November 21, 2009, 08:57:31 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Whiteside 1/16" Slot Cutter from T-molding.com  (Read 758 times)
Honkyharris
Trade Count: (0)
Full Member
Offline Offline
View Profile
« on: September 28, 2009, 08:16:30 PM »
I purchased this slot cutter from t-molding.com when I purchased my orange t-molding. Overall I was very impressed with the t-molding itself, but not impressed by the slot cutter. I got the cutter lined up properly using scrap pieces of MDF and noticed immediately that it was burning the wood. Even when multiple light passes were used the slot cutter burned every time which leads me to believe it was not made to be used with MDF.
After we had finished the work my garage was almost completely filled with the putrid smelling smoke created by the burning MDF. Here is a picture of the bit after completion :
You may or may not be able to see it, but it actually began to crack! Had we used this much longer it very well may have broke in use which could have ended up very poorly. We went as slow as possible when using the slot cutter to try to avoid the burning, but nothing helped.
In the end the cutter served its purpose although at this point it is scrap and I won't be able to use it on any future projects which is a bit disappointing. I am very happy with the service I have received from t-molding.com and will certainly return there for any future t-molding purchases as it was quick and the molding itself is very good quality. However, I will look elsewhere when purchasing another slot cutter.
Hope this helps,
Honkyharris
P.S. for reference the slot cutter was a Whiteside Slotting Cutter 1/16" Part# 6700A 3 wing w/ a 1-7/8" cutting diameter.
Logged
shponglefan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #1 on: September 28, 2009, 08:55:42 PM »
I have the same problems with this slot cutter.   However, I've found the trick is to go faster not slower.  I do about 3 relatively fast passes and that seems to reduce the burning problem.
But I plan to buy a new slot cutter for my next project.
Logged
severdhed
Trade Count: (0)
Full Member
Offline Offline
I Love Bacon!!!
View Profile WWW
« Reply #2 on: September 28, 2009, 10:05:48 PM »
i bought a freud slot cutter bit from a local cabinet shop and it worked great.
Logged
My first attempt at a cabinet...
http://www.severdhed.com/
syph007
Trade Count: (+2)
Full Member
Offline Offline
View Profile
« Reply #3 on: September 29, 2009, 07:21:43 AM »
I bought the exact same whiteside bit, works awesome.  I did all my routing and it looks like new.   It looks like you put the cutter on backwards, that's why its burning.   The router rotates clockwise (looking down as if you were working with it)  So you were burning your way through the wood with friction, not actually cutting it.
Not my pic, found it on another post on the site.
« Last Edit: September 29, 2009, 07:30:19 AM by syph007 » Logged
saleem
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #4 on: September 29, 2009, 08:29:05 AM »
i am waiting on this set to arrive:
http://www.rutlands.co.uk/power-tools-&-accessories/router-cutters/router-cutter-sets/TR6/7-pc-slot-cutter-tct-set---1_2%22
the 1/16 slot cutter is expensive on its own so i thougt i might as well fork out like double and get 7 blades instead of like £20+ for one.
Smiley
Logged
Honkyharris
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #5 on: September 29, 2009, 10:25:03 AM »
That's a possibility, in which case I'm an idiot. When it first burned my dad and I looked to make sure when had it on properly although I guess we may have not. Good catch.
Logged
NelsonPJ
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #6 on: September 29, 2009, 10:30:49 AM »
I agree with the previous poster - I think you installed the slot cutter bit backwards, and that's why it burned.  You were probably cutting the slots with the "dull" side of the carbide blades, not the "sharp" sides.  At least you got through your job without the bit flying apart and shooting the carbide tips across your workshop/garage!
  I bought the same Whiteside router bit set from Woodcraft and had no issues - although I did apparently install the bearing and washers incorrectly.  Here's a thread from about a year ago about that same bit, along with some pictures of how to install it.
http://forum.arcadecontrols.com/index.php?topic=84588.msg901269#msg901269
Logged
shponglefan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #7 on: September 29, 2009, 10:37:36 AM »
That's okay, I think I did the same thing.  So at least you have company.  Grin
Logged
Benevolance
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #8 on: September 29, 2009, 02:29:21 PM »
I bought that same slotting cutter and have found it works very well. I had trouble deciding which way it should go on, but ran a couple test spins before trying the MDF to make sure that the blade was turning in the proper direction I would be cutting. I had a little burning on the cutter, on a few runs when I guided the slotting cutter too slowly over the wood.
Edit: I bought mine from Holbren and found them most excellent to deal with. In spite of a hurricane, they got my slotting cutter shipped across the continent in very reasonable time, and the shipping was very reasonable.
« Last Edit: September 29, 2009, 02:31:37 PM by Benevolance » Logged
shponglefan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #9 on: September 29, 2009, 03:27:19 PM »
I just flipped mine around and now it cuts like a dream.  Live and learn I guess.
Logged
LeedsFan
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #10 on: October 03, 2009, 12:59:46 PM »
I used the exact same slot cutter on my latest project. I was using plywood and it cut so easily.... I was quite impressed as I thought it might take a bit more "effort" to make the slots. I bought mine from the USA together with the 1/4" shank it attaches to. It came with a little bearing that helps to "roll" the router around the piece you are cutting and to enable you to get a consistent depth of cut. The bearing just sits between the securing nut and the cutter.
Also yeah, you fit it backwards. But then again you probably getting sick of people telling you this now.  Tongue  At least you got the job done.
Logged
Kevin Mullins
Trade Count: (+2)
Full Member
Offline Offline
View Profile WWW
« Reply #11 on: October 14, 2009, 06:25:44 PM »
I personally would not continue to use it though .... pick ya up another one and start fresh.
The heat has changed the temper, hence the cracking, it may still come apart on you at some point.
And yeah, we've all done something like that before.  Cheers!
Logged
CadeFreak
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #12 on: October 14, 2009, 06:50:55 PM »
Putting on the blade in the wrong direstion is a common but seriously dangerous problem! I bought all my t-molding and router bit from them! I know its not on T-molding to instruct us but there should be some small few instructions included with the router bit!
If you have burnt the bit by using it the wrong way its recommended that you throw it away and get a new one as it could come apart during use and seriously hurt you or others! don't forget the gloves and safety glasses!  ???
Logged
D to the mofo M
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.293 seconds with 28 queries.
