Poll
What should I do?
Keep separate Vertical & Horizontal MAME cabinets. Buy PC for Driver MAME.
4 (33.3%)
Get a 27" multi-res monitor for the horizontal mame and play vertical games on it.  Use the vertical MAME PC for driver MAME.
8 (66.7%)
Total Members Voted: 12
Author Topic: Decisions Decisions - What would YOU do?  (Read 2545 times)
FrizzleFried
    • Idaho Garagecade
« on: September 08, 2008, 04:57:38 pm »
Right now I play my horizontal games on a horizontal MAME cab and my vertical games on a vertical MAME cab.  I am considering purchasing a 27" multi res monitor for the horizontal MAME enabling me to play the vertical games on it and maintain approximately the proper resolutions.   If I did that I could pull the PC from the vertical MAME to use in the Driver MAME I will be working on shortly.  I then would have an empty Dynamo cut-corner cab I could drop a multi-CPS2 board in to or something.  This would also free up a little space in the game room.
How nice do vertical games look on a multi-res horizontal monitor?
Ginsu Victim
  • Comanche, OK -- USA
Re: Decisions Decisions - What would YOU do?
« Reply #1 on: September 08, 2008, 05:26:02 pm »
Keep things as they are, and buy a PC for the driver mame. You can build a PC so cheap these days.
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #2 on: September 08, 2008, 05:33:59 pm »
The money shouldn't be an issue, as a big multi res monitor is as expensive as a PC.
I have been playing vertical games on a 25" horizontal monitor. They look fine, but the horizontal ones look better: filling up the screen to the bezel. Sometimes I get the itch to build a vertical cab, which considering my project is far from done, is insane...
ahofle
    • Arcade Ambience Project
« Reply #3 on: September 08, 2008, 05:58:41 pm »
That's a tough decision.  I think what you have is pretty much ideal.  However, verticals do look terrific on a multisync, especially if you use Soft15khz which let's you add some additional custom resolutions for 300 and 320 line vertical shooters.
A couple benefits I can think of using a digital multisync (I wouldn't bother with an analog one which seems to be practically all that's available these days):
- medium resolution games
- Arcade cabinet-friendly PC games requiring higher resolutions
- keeps geometry settings between games
Another thing to consider is how much longer digital multisyncs will be around.  I would bet in a year or two there will be no more digital multisync CRT arcade monitors available.  The D9400 is pretty much the only one left.  :'(  If I could afford it, I would buy one as a backup for my Betson.
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: September 08, 2008, 06:47:38 pm »
I was looking at this bad boy...
http://www.betson.com/products/IMP-44-4070-RT
  • Last login:April 08, 2026, 06:31:20 pm
« Reply #5 on: September 08, 2008, 07:01:16 pm »
I use an automatically rotating 19" PC CRT monitor.
I love it. The WOW effect when people first see it turn is pretty cool too.
FrizzleFried
    • Idaho Garagecade
« Reply #6 on: September 08, 2008, 07:04:04 pm »
I'd love to build one of these one day... I agree,  a rotating monitor is bitchin,  especially if it's automatic depending on the game you choose....
Havok
  • Trade Count: (+17)
« Reply #7 on: September 08, 2008, 07:22:06 pm »
Free up the space - then you can fill it up again with another cabinet!
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #8 on: September 08, 2008, 07:43:41 pm »
Keep your setup.  I have a 27" multisync and while i love it.  i would like dedicated horiz and vert cbs better.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
ahofle
« Reply #9 on: September 08, 2008, 09:31:36 pm »
Be careful with that one (that's what I have).  In recent months, they seem to be having 'horizontal linearity' issues with those monitors (ie. squishing on one side or the other).  That's about the only issue with mine (search the monitor forum and you'll find a bunch of others with the same problem).  If you are close to a Betson distributor for easy return/exchange I'd say go for it, but if not just remember it's about $100 shipping if you have a problem with it.
Thenasty
  • Last login:Yesterday at 07:53:36 am
« Reply #10 on: September 08, 2008, 09:57:00 pm »
do what I did, have both monitor installed in ONE CAB. One Vertical and 1 Horiz....... All I do it flick a switch to change the monitor. Easy, Simple....
Free VGA Breakout Cable
Thenasty
« Reply #11 on: September 08, 2008, 09:59:00 pm »
switch under the upper bezel...
Ginsu Victim
« Reply #12 on: September 09, 2008, 08:26:52 am »
Thenasty:
Is there another link to your project thread? The one in your sig isn't working. (Awesome setup, I wanna see more! What sort of cab is that?)
« Last Edit: September 09, 2008, 08:28:44 am by GinsuVictim »
