Author Topic: Here's an app to control volume with your spinner/trackball/joysticks/buttons...  (Read 151889 times)
ahofle
    • Arcade Ambience Project
Based on an idea in this thread:
http://forum.arcadecontrols.com/index.php?topic=69805.0
...I threw together a small application which allows you to set a hotkey which, when held down, allows you to control your windows wave output volume using a mouse device (spinner, trackball) and/or keyboard device (joysticks/buttons connected to a keyboard interface such as IPAC or keywiz).  Basically you can set it up to control cabinet volume using only arcade controls.  It only works on NT/2000/XP/Vista and it requires the .NET 2.0 framework which you can download from microsoft.  There are a bunch of apps like this out there, but the ones I've tried are not very cabinet friendly (requires use of the mouse scroll wheel, special 'windows' key, etc).  I hope someone gets some use out of it.
NT/2000/XP (this build does NOT work with Windows 7 and higher):
http://hofle.com/mame/CabVol.zip
Windows 7 (ONLY works with Vista/Win7/Win8 and higher):
http://hofle.com/mame/CabVol-VistaOnly.zip
« Last Edit: October 14, 2014, 12:26:29 am by ahofle »
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
YOUR THE MAN DUDE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 :notworthy: :applaud:
You Just Made a Tron Spinner Vol Knob!!!!!!!!!!!
« Last Edit: August 10, 2007, 09:34:35 am by Chunce DeLeone »
unclet
Thsi is a great little application ..... may I suggest a little update to it ....
For a jukebox cabinet, having a little spinner know would be great for volume, however, having to press the hotkey while turning the spinner knob is not really great (for a jukebox cabinet).    Perhaps you could add an option in this application to indicate whether the HotKey should be used or not.
Basically, for a jukebox scenario, walking up to the cabinet and turning the knob should always adjust the volume.  Would not want to have to get people to press a hotkey first then turn the knob for a jukebox ...... I understand why you do it for an arcade cabinet, but it just is not that friendly for a jukebox cabinet.
Neilyboy
  • Last login:October 08, 2025, 08:19:14 am
  • what day is it...
Very cool program man!! Once my cabinet is done ill be running this software!
Neil
ahofle
Hmm interesting...  Are there people out there that have a spinner on their jukebox with no trackball or mouse (it would have to be totally mouseless or else the program would start wildly adjusting the volume around when you used the trackball/mouse)?
bfauska
I just installed this and it seems fairly cool, one question/request though.  Would it be possible to add z-axis control of the volume?  I don't yet have a spinner but my plans include one running off of the x-axis of a TB controller, the trackball would be x and y and the spinner would be z.  I think this is actually a fairly common approach and would allow me to use a TT2 spinner as the interface for both a trackball and spinner and then use the spinner for volume.  OK I lied, two requests... Is it possible to allow holding down a key for continuous volume control, right now I have it assigned to a joystick and to control the volume I have to tap it instead of hold it down, I suppose if I fine tune the adjustment increment then I could get a solution worked out.
Overall I think this software will save me a bunch of work, I was planning on replacing the wheel style volume control in-line with my computer speakers in the cabinet w/ a knob and that would have either been a complete custom cable or a hacked factory one.
Thank you for a great application, I like it as is and feel that the additions would only make it better.
unclet
Yeah, I guess a lot of people would not have a hacked mouse as a spinner for their jukebox, although if your application had this ability perhaps more people would hack a mouse for volume adjustment.   It would be pretty cool to have a knob of the jukebox to adjust volume.
Actually, you could do a lot with this program if you wanted to ...... you could allow people to map a certain key to moving the mouse "right" and another key to moving the mouse "left".   This way turning the spinner knob could be used to select a game in a game list, flip through all the various emulators installed on a cabinet, etc ... etc ...
« Last Edit: August 11, 2007, 08:45:16 pm by unclet »
TheBrokentoken
  • Last login:December 13, 2009, 09:19:37 am
  • Being a noob is awesome! (not)
    • Brokentoken.com
Very, very nice.  Thanks for putting this together, as it'll be a huge help to everyone here on the forum!
- Whitney Roberts
http://www.brokentoken.com
ARTIFACT
you are totally the man... I am glad I posted this thread!!! :)
Can't wait to try it ... my cab is all unplugged but my test / mockup CP is coming together and I'll make sure to set up your app.
thanks again
ahofle
I'll look into this.  I know the scroll wheel is reported differently than the X and Y movement (more like a keypress) but I think it should be easy to do.
It works that way already.  Try going to your keyboard control panel and increasing the repeat rate.
Space Fractal
  • Space Fractal
    • Space Fractal
Did not work in 64 bit version with Vista Premuim on my work machine.  All Inputs works in debug mode, but it did never change that volume (I have UAC user control disabled).
Otherwice Cool app to see and good use on a arcade cab (maybe on my primary arcadecab, where I use VolumeTray, that works as it should).
A request is been able to remove that config window and send it to the system tray, when you minimize it, after you configurated it. next start should allways start as minimized state.
About around repeat rate problem:
 Do NEVER change volume, directly on PollEvent() events. PollEvent() should even been use to check if key is pressed down or not.
 Instead use a input variable and change that that to 1 if KeyDown() is invoked and 0 if KeyUp() is invoked (and ONLY that).
 Then use a timer event to detect when it time to change the volume and check the variable for the keypress status. Now the key repeat is gone.
About mouse spinner
 Not all jukebox software need that, because it added to that software (like my own MultiJuke), but it would been cool to use a spinner without need to press a key or not (should been user choiseable). If you do that, this app would been suitable for arcade cabs and jukebox cabs (that do not have a touchscreen).
« Last Edit: August 13, 2007, 08:41:50 am by Space Fractal »
ahofle
OK I added the Z axis.  It seems to work with my mouse scroll wheel.  Not sure how it will work with a spinner hooked to the Z axis though.
This uses windows hooks, not polling.
ARTIFACT
for some reason it does not work for me
i map to mouse x.
my spinner is mapped to mouse x
there is also a trackball (x and y mouse) ... conflict?
also it'd be awesome if this could start and minimize as a system tray app
thanks!!!!
ahofle
Are you using Vista?  Someone else reported it doesn't work with that OS too.
ARTIFACT
no, just xp pro with a bunch of services disabled (maybe thats it)
it does launch and run, just no effect
thanks
ahofle
Try checking on the 'debug mode' checkbox and make sure you are picking up the mouse and keyboard events.  Dumb question but you are holding down the hotkey right?
ARTIFACT
yep
I am assigning the MAME P1 Switch 2 ("ALT", the mame default), from a happ pushbutton plugged to an I-PAC 2.
I will check the debug mode when I get home :)
thanks...
ARTIFACT
I am sad this is not working for me :(
the key presses are listed in the debug list, and the mouse x axis value (where my spinner is assigned) changes
ahofle
Re: Here's an app to control volume with your spinner/trackball/joysticks/button
« Reply #18 on: September 05, 2007, 10:19:12 am »
Just for kicks, can you try a different hotkey (like 'A' or '2' or something, not a special character).  Also make sure your focus is not on the cabvol program when testing (minimize it) because it will think you are trying to set the hotkey if you are focused in that field.  To test, I usually play an mp3 or something that has constant sound.
ARTIFACT
OK! I will do that...
Is there any way to make CabVol.exe start minimized in the task bar?
I know how to add a shortcut to it in the Startup folder (so it starts when windows boots) BUT the UI shows up on top of MaLa frontend...
Thanks!!!
ahofle
« Reply #20 on: September 05, 2007, 05:09:16 pm »
Thanks!!!
Drag a shortcut to cabvol.exe into your startup folder, and then go to the shortcut's properties and select Run: 'Minimized'.  It should then start with Windows and minimize itself.
Space Fractal
  • Space Fractal
    • Space Fractal
You might try to use bass.dll or fmod.dll as a alternative to change the volume, when it dosent work (I remember it can change the main volume, so it should effect other apps as well)? The only problem it may confuce with some Jukebox applications (which many use bass.dll)... The user could try it if it fail witch the normal api.
ARTIFACT
IT WORKS NOW!!! AAAAAAAAAAAAAAAAAAAAA
thank you thakn you thank you
(configured P2 START as hot key, and set increments to 1000... like a charm!)
ahofle
« Reply #23 on: September 08, 2007, 01:58:00 am »
Glad to hear it!  :cheers:
I guess 'alt' doesn't work too well as a hot key for whatever reason.
ARTIFACT
this totally rocks...
I just spent about 1 hour playing various games, loving the volume control.
P2 START is a pretty good key for it too... I use P1 START to select items in MaLa
ARTIFACT
weird...
ok so i launch a game
then set the volume how i want it
then play
then exit the game
now
if i launch the same game again
without changing volume
it is LOUD again!
and
if i try to change volume again
it doesnt work all the way (changes but not below a certain value)
whats going on?
i use my spinner and increments are set to 250 i think
does your app controle mame's game volume, or the windows / general volume?  .. why is it changing on game launch?  ... is it perhaps reading the mouse x (spinner) and resetting itself?
« Last Edit: September 09, 2007, 02:34:30 pm by ARTIFACT »
ahofle
« Reply #26 on: September 09, 2007, 05:17:54 pm »
Hmm I'm not sure.  I just tried what you did in MAME and when I exited and came back in the volume was the same.  What version of MAME are you using?
ARTIFACT
i compiled my own 117u3 with high score support and no nag screens
im about to do the same with version 118 and use that
ARTIFACT
One tiiiny feature request from me... :)
Right now, if by mistake I toggle from MaLa to the cab volume app, focus is on the hotkey field... if I then press a key, it simply messes up the configuration... I just had folks over playing on the arcade and couldn't figure out why it wans't working anymore... it was because the key had been changed by mistake... :(
Could you make it so the text field must be CLICKED to wait for a key change?
Thank you!!!
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #29 on: September 11, 2007, 10:52:32 pm »
Great program Afole, but im having a slight issue with it...
When my cabinet boots up into MAMEwah, your program seems to always boot on top of it in focus, is there anyway to have it stay in the background or even minimized in my tray?
Aside from that, awesome job mate!
ahofle
« Reply #30 on: September 12, 2007, 12:19:18 am »
Have you tried running it minimized at startup?
postalp123
« Reply #31 on: September 12, 2007, 08:56:08 am »
TY Sir! Ill give it a shot when I get home, But im sure that will do it.
Props again for this program.
ARTIFACT
it would be great if the focus was not being automatically set to the hotkey change action though... even if the app will generally be minimized... it would add an extra click to avoid switching the key by mistake :)
right now if i use alt+tab to flip between my apps (mala, cabvol, sometimes a folder open to copy files or notepad to edit ini files...)... well flipping to cabvol and to another app ... changes he hotkey o alt or tab ...
thanks for the hard work! one less hole to make i my cab or wires to solder :)
ahofle
« Reply #33 on: September 13, 2007, 12:10:36 am »
I will try and look into that soon.
ahofle
« Reply #34 on: September 13, 2007, 11:34:40 am »
ARTIFACT
you ROCK!
i will try tonight :)
ARTIFACT
much better!
thank you
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Is there any way you can add a Mute hokey combination to this fabulous little app?
-csa
ahofle
Hmm that's not a bad idea.  I'll look into it when I get a chance.
csa3d
awesome!  you the man.
-csa
