Author Topic: GreenAntz RGB to component transcoder  (Read 963996 times)
0 Members and 40 Guests are viewing this topic.
  • Last login:Today at 03:14:19 pm
Re: GreenAntz RGB to component transcoder
« Reply #160 on: June 21, 2026, 03:47:47 pm »
I'm guessing that Scott already knows this.
Uhhh . . . not really.  You're working FAR beyond my very basic skills in electrical engineering.   :cheers:
The idea of using a PIC with built-in VCO and comparator functions to control a logic gate that turns sync processing on/off sounds promising.
Seems like the safest approach is to have the default state for that logic gate turn sync processing off and turn sync processing on only when a 15kHz signal is detected.
Zebidee
  • Last login:Today at 07:48:51 pm
« Reply #161 on: June 21, 2026, 05:11:02 pm »
Oh noes, I rely on you to call me out on my ---That which is odiferous and causeth plants to grow---!
Everything I know about electronics has been self-taught, mostly since taking up this hobby and much more since retiring. Well, I have a strong computer, science and tech background, so not entirely illiterate I guess.
It does, doesn't it? Not just this project - with a PicKit and a logic analyser you can do a lot of stuff. If you can do it with an arduino then you might be able to do it with a PIC or some other programmable micom instead. Smaller cheaper. Programmable microcontrollers are common in modern (and not-so modern) electronics.
But for now I'm sticking to old-skool analog electronics to get the job done.
Aye it does. In addition to the LMC567 (SOIC-8) I'll use a SMD transistor or mosfet to do the V+ switching (both same SOT-23 footprint, and I have ordered both, so all good). I just have to turn on/off the final sync amplification & buffering stage, which draws only a little current, and incidentally powers the sync LED so I can delete the sync filter I'd setup for that earlier.
So, waiting for parts. I will then breadboard it, but I'm so confident enough it'll work that I've already redesigned the PCB.
MdH
  • Last login:June 28, 2026, 03:07:25 am
« Reply #162 on: June 25, 2026, 02:44:45 am »
Adding a message so I can send a PM :)
Zebidee
« Reply #163 on: July 15, 2026, 12:20:01 am »
MORE MORE SYNC
Over the past month or so I've had some success working on solutions on blocking non-15khz video signals.
Thirdly, it will BLOCK higher frequency signals (VGA, 31khz+) automatically (optional, but on by default). I hope so anyway, because I haven't tested this last part yet :)
Doing this with purely "analog" components proved to be a big challenge, and I wasted time exploring several dead-ends before finally getting to a reliable solution. Even so, I learned a lot from this exercise.
I asked AI for help at different times. Occasionally it did help by giving me a different perspective, but mostly (80-90%) it just led me down garden paths that led to nowhere. It can make mistakes too, sometimes silly mistakes, so use with caution.
"Filtering" out frequencies >15khz was a false hope. Not impossible, but completely impractical.
Better approach is comparing frequency cycles (hertz) via a tuned-in phase-locked loop (voltage controlled oscillator). It works much better because you don't have to filter anything out, just compare PLL with input frequency patterns. If they are a match then it "unlocks" and you're in.
I managed this using some tone decoder and timer ICs that have been around almost as long as I have (>50 years).
[REDACTED] Maybe excessive paranoia, but I deleted some details here. If you want to know how I did this PLL matching for your own projects, what ICs I used etc., then please contact me directly
Some more testing to do, but I hope to include this functionality into GreenAntz soon. I can also foresee a bunch of other applications for this in our hobby space.
I have linked to a very basic, short video (click on the picture below). Watch the LED on the breadboard. If I can turn an LED on then I can do anything  >:D
« Last Edit: October 09, 2026, 10:04:21 am by Zebidee »
almsivi
  • Last login:August 05, 2026, 02:41:49 pm
« Reply #164 on: July 20, 2026, 02:27:13 pm »
Very cool, i have to post once to message you to get one right? Here is that.
Zebidee
« Reply #165 on: July 20, 2026, 08:18:30 pm »
Yes, exciting times to be ordering a new GreenAntz, as I am completely re-working the sync circuits atm.
The new GreenAntz will be able to handle whatever sync polarity you give it. It will also check for a valid 15.7khz signal, with a capture range of about 1khz either side. If this signal is absent GreenAntz will automatically cut the sync and video feed, so no chance of damaging sensitive CRTs. The sync LED will indicate sync status.
I still have GreenAntz v2.2 available. Please PM me.
The new GreenAntz (I haven't decided on version number, name yet) price will likely increase slightly as it offers increased functionality, and includes more costly ICs. I also need to get those enclosures sorted out, now that Ond has done the design work. I really should have got some printed already but the sync re-vamping stuff has been taking all my attention.
« Last Edit: August 30, 2026, 02:52:04 am by Zebidee »
almsivi
« Reply #166 on: July 20, 2026, 11:25:36 pm »
Thank you for the exciting update! I sent you a pm and look forward to getting to experience both! If my pm didn't go through for some reason shoot me one and I'll respond back. New to this forum still.
wr023
  • Last login:October 14, 2026, 12:47:03 am
« Reply #167 on: July 21, 2026, 12:37:36 am »
also first post here, eagerly awaiting the new version when it's ready
Zebidee
« Reply #168 on: August 04, 2026, 06:13:56 am »
GREENANTZ SYNC WINS
Success! The latest assembled prototype works well and meets all of my established goals.
I am proud to announce that the *NEW IMPROVED* GreenAntz v2.3 "Sync-off Ant" superior sync circuit will:
- accept all sync input polarities (-/+) and combinations of polarities.
- automatically process composite sync input including CRTEMU csync (which does not switch off the vertical sync signal).
- automatically analyse, filter and block sync signals that are not 15.7khz (within a bandwidth of approximately +/- 1.0 khz).
Which means I am delivering on my earlier promises, in particular:
This is a major upgrade from the older GreenAntz versions! I am considering whether to increment version number to v3.0.
The new design replaces 2 small 5-pin ICs (logic gates) with a 3-pin MOSFET for power switching, a 16-pin quad-logic IC for the csync processing, and 2x 8-pin ICs for the 15khz filtering. There's also a bunch of extra capacitors and resistors involved in trimming, buffing and tweaking signals. Fair bit of stuff.
All this extra hardware has used up most of the spare PCB space and added a bit to the production costs.
Since my last posts I have:
- created a fresh breadboard prototype of the sync and filter circuits
- fine-tuned that circuit
- tested circuit with various parameters (component values) and components from different manufacturers
- designed and built a PCB prototype
- comprehensively tested the new PCB prototype
Here is a pic of my final (fourth) fresh breadboarding of the circuit, from forming composite sync to filtering the 15khz to switching the power on (lighting the LED). This made it easy to swap out and test different parts.
The filter is a phase-locked loop based design, which works similar to a lock & key basis. The frequency patterns must match. It requires high-precision parts in order to get the frequencies and wave patterns right. It has a target of 15.7khz with a bandwidth of approximately 2khz (+/- 1k).
Before I forget to mention, there is also a 15khz filter override switch if you decide you want to ride bare-back for fun, or perhaps you want to use GreenAntz to connect to a compatible HDTV in 640x480p (which is possible).
In case you are wondering, this is the same technology that would have been used in the Matrix to dial in/out (that is, in old-skool tone-dial telephones).
Anyway, I managed to squeeze all of that into the remaining PCB space on the GreenAntz, without disturbing parts like LEDs and screw holes that the enclosures are already designed for. Here is a pic of my first completed GreenAntz v2.3 "Sync-off Ant":
I also made a short video demonstrating how this 15khz filter/screen works. Sorry that it is a bit dark, I needed to make sure there was no screen flicker and that the blue LED was clearly visible (and that my messy work area was not). You can rate my narrative skills as I provide a commentary to help you follow the fun :)
Overall I would call this a complete success! The new design does exactly what I wanted it to do.
Here is a revised "State of Play" summary table of different transcoders. As you can see, GreenAntz v2.3 "Sync-off Ant" outperforms them all.
The only surprise issue I've encountered is that: if you change the polarity of either sync signal to positive, while the GreenAntz is connected, the "Sync-off Ant" sync circuit will fail to reset itself and process the new sync input until you manually reset the GreenAntz (that is, unplug, or turn power off and on again). This never came up during breadboard testing as I always disconnected it to change sync parameters. People are unlikely to encounter it, and anyway is simple to resolve.
It is perhaps worth mentioning that, because of the PLL design, the 15.7khz filter will also pass frequencies at (2n+1)*15.7k, where n=0,1,2 etc. This means at 47.1k, 78.5k, 109.9k, 141.3k and so forth. This seems unlikely to be an issue for most people, but so you know. I may, with future versions and PCB space allowing, include a low-pass filter to exclude those higher frequencies altogether.
If you would like to order, please message me directly. I currently have just a handful of GreenAntz v2.3 "Sync-off Ant" PCBs available from this batch for only US$55 each + courier delivery (+$17 to USA including import duties). Prices will undoubtedly go up soon, and the purple PCBs are sooooooo cool, so locking in a purchase now is a good idea    :cheers:
Enclosures will also be available soon, depending on the quality of what I get back from the 3D printers. The first small batch have already been printed to Ond's design and should arrive any day now. I am reluctant to offer them for sale yet until I give them a proper quality check. So here's a deal: if you order a GreenAntz "Sync-off Ant" right now, I will include a free enclosure with the first four orders (I have already received one pre-order, so that leaves three more). Assuming they pass quality check, of course :D
If you want to save some money and order a GreenAntz v2.2 instead, I still have some available for only $US50. The new cases will work for them too   8)
« Last Edit: August 04, 2026, 07:28:44 am by Zebidee »
srchrono
  • Last login:September 10, 2026, 05:19:44 pm
« Reply #169 on: August 04, 2026, 02:34:44 pm »
Really excited about these! I just wanted to post so I can DM for one. Thanks!
shinobicalamity
  • Last login:September 23, 2026, 09:43:26 am
« Reply #170 on: August 05, 2026, 09:38:16 am »
I just wanted to post too, because I'm intrested to order v2.2 so I can DM:)
Zebidee
« Reply #171 on: August 08, 2026, 06:22:28 am »
All free enclosures have been claimed. No more free ones.
Also, they're taking a bit longer than I expected to arrive, which affects everyone.
If you want to order a GreenAntz v2.3 with an enclosure, probably best to wait. Keep monitoring this thread, I will post developments over next for 2-3 weeks.
Apologies to those affected by the delays   :notworthy:
CX456
  • Last login:September 10, 2026, 09:51:59 am
  • CRT Rule!
« Reply #172 on: August 12, 2026, 02:49:50 pm »
Your progress is interesting! I could DM you to order one.
buttersoft
  • Last login:October 08, 2026, 02:37:50 am
  • Is running at 15kHz
« Reply #173 on: August 13, 2026, 12:57:12 am »
You should!
LW2001
  • Last login:August 28, 2026, 04:29:10 pm
« Reply #174 on: August 13, 2026, 04:55:22 pm »
Very interested in v2.3 I've used other transcoders but none of them block unwanted signals. Also have heard good things about Greenantz in general. Would love to order one as well.
« Last Edit: August 14, 2026, 08:15:13 am by LW2001 »
Zebidee
« Reply #175 on: August 20, 2026, 01:11:19 am »
I've got Good News and Bad News, so will start with the Good.
GOOD NEWS
The new enclosures, designed in collaboration with Ond, came up looking very tidy in standard white resin.
The design includes an 3mm tube to allow users to see the LED directly.
I got a few metres of 3mm fibre optic and cut pieces approximately 1cm long to neatly fill the holes, coming down to the LED tops. However, cutting this stuff neatly isn't easy. Clippers would usually leave a jagged cut, and sometimes left small cracks between the bundles of tiny optic fibres inside.
The enclosure on the right (below) has the unaltered (empty) LED holes.
So I used my soldering iron, with a fresh knife/axe-like tip, to slice off the raw exposed end. This would give a fairly neat edge to start with. After that I'd cut off approximately 1cm with clippers, and maybe also tidy that up later with a quick swipe of the soldering iron.
Then I took some sand paper, working up to 1200, and sanded the exposed "top" ends until "glassy" smooth. The "inside" ends just need to be neat, not glassy.
Next, I carefully glued the fibre-optic tubes into the top shell piece so that the glassy end is level with the top surface. This is tricky to do neatly as the superglue want to run like water through the tiniest of gaps, and leaks onto the outer surface. Nevermind, minor leaks are solvable as the shell's resin surface responded well to sanding. Finish with that 1200 grit paper I mentioned earlier.
With the pics above and below, the GreenAntz enclosure tops on the left and right also have the fibre-optics installed for LEDs (but obviously are not lit).
The fibre-optic-filled LED tubes look great and, in my opinion, are much better than just leaving them open. They look good on or off. They are smooth to touch, level with the top, look professional and give moderate protection vs liquids.
The downside is it requires more work than I'd like. Something for me to think about.
BAD
I did the optic-fibre-LEDs for six top pieces, quite a bit of work. Then it was time to assemble some GreenAntz v2.3 units into their enclosures, ready to be shipped out to people. All I needed to do was screw them together with these M3 screws I've been using until now...
Then disaster! I needed to reprint the tops because the screw holes came out the wrong size.
 :hissy:
I fixed the 3D print files then ordered some replacement top pieces and paid a bit more for faster delivery.
So this ended up being a Good anyway because I learned new skills and went up a level  ;)
CONCLUSION
All is good. The new tops will be here soon. Then I'll need some time to add the fibre-optics.
For those who have already ordered, including the promised free ones, thank you for your patience. It will still be a bit longer. I will send them out as soon as possible.
For others who are interested in ordering GreenAntz with enclosures, thank you also for your patience. I will post here soon when enclosures are available.
If you want a GreenAntz v2.3 *without* an enclosure, I have some available now, no need to wait.
Zeb
« Last Edit: August 31, 2026, 07:48:23 pm by Zebidee »
CX456
  • CRT Rule!
« Reply #176 on: August 21, 2026, 12:44:03 am »
You should!
I arrive at the right time with horizontal frequency protection like the VideoAmp by njz3 and Bandicoot but in component instead of SCART.
Finally, an update from Zebidee !!!  ;D
But, it was your first time designing an enclosure you & Ond?
Zebidee
« Reply #177 on: August 21, 2026, 03:20:19 am »
Videoamp and GreenAntz are complementary devices, meaning you can use both at the same time to achieve bigger things.
For example, with VideoAmp it is possible to run both an RGB TV (via SCART) and a component TV (via VGA out => GreenAntz) simultaneously, with identical images displayed on each.
I made the following video about a year or so ago:
You could also operate a VGA monitor from one head, a GreenAntz TV from the other head, and utilise the GreenAntz 15khz filter to block VGA signals from ever reaching your TV.
It is possible to run GreenAntz to component TV, or direct to RGB TV, from the SCART head by using a VGA-SCART cable in reverse (with some caveats, minor modifications may be necessary). Carefully check the end of the video, you can see I get display on the RGB TV (JVC) using a VGA-SCART cable in reverse to get signal out of VideoAmp. This would also work for input to a GreenAntz (VGA end to GreenAntz, SCART to VideoAmp).
GreenAntz is pure analog, requires no software installation to work (beyond 15khz drivers on your output PC/device). No funky software or configuration required, it just works if it receives an appropriate 15khz signal.
Ond has a lot of experience with 3D printing techniques, and solid design sense, which is why I brought him in on the project.
I already seem to have some raw talent or knack for 3D design, but lack the direct experience. It is all about time, opportunities, priorities. Choices. At the moment my priorities are on the electronics design, and the 3D design quality must match & reflect that. So I asked Ond for some assistance.
The 3D printing technologies are quite mature now. It is something I'd like to do more with, a way I've felt for over 20+ years, if only I can find the time to focus my energies. I'll likely invest in my own 3D printer before too long.
So, getting down to brass tacks. What do you think about the new enclosure?
« Last Edit: August 21, 2026, 03:30:49 am by Zebidee »
buttersoft
« Reply #178 on: August 21, 2026, 07:04:29 pm »
I use 3mm or 5mm perspex/acrylic rod for light-pipes. Works perfectly, and it has to be easier to work than optic fibre :)
Zebidee
« Reply #179 on: August 21, 2026, 07:24:38 pm »
Thanks Butters. A few questions then:
- Do you have any links or examples?
- How well does it transfer the light?
- What about cutting it to length?
- Can you buy it neatly cut to the right length?
buttersoft
« Reply #180 on: August 23, 2026, 07:31:50 pm »
I've found it works fine. Nintendo used plastic to pipe light for the SNES and N64, certainly. any plastic supplier should have it, and could cut it for you. But you can get it off aliexpress as well - https://www.aliexpress.com/item/1005009723278119.html.
Like you noted, bottom end doesn't matter so much, so scoring with a knife an snapping is fine. Top end can be sanded flat, and the rougher surface helps display the light. Short lengths are always a pain to work with, of course, but that applies no matter the material.
Zebidee
« Reply #181 on: August 25, 2026, 10:17:34 am »
Thank you Butters. Hmmm, those are good ideas. However you also still have to sand the ends to make it nice, and that is where the work/time is.
I've refined my method and it works OK. I made a rig (from old PCBs taped together) to hold the fibre secure for clean hot-knife cuts. Sanding is what takes most of the time. My fingers go numb from holding tiny 1cm pieces for so long. All going well it still takes about one hour to sand and fit the fibre to the shells. Then there is a wait (3-4 hours at least) for the superglue to set. If nothing goes wrong like a glue run (all care + fingers crossed), no more sanding required. I was going to explain all of this in more detail BUT...
...BUT, I found an even better solution that I simply must share with you!!
While looking at your aliexpress link, I grabbed some key words from the item description and did some more searches like "LED light guide rod 3mm"
I found multiple suppliers of these made-for-purpose LED light guides designed for 3mm LEDs (and others) in several styles and many different lengths.
I eventually ordered three different types to try. They will now essentially be drop-in parts. This will reduce risk and save me many many hours. The only real risk now will be a glue spill/leak.
Unfortunately, the LED light guides will take 2-4 weeks to arrive. Until then I'm stuck doing them the hard way.
Attached representative pics of these light guides ripped from Ali.
« Last Edit: August 25, 2026, 11:51:23 am by Zebidee »
buttersoft
« Reply #182 on: August 26, 2026, 12:02:12 am »
Nice, that's the ticket! Dropping some in my cart right now :)
Zebidee
« Reply #183 on: August 29, 2026, 03:59:25 am »
To everyone patiently waiting on pre-ordered GreenAntz v2.3 with enclosures, the last of your parcels went out today. I will be in contact directly in a couple of days with tracking information.
This means I can take now take new orders:
- I still a few completed enclosures available for immediate use (LEDs installed etc.), and some more 3D shells are on the way.
- A fresh new batch of v2.3 PCBs just arrived (last lot sold out).
If you want to order a new v2.3 GreenAntz with the "Sync-off Ant" 15khz filter please message me directly (PM/DM). As always you must make at least one post before sending personal messages.
« Last Edit: September 26, 2026, 11:53:24 pm by Zebidee »
hagermo
  • Last login:September 09, 2026, 08:00:37 am
« Reply #184 on: September 06, 2026, 12:04:30 pm »
Hello Zebidee!
I'd like to order one, but I can't PM you yet.  ;)
Judging from all the recommendations for GreenAntz I see, this is the best product available for VGA -> Component transcoding.. maybe it's time for a webstore?    :D
Anyway, thank you for all the effort you've put into this and also for saving me from having to RGB mod my TV. :)
Loveretrogames
  • Last login:September 10, 2026, 12:17:55 am
« Reply #185 on: September 06, 2026, 05:16:37 pm »
Hi, I am interested in getting this transcoder
Loveretrogames
« Reply #186 on: September 06, 2026, 05:33:39 pm »
how to send message to Zebidee to get GreenAntz v2.3I. dont see any option to send him message directly :(
« Reply #187 on: September 06, 2026, 09:41:31 pm »
Sorry I was a bit slow approving your first messages.
Your PMs should now be enabled.
Click on the icon under Zebidee's avatar to send him a PM.
Zebidee
« Reply #188 on: September 10, 2026, 03:08:11 am »
The first batch of pre-ordered GreenAntz v2.3 will have arrived for most, or be arriving soon.
CX456 has pointed out that I made an error with the coloured RCA Y-Pb-Pr output. I have got two of the coloured tabs back-to-front, such that Y (green) and Pr (red) are swapped.
 :banghead:  AFAIK this has affected the entire first batch. My apologies   :notworthy:
I feel devastated of course. Even so, this is a purely cosmetic error. It does not affect the normal operation of the GreenAntz at all. Just swap the red/green cables around. The issue has been corrected for all future GreenAntz units.
In other news, I have used steel screws with these enclosures. I wanted to use transparent nylon screws here but they have slightly taller heads, and the inset for the head is not large enough. The nylon screws stick out by about 0.5mm. So I used steel instead, smaller head. A warning though, If you are going to open the enclosures up, that it is easy to accidentally strip the plastic thread when re-tightening with steel screws. To avoid this, stop screwing as soon as the screw head is fully inset.
Please let us know how it goes in your setup, I hope all is well. Apologies again about the red/green mixup.
« Last Edit: September 15, 2026, 11:06:43 pm by Zebidee »
NekoTheDank
  • Last login:September 21, 2026, 01:42:39 am
« Reply #189 on: September 21, 2026, 01:40:00 am »
I should have guessed lol, so many of the transcoders I've tried have had a miswired RCA. Doesn't bother me at all. I totally understand how you must feel. Don't sweat it.
I flipped the cables around and re-troubleshooted my mode lines and I'm feeling really good about how it looks. I feel like there are just a lot of subtle improvements that have been added to the picture that I'm really appreciating, and I can't wait to tune in the 240p mode line and see how that looks as well.
Really appreciate your dedication to a clean component transcoder, really doing gods work.
Pistachio Bonkrod
  • Last login:October 04, 2026, 09:48:49 pm
« Reply #190 on: September 22, 2026, 08:15:59 pm »
Posting in this thread so I can unlock the ability to PM people.
(lost access to my original account i opened over a decade ago because i used hotmail to sign up, and I can't reset my password on this forum because the reset feature doesn't work with hotmail  :applaud: )
How does this compare with older transcoders? I'm currently using a Crescendo Systems TC1600 i got in 2014 and it has served me extremely well.
buttersoft
« Reply #191 on: September 23, 2026, 09:44:17 pm »
A lot of older equipment in this hobby was considered great at the time, but can't compete with newer options. Scalers especially, but transcoders too. I don't know about the TC1600 specifically, but it's a pretty good bet the GreenAntz will knock it out of the park.
Zebidee
« Reply #192 on: September 24, 2026, 02:32:47 am »
Hi, thanks for your interest and question.
The TC1600 seems pretty decent, for what it is and when you got it. I don't have one, but read the user manual. How much did it cost?
GreenAntz offers many extra features. Here are a few things to think about, off the top of my head:
1. GreenAntz provides best-quality performance of expensive transcoders for a much more reasonable price.
2. GreenAntz will preserve your original video modes like 240p; it will not crunch or squish your video into a single mode like 640x480i.
3. GreenAntz includes a video filter to pass 15.7khz only (+/- approximately 1khz, optional). This will actively block other video signals, such as 25khz (EGA) or 31khz (VGA) etc. This will protect your sensitive (and irreplaceable) CRT equipment from damage due to high frequencies (a situation the TC1600 user manual specifically warns about).
4. GreenAntz is specifically designed for retrogamers and 15khz use only, up to 480i/576i. It will pass HD 480p/720p video (if the 15k filter is turned off), but the colour conversion will not be correct for HD.
5. GreenAntz will work with any valid sync input combination, including all possible combinations of sync polarity, composite sync, and even composite sync with dirty vertical sync (CRT_Emulator). No other transcoder anywhere provides this "complete" level of flexibility. This makes it much easier to use for different setups like Nvidia cards, Batocera or Groovyarcade, CRU etc.
6. Sync signal is injected into Y (luma, green) at the right place, at the right levels. Many other transcoders just jam it in with no consideration to levels or where it sits in the signal, making it more difficult for your TV to interpret properly.
7. GreenAntz colours are brighter, fully saturated and more "consistent" than most transcoders. No more "filckery", "patchy" or "thin" colours. This is due to multiple iterative and converging quality improvement factors, including superior voltage regulation, efficient design, smarter video signal filtering and amplification.
8. GreenAntz comes pre-optimised, but includes three pots (Y, Pb, Pr) that allow you to tweak the video signal mix to your own complete satisfaction.
9. Just plug GreenAntz in and it works. No software setup or configuration needed.
10. GreenAntz is 100% analog and adds zero lag.
11. GreenAntz includes a 9.5mhz Butterworth low-pass filter (6th order, optional) to further clean up the video signal.
12. GreenAntz is designed to work with arcade cabs and original arcade game PCBs. The board comes with mounting points for PCB offset legs, making it easy to screw into your cab.
13. GreenAntz  includes 5v and GND landing points for alternate power inputs, for example from an arcade DC PSU. You can install screw terminals.
14. GreenAntz includes status LEDs for power (green) and sync validity (blue). The blue LED (and video output) will not come on unless a valid (~15.7khz) signal is received. Very useful for troubleshooting. Filter can be bypassed.
15. GreenAntz' new and stylish enclosure/case includes mounting points and LED windows to see the status LEDS.
16. GreenAntz is new, still being actively developed after six years in response to retrogamer needs, and support is still available by contacting me or through this channel.
That should cover it for now. Just thinking that I should probably put this list at the beginning of the thread :D
kohu
  • Last login:October 12, 2026, 10:08:07 pm
« Reply #193 on: September 30, 2026, 12:07:08 am »
Getting 1 post to send PMs  :laugh:
The 15khz filter is someting I had been wanting for some time now - definately worth the price for my main retrogaming setup. Cheers!
SaltyGamer77
  • Last login:October 02, 2026, 04:32:45 pm
« Reply #194 on: October 01, 2026, 03:47:19 pm »
Posting here for PM! I am excited to potentially be able to use my crt tv for some nice retro gaming with the transcoder!
Zebidee
« Reply #195 on: October 04, 2026, 05:37:40 am »
Now that many of you have your GreenAntz v2.3, I'm sure that some of you have opened them up to have a look.
So I thought I'd explain what the switches and pots are for.
There are three slide switches, which I've circled above:
- Composite sync input/vertical sync blanking switch is circled in YELLOW and near the VGA input. This switch is almost obsolete, but can be useful if the GreenAntz is receiving composite sync input from the video source and, for whatever reason, is unable to ignore vertical sync signals. Note that GreenAntz will try to accommodate this sync mismatch automatically. Often resetting the GreenAntz (re-plugging power) is enough to sort it out, so try that first. As a failsafe, sliding this switch to the CSYNC position will disconnect any vertical sync input and pull the vertical logic input HIGH. Best to leave it in the default HV position.
- Low-Pass filter switch is circled in GREEN and near the green power LED and Pr pot. This is a 9.5Mhz 6th-order Butterworth filter that can help reduce noise on the video signals. It also creates a video delay of approximately 800 nanoseconds. This can be seen as the picture moves slightly to the right as you active the filter. It also seems to blur lines together slightly, similar to a "sharpness" setting on a TV. Some might like, some might not. Default position is OFF.
- 15khz filter switch is circled in BLUE and is near the blue LED. The 15k filter only passes video and sync outputs if correct 15khz sync is received. Default position is ON. If disabled, GreenAntz will attempt to output and process video and sync input regardless. Note that it is possible to pass 480p modes with the filter disabled, and can get you a picture in 480p on a compatible HDTV, though the colour space conversion will be incorrect for HD modes.
FYI No other transcoders offer these features or flexibility.
For the pots, they simply correspond to the Y (green), Pb (blue), and Pr (red) outputs they are near, and I've used coloured dots to represent that above. The pots come pre-calibrated, but you can adjust them to suit your own needs. Every display, GPU, every pair of eyes, is a little different so these pots give the power back to you. Suggest that you mark positions before you adjust. If all else fails, by design the default position is roughly at the centre, ~40-45% or so of travel.
SYNC UPDATE - Mister FPGA
I decided to test GreenAntz v2.3, with it's revamped sync circuit, with my Mister unit. I found it was having trouble syncing reliably, consistently. Sometimes it worked fine for a while, then it lost sync. At first I thought my Mister must be underpowered with it's default 5v 2A power supply. So I upgraded to a 4A PSU and the situation improved, but continued. Now I'd lose sync for about a minute after switching the Mister on, but then it would come good. Perplexing.
Probing with an oscilloscope, I found that was because Mister outputs sync at only 3.3v from the VGA port (on analog IO board). This is much lower than the levels put out by most GPUs (closer to 5v, though sometimes as low as 3.8v or so).
Anyway, I fixed this by tweaking the AC coupling on GreenAntz sync inputs (reduced impedance, resistor on sync inputs) to accommodate Mister's lower sync input thresholds without losing any other capabilities, and have already retrofitted this change into units on hand. Now everything is sweet, GreenAntz and Mister playing well together again:
My phone camera seems completely incapable of correctly capturing the correct colours
For the record, my Bitfunx transcoder completely failed to recognise Mister's lower sync thresholds, as did my older Wakaba units. However, my more recent Wakaba handled the Mister sync OK. None of them have AC coupled their sync inputs.
Yes, I know that technically I can just tweak the Mister .INI file to get YPbPr output, and I even have an adapter (pictured!), but mostly I just run it through the GreenAntz, and should be able to.
EDIT: I just tried Mister's raw YPbPr video output and found the colours quite dull and dirty. Much better with a GreenAntz!
As always, if you ever have issues with using your GreenAntz, just let me know and we'll sort it out if possible.
« Last Edit: October 04, 2026, 11:11:18 am by Zebidee »
tbender
  • Last login:October 14, 2026, 07:59:13 pm
« Reply #196 on: October 04, 2026, 01:56:20 pm »
Replying to send a PM. Happy to try this out it looks very promising at a very generous price.
CRTFTW
  • Last login:October 08, 2026, 06:37:46 pm
« Reply #197 on: October 07, 2026, 07:53:31 pm »
Is that 15.7kHz figure a hard cutoff?
Because on my Emudriver setup I typically go as high as 15.9kHz for Steam games that could use some extra porch padding to reduce overscan. My CRT TV doesn't start to lose sync until you hit 16.0kHz
Zebidee
« Reply #198 on: October 07, 2026, 09:43:41 pm »
The filter is centred on 15.7khz with a pass bandwidth of approximately 2khz, or roughly 14.7khz to 16.7khz.
SephAU
  • Last login:October 12, 2026, 02:36:44 am
« Reply #199 on: October 08, 2026, 01:49:16 am »
I'm super keen to get hold of one of these. I'm in Australia, so assuming you have current stock, I'm guessing I'd likely receive it within about week or so?
« Last Edit: October 08, 2026, 07:12:58 pm by SephAU »
