Author Topic: Tron Legacy - Update 05/03/2016 - Mala Woes  (Read 197854 times)
Re: Tron Legacy - Update 4/14/2012 - Playing with Bling
« Reply #160 on: May 10, 2012, 11:07:28 am »
 :bump
Stop looking at responses to the pictures of your cat of Facebook and get back to work.
« Reply #161 on: May 10, 2012, 11:29:10 am »
:bump
 :lol  Man you ain't kidding.  Pretty pathetic progress recently.  I'm really envious of guys like LeChuck that can fly through a project.
I'm have been doing some minor work but nothing worth posting.  Hope to have something by this weekend.
« Reply #162 on: May 10, 2012, 12:07:54 pm »
I took an afternoon off from work to cut out the side panels.
My girlfriend was out of town last weekend, so I ignored everything else and spent a solid day and a half working on it.
That's why I made such "fast" progress.  ;)
If it were done in a couple hours each evening, it would have taken me a month.
« Reply #163 on: May 10, 2012, 01:28:52 pm »
:bump
I can't hear you over the sound of my router!
Re: Tron Legacy - Update 4/6/2012
« Reply #164 on: May 14, 2012, 07:00:54 pm »
I think I've had that monitor in and out at least 10 times as I try to get it to fit just right.   :banghead:
I'm happy with it now and am on to working on the bezel and glass.  I've been holding off on mounting the completed Tron disc until the monitor was ready since the board it will mount to will rest on the monitor shelf.
I've also been slowed down just a touch on this project because I picked up a dedicated Asteroids Deluxe.    Good problem to have in this hobby.   :cheers:
I now officially have three projects going at once.   :dizzy:
tony.silveira
  • Last login:February 18, 2026, 09:58:05 pm
    • my baby
« Reply #165 on: May 18, 2012, 09:10:46 pm »
check out my sig for where i have my secondary monitor.  i want to add a servo so that it pops out when turned on
« Reply #166 on: May 18, 2012, 10:56:11 pm »
I had wanted to do something similar to yours at one point.  I designed my cabinet without a 2nd monitor in mind though so there is no room there.
I like how you incorporated the SW Yoke.   :cheers:
« Reply #167 on: May 24, 2012, 11:51:49 pm »
I've been working on the template to my CP top.  I wanted to have a curved front and ended up making a jig.  There are easier ways to do this but I thought this would be more fun.
I started off by making a plate for my router to attach to.
I attached the plate to a 2x4.
I drilled a hole through the 2x4 and secured it using a bench dog.
It took me several tries as my initial cuts were not round enough.  I just shortened the 2x4 a little each time to get a bigger arc.
I'm still not sure this is quite what I want but I'm going to go with it for now.
Woodshop Flunky
Re: Tron Legacy - Update 5/24/2012
« Reply #168 on: May 25, 2012, 08:58:18 am »
Nice job... love a perfect curve!  :cheers:
  • Last login:September 28, 2026, 10:38:02 pm
« Reply #169 on: May 25, 2012, 10:05:48 am »
Now THAT is a circle cutter!
Good work.
« Reply #170 on: May 25, 2012, 10:08:39 am »
Thanks guys.  I'm sure there are easier ways to cut an arc but that I always wanted to try something like that.
« Reply #171 on: June 20, 2012, 08:12:19 pm »
I've been working on the CP box here and there for the past few weeks.  My plan was to curve the front at the same angle as the CP top.  I'm also laminating the outside.
I kerfed the front and rabbit cut the sides to hold the bottom together.
I glued the sides and back first.
I laminated the front before I glued it in place.  I had to file the laminate carefully as the top was beveled and I was unable to make it flush with my router.
Had to use a lot of clamps to hold the front in place
Needs a little clean-up but I like it.
I'd never laminated a corner before and had trouble finding many "best practices".  As a precaution I painted the corners black to ensure no wood would show.  This turned out not to be required.
Here it is test mounted.  I'm happy with the look but it seems a little big.  Not an aircraft carrier but very close.
Re: Tron Legacy
« Reply #172 on: June 20, 2012, 10:45:42 pm »
Next step is to build the base and decide how I want to attach the cleats.  I wanted to have the basic cabinet assembled and in my basement by the time the Christmas Tree comes down.  I don't think I am going to make it but maybe by New Years.
Dumbass.   ;D
Almost 6 months to the day.  Better late than never.
Re: Tron Legacy - Update 6/20/2012
« Reply #173 on: June 21, 2012, 10:13:50 am »
Glad to see you back on it!  Sometimes it's good to take a break instead of dropping the quality to get it done (like I usually do).
The laminate work on that CP box looks sweet!
« Reply #174 on: June 21, 2012, 10:34:51 am »
Thanks BadMouth.  I found that Spring wasn't really a good time to work.  We had way to many commitments with our kids in sports, band and dance.  Things are finally starting to slow down so I should be able to make more progress.
Now if I could just decide on artwork.   :banghead:
GIZMOGAMES
« Reply #175 on: June 21, 2012, 01:05:49 pm »
do you have a rough layout idea for your control pannel ?????
ive been josling some tron ideas for the past 2 weeks :) seems to be the theme style lately :) i like those disk kits tho very cool :)
« Reply #176 on: June 21, 2012, 07:28:25 pm »
GIZMOGAMES -
Here is a rough layout of what I have in mind.  It is your basic panel with a Tron stick and spinner--and a recessed monitor.
You are right about Tron becoming quite the style lately.  I could have been a trend-setter had I started earlier.   ;D
« Reply #177 on: June 21, 2012, 10:09:38 pm »
  I could have been a trend-setter had I started earlier finished on time.   ;D
FTFY :duckhunt
« Reply #178 on: June 21, 2012, 10:20:28 pm »
FTFY :duckhunt
You say tomato...   ;)
I was showing my daughter the lit up Tron disc last night.  She mentioned she didn't think she would ever see it in the basement.   She "helped" me build my first mock-up CP 4 years ago.    :dizzy:
GIZMOGAMES
« Reply #179 on: June 22, 2012, 07:45:44 am »
this kind of idea flows well and fits very well if you use the cutouts in the buttons to make a complete image :)
took a few hrs but fits better than other ideas im away a few days so will work on some more if you like :)
also tried to keep it samescale as yr image
hope this inspires you oh and one more thing if your pc in there can cope with up to date graphics i found out tron EVOLUTION is on the pc/360/wii/ps3 games amazing "grabbed my 360 vs"thanks fleabay lol :D
and would make an awsome addition to yr collection/theme :)
keep up the awsome work :)
http://uk.ign.com/videos/2010/12/07/tron-evolution-video-review?objectid=14319752
« Last Edit: June 22, 2012, 08:08:47 am by GIZMOGAMES »
mcseforsale
  • Creepy Mario Dude
« Reply #180 on: June 22, 2012, 10:28:59 am »
Wow.  That's really really good.
AJ
« Reply #181 on: June 22, 2012, 10:35:57 am »
Thanks GizmoGames.  I like the look of that image but I've been thinking of going with something like this -
http://forum.arcadecontrols.com/index.php?topic=113679.0
I'd like to pick up that Tron game for the cabinet.  Have you played it?  We have the PS3 version but I think it is a different game.
GIZMOGAMES
« Reply #182 on: June 22, 2012, 10:45:07 am »
not sure to be honest and no worries that one youve seen is cool :)
i only just saw evolution and thought y dont i own that lol ive got over 850 originals for my 360 now so thats my dedicated console altho i do own all the others :)
hence gizmogames lol
the one you chose could overlay the one i did pretty easily with some merge fading could be something maybe ill spitball it later gotto go hospital and lack of internet means no posts but meh got to hope i get better
keep up the great effort anyhow and see what i can throw into the ideas pot later
ciao for now
« Reply #183 on: June 24, 2012, 05:06:15 pm »
Finally got the first disc mounted.
I mounted the disc on a piece of MDF that had been wrapped in carbon fiber vinyl to give it some contrast with the laminate.
Here is a shot of the bottom of the disc with the insides "Dremeled" out.
Here are the LED's waiting to be covered.
Here are a couple of shots of the modified disc with an unmodified one.
Here is one unlit.
Here is one lit.  I ended up having to do a lot of tweaking with the Dremel to get the disc looking how I wanted.  There were a lot of shadows initially and I had to keep trimming plastic to get the light to show through evenly.   As most of you know it is really hard to take pictures in the dark.  Suffice it to say the disc looks much cooler in person.
I need to order a second kit now for the other side.  As with most things I expect the second one to go much faster.
« Reply #184 on: July 01, 2012, 11:34:08 pm »
Did a little cosmetic work this weekend.
Here is the coin door mounted.
I couldn't find any carriage bolts locally that would fit so I used some of these.  Originally they were just going to be temporary until I could find some black carriage bolts but I like the look.  They are a little more industrial and I'm going to keep them.
I finally mounted the back door.  I was originally going to hinge it but decided to go with a removable door to match my Asteroids Deluxe.
Next up - Mounting the computer and configuring software.
Re: Tron Legacy - Update 7/1/2012
« Reply #185 on: July 02, 2012, 09:11:15 am »
The back of that thing looks nice and clean.
Top notch work!
« Reply #186 on: July 02, 2012, 09:22:21 am »
Love that coin door style.  The bolts do catch they eye but not necessarily in a bad way.  Keep going!
« Reply #187 on: July 02, 2012, 09:22:50 am »
Thanks BadMouth.  There are a few bad spots on the back but I made sure they didn't show up in the picture.   ;D
Hoopz
  • Intellivision Rocks!
« Reply #188 on: July 02, 2012, 09:33:07 am »
Pretty awesome work.  The CP curve and laminate looks amazing.
How about replacing the coin return art with something tron related?  Small touch that really adds a little something extra.
« Reply #189 on: July 02, 2012, 09:33:49 am »
Thanks LeChuck.  I dragged my coin door to a couple of hardware stores looking for carriage bolts that fit.  I couldn't find any that would sit flush in the square opening.
I did get a lot of interesting looks and a few questions lugging around a coin door.  That was fun.
« Reply #190 on: July 02, 2012, 09:36:07 am »
Thanks Hoopz.  That's a good idea.  Maybe something with the Tron disc on it?
I'm also going to get a different color coin return once I settle on artwork.  I don't like the color of the one that came with the door.
« Reply #191 on: July 02, 2012, 09:52:22 am »
ENCOM logo in place of Happ
maybe ditch the "push to reject" and make the 25c bigger
« Reply #192 on: July 02, 2012, 10:07:58 am »
I like that idea.  I might also add the ENCOM logo to the flat spot of the door like some of the older Atari and Williams doors had.
Hoopz
« Reply #193 on: July 02, 2012, 10:10:12 am »
How about Tron's bit on each one?  One could be "yes" and the other "no".
And it looks like someone has my skills in MSPaint with the shaky line!  That's how I do it.   :cheers:
« Reply #194 on: July 02, 2012, 10:33:42 am »
That's good as well.  As an old Assembler programmer I always liked that character from the first movie.
Too bad my frankenpanel is going to totally eclipse the coin door anyway.   >:D
  • Last login:September 29, 2026, 10:50:05 am
« Reply #195 on: July 02, 2012, 04:46:49 pm »
Wow, that disc looks badass!
Woodshop Flunky
« Reply #196 on: July 02, 2012, 08:11:44 pm »
This keeps getting better!  Really like the allen head screws.  :applaud:
« Reply #197 on: August 06, 2012, 08:23:51 am »
I may have gotten too cute with the curved front on my CP.  I'm having trouble figuring out a good way to hinge the top.  I've uploaded some pictures here that I hope will accurately represent the problem.
With the front being kerfed I'm a little leary of trying to attached the hinges there.
I picked up some hinges I thought would work mounted on the sides but the curve makes it so there is not enough clearance.
I've kicked around hinging the CP at the back but there doesn't appear to be enough clearance---particularly with the Tron stick.
I've been leaning towards rebuilding the CP for a while anyway.  I think it is an inch or two too deep.  It wouldn't be the end of the world if I did rebuild it (with a flat front) but I thought I would throw this problem up to the group to see if there is a workable solution I'm missing.
Re: Tron Legacy - Looking for advice
« Reply #198 on: August 06, 2012, 08:30:24 am »
Make the curve integral to the top and hinge from the bottom so the front panel and top fold out as a unit from the sides. Just run your break straight across the bottom at the side panel edges. Keep the curve, it's cool.
« Reply #199 on: August 06, 2012, 09:20:52 am »
I like that idea.  I wish I would have thought of it when I built it originally.  I was so focused on getting the curves right I didn't stop to think how I would hinge the top.
