Author Topic: Control panel tilt angle  (Read 10363 times)
cammada
  • Last login:February 19, 2026, 08:29:29 pm
« on: July 13, 2011, 12:48:26 am »
Does anyone know the health guideline for wrist safety from injury cause from control panel? I mean is does the control panel must have to be level or can it tilt up few degree without making wrist sore after long hours of playing?
regards,
Cammada
LeedsFan
Re: Control panel tilt angle
« Reply #1 on: July 13, 2011, 01:29:34 am »
Health guidelines?!  I think there's no problem whether a panel is flat or has a small tilt (say 1" from back to front depending on the size of the panel).  Purely for aesthetics I think a small tilt looks better and some say it's more comfy. However I find that flat panels are easier to build (because I suck at woodworking basically).  :P
wweumina
  • Last login:August 30, 2022, 04:56:31 am
« Reply #2 on: July 13, 2011, 02:42:12 am »
A slight tilt is generally considered more comfortable. Emphasis is on slight though.
Raitsa
  • Last login:March 29, 2024, 10:45:35 am
« Reply #3 on: July 13, 2011, 04:37:57 am »
A different than usual tilt negative, meaning "the other way around" is very comfortable too, but looks kinda strange.
I had one like that when i used an X-arcade temporararily in my cab.
syph007
« Reply #4 on: July 13, 2011, 10:44:24 am »
Ya if you are tall, a negative tilt is very comfy, but looks weird.  I went with a 5 degree tilt on mine.
Bender
« Reply #5 on: July 13, 2011, 05:35:31 pm »
I find 5-10º is the comfortable range and looks good aesthetically too
cammada
« Reply #6 on: July 13, 2011, 10:50:06 pm »
mmmm, I guess tilt by 5 degree will be enough since when you look down and it look flat to your eyes rather then bending further to see it flat. I see it shouldn't matter about wrist so I will try to make a temporary board and work out which is comfortable for me.
Thanks to all for the reply, it helps.... ;)
Mrephunk
  • Last login:July 17, 2012, 12:56:47 am
« Reply #7 on: July 14, 2011, 04:44:51 am »
I remember reading some where that the forward tilt of a CP was need if the panel was above your elbows, and flat if it was below. I just built mine and gave it a forward tilt as it sits a bit above my elbows and I am 6' 1" so I figured for most people playing it would sit more above their elbows than mine. It feels very comfortable with the tilt
eds1275
  • Last login:April 16, 2026, 11:43:58 am
  • Rock and Roll!
« Reply #8 on: July 14, 2011, 12:21:27 pm »
I went with an inch front to back (!) on the two I've been working on. Looks good and is comfy.
Woodshop Flunky
« Reply #9 on: July 14, 2011, 12:44:47 pm »
I put a 7.5 degree angle on mine.  Seems comfortable, but I mostly did it for aesthetics.
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
« Reply #10 on: July 14, 2011, 05:09:59 pm »
I took a lot of time to get this right. First of all, I have a standard upright, cab but I made it shorter to allow for sitting in a standard folding chair. I then had several Friends sit in the chairs and I measured their elbows and had them hold out their arms like they are playing. Next, I tilted a piece of plywood up and down until I got the right angle.
The top of my control panel is 29" off the ground and tilts 15 degrees up to 31" at the monitor. I works great because you can rest your wrist on the panel and it slopes with your arm. :applaud:
They treated me like an animal and that's what I became.
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« Reply #11 on: July 18, 2011, 01:52:27 pm »
What's comfortable and what will tend to cause repetitive use problems will be different from one person to the next.
Staring for zero, the higher the degree of angle the higher the chance of developing overuse injuries.
That said, I've been making my controls panels to match the 10° slant of the Williams arcade control panels on Joust, StarGate, Robotron, etc.
Darren Harris
Staten Island, New York.
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
nakeworks
  • Last login:October 26, 2020, 09:49:37 pm
« Reply #12 on: July 18, 2011, 07:12:28 pm »
Part of it may depend on how much room is on your CP.  If your buttons are right on the edge and there is no room to rest your wrists/forearms, then having some tilt might be nice.  I already have carpal tunnel syndrome so I left plenty of room on the CP for my wrists and part of the forearms.  I tested several inclines out while watching tv and felt that no incline was preferable.  Any incline gave my fingers the tingles and went numb after a little while.  Sadly I didn't even think to try a decline or negative angle.   :banghead:
Thriller baby
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« Reply #13 on: July 18, 2011, 11:25:29 pm »
Is your control panel Belly button height? I've always found the thumb rule  "only angle it if it is higher than your belly button" to be pretty valuable for me.
