvements ladies and gentlemen, the curves the lines the detail.  Don't forget about those signature pocket screws Jim, this would not be a Griffindodd build w/o pocket screws....
Loving the night shift approach it brings an essence of peace when your able to run loud obnoxious tools at night, right Jim?  I agree, there is something special about midnight sawdust......
rockyrocket
« Reply #306 on: March 24, 2013, 05:53:29 am »
Here you go
Slig
  • Last login:May 26, 2013, 08:58:42 pm
« Reply #307 on: March 25, 2013, 09:40:18 pm »
O M F G!  :notworthy:
griffindodd
  • Builds Stuff
« Reply #308 on: March 26, 2013, 11:44:06 am »
Taking a little break over the next week, heading off to Oregon to have a few craft brews in Portland, drive the coast and spend some time in Eugene and Bend with the wife and peanut, time for some green trees and mountain air instead of sawdust and wood glue.
dandro
  • Last login:July 20, 2014, 12:32:46 am
    • Link To project
« Reply #309 on: March 26, 2013, 12:45:40 pm »
When/If your driving I-5 north, when you pass 205/580 near Tracy, wave!
Gamester
« Reply #310 on: March 26, 2013, 01:32:29 pm »
Enjoy!  Hopefully you'll come back to the project rejuvenated, and with a nice fresh perspective.  :)
griffindodd
  • Builds Stuff
« Reply #311 on: March 26, 2013, 02:16:24 pm »
Thanks guys. I must admit I'm hitting a bit of a mental wall with this, not for any bad reason, just the big projects sometimes feel a bit too big. That's why I keep side projects like the Kong barrel
griffindodd
  • Builds Stuff
« Reply #312 on: March 27, 2013, 12:23:19 pm »
I decided that the load times weren't fast enough and they were taking away from the experience too much, so I hunted down a decent deal for a refurb 120GB Corsair Neutron GTX SSD for $100 shipped, it's a screaming fast drive so hopefully it will make a big difference to the overall feel of the menus and game loads.
griffindodd
  • Builds Stuff
« Reply #313 on: March 27, 2013, 12:54:08 pm »
Having a really hard time naming this project, Identity Crisis was more of a working title, but I guess it fits quite well as the machine transforms totally based on what you are playing. I guess it would be fun if I took the Time Crisis logo and adjusted it but I can't seem to find a font anywhere for that.
This is almost the opposite to my other builds where artwork has played such a huge part in their identity, ideally this build will have no printed artwork anywhere on the cab....hrmmmmmmm
Anyone else got any super clever names for something that constantly morphs?
« Reply #314 on: March 27, 2013, 12:58:43 pm »
The entire front end should be working out of memory.  Game loads, maaaybe, but I'm thinking that disc speed isn't your issue here.   This is more of a "how fast can you process the paperwork" sort of thing and not "how fast can you read the paperwork".
griffindodd
  • Builds Stuff
« Reply #315 on: March 27, 2013, 01:03:53 pm »
Getting the FE from disk to memory is the choke and loading tables is the most noticeable issue. Also leaving tables and going back to the FE is strangely laggy as it should, like you have said, all be in memory. I'm using 8GB of 1866 DDR3 on an x64 system, so I don't understand the 6-8 seconds between quitting a table and being able to navigate in HyperPin again.
Yvan256
    • Yvan256
« Reply #316 on: March 27, 2013, 01:10:25 pm »
Having a really hard time naming this project, Identity Crisis was more of a working title [...] Anyone else got any super clever names for something that constantly morphs?
Morphcade? Only 9 non-related results on Google! ;)
There's so many things inside that project that even picking one to name it wouldn't do it justice, i.e. "LCDCade" or "Projectorcade". Not to mention that those are silly names.
How about "OddCade"?
griffindodd
  • Builds Stuff
« Reply #317 on: March 27, 2013, 01:11:41 pm »
ummm I think anything with the letters "CADE' in it is an automatic /fail
« Reply #318 on: March 27, 2013, 01:13:18 pm »
 :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud:*
*Unless it's a clever pun, like Shoryukade.
griffindodd
  • Builds Stuff
« Reply #319 on: March 27, 2013, 01:25:58 pm »
AFKade
Darkade
Urkelcade
are the only exceptions to this rule.
