Author Topic: Whiteside 1/16" Slot Cutter from T-molding.com  (Read 35005 times)
Honkyharris
  • Last login:September 04, 2010, 11:28:06 am
« on: September 28, 2009, 09:16:30 pm »
I purchased this slot cutter from t-molding.com when I purchased my orange t-molding. Overall I was very impressed with the t-molding itself, but not impressed by the slot cutter. I got the cutter lined up properly using scrap pieces of MDF and noticed immediately that it was burning the wood. Even when multiple light passes were used the slot cutter burned every time which leads me to believe it was not made to be used with MDF.
After we had finished the work my garage was almost completely filled with the putrid smelling smoke created by the burning MDF. Here is a picture of the bit after completion :
You may or may not be able to see it, but it actually began to crack! Had we used this much longer it very well may have broke in use which could have ended up very poorly. We went as slow as possible when using the slot cutter to try to avoid the burning, but nothing helped.
In the end the cutter served its purpose although at this point it is scrap and I won't be able to use it on any future projects which is a bit disappointing. I am very happy with the service I have received from t-molding.com and will certainly return there for any future t-molding purchases as it was quick and the molding itself is very good quality. However, I will look elsewhere when purchasing another slot cutter.
Hope this helps,
Honkyharris
P.S. for reference the slot cutter was a Whiteside Slotting Cutter 1/16" Part# 6700A 3 wing w/ a 1-7/8" cutting diameter.
shponglefan
Re: Whiteside 1/16" Slot Cutter from T-molding.com
« Reply #1 on: September 28, 2009, 09:55:42 pm »
I have the same problems with this slot cutter.   However, I've found the trick is to go faster not slower.  I do about 3 relatively fast passes and that seems to reduce the burning problem.
But I plan to buy a new slot cutter for my next project.
severdhed
  • RIP Dinosaur Hippo
« Reply #2 on: September 28, 2009, 11:05:48 pm »
i bought a freud slot cutter bit from a local cabinet shop and it worked great.
syph007
« Reply #3 on: September 29, 2009, 08:21:43 am »
I bought the exact same whiteside bit, works awesome.  I did all my routing and it looks like new.   It looks like you put the cutter on backwards, that's why its burning.   The router rotates clockwise (looking down as if you were working with it)  So you were burning your way through the wood with friction, not actually cutting it.
Not my pic, found it on another post on the site.
« Last Edit: September 29, 2009, 08:30:19 am by syph007 »
saleem
  • Last login:February 07, 2012, 08:03:39 am
« Reply #4 on: September 29, 2009, 09:29:05 am »
i am waiting on this set to arrive:
http://www.rutlands.co.uk/power-tools-&-accessories/router-cutters/router-cutter-sets/TR6/7-pc-slot-cutter-tct-set---1_2%22
the 1/16 slot cutter is expensive on its own so i thougt i might as well fork out like double and get 7 blades instead of like £20+ for one.
Honkyharris
« Reply #5 on: September 29, 2009, 11:25:03 am »
That's a possibility, in which case I'm an idiot. When it first burned my dad and I looked to make sure when had it on properly although I guess we may have not. Good catch.
NelsonPJ
  • Last login:June 17, 2020, 06:50:27 am
« Reply #6 on: September 29, 2009, 11:30:49 am »
I agree with the previous poster - I think you installed the slot cutter bit backwards, and that's why it burned.  You were probably cutting the slots with the "dull" side of the carbide blades, not the "sharp" sides.  At least you got through your job without the bit flying apart and shooting the carbide tips across your workshop/garage!
  I bought the same Whiteside router bit set from Woodcraft and had no issues - although I did apparently install the bearing and washers incorrectly.  Here's a thread from about a year ago about that same bit, along with some pictures of how to install it.
http://forum.arcadecontrols.com/index.php?topic=84588.msg901269#msg901269
shponglefan
« Reply #7 on: September 29, 2009, 11:37:36 am »
That's okay, I think I did the same thing.  So at least you have company.  ;D
Benevolance
« Reply #8 on: September 29, 2009, 03:29:21 pm »
I bought that same slotting cutter and have found it works very well. I had trouble deciding which way it should go on, but ran a couple test spins before trying the MDF to make sure that the blade was turning in the proper direction I would be cutting. I had a little burning on the cutter, on a few runs when I guided the slotting cutter too slowly over the wood.
Edit: I bought mine from Holbren and found them most excellent to deal with. In spite of a hurricane, they got my slotting cutter shipped across the continent in very reasonable time, and the shipping was very reasonable.
« Last Edit: September 29, 2009, 03:31:37 pm by Benevolance »
shponglefan
« Reply #9 on: September 29, 2009, 04:27:19 pm »
I just flipped mine around and now it cuts like a dream.  Live and learn I guess.
LeedsFan
« Reply #10 on: October 03, 2009, 01:59:46 pm »
I used the exact same slot cutter on my latest project. I was using plywood and it cut so easily.... I was quite impressed as I thought it might take a bit more "effort" to make the slots. I bought mine from the USA together with the 1/4" shank it attaches to. It came with a little bearing that helps to "roll" the router around the piece you are cutting and to enable you to get a consistent depth of cut. The bearing just sits between the securing nut and the cutter.
Also yeah, you fit it backwards. But then again you probably getting sick of people telling you this now.  :P  At least you got the job done.
Kevin Mullins
    • Me on Myspace
« Reply #11 on: October 14, 2009, 07:25:44 pm »
I personally would not continue to use it though .... pick ya up another one and start fresh.
The heat has changed the temper, hence the cracking, it may still come apart on you at some point.
And yeah, we've all done something like that before.  :cheers:
CadeFreak
  • Last login:October 29, 2010, 11:48:44 am
« Reply #12 on: October 14, 2009, 07:50:55 pm »
Putting on the blade in the wrong direstion is a common but seriously dangerous problem! I bought all my t-molding and router bit from them! I know its not on T-molding to instruct us but there should be some small few instructions included with the router bit!
If you have burnt the bit by using it the wrong way its recommended that you throw it away and get a new one as it could come apart during use and seriously hurt you or others! don't forget the gloves and safety glasses!  :dizzy:
D to the mofo M
Michigan Classic Arcade
  • Last login:July 06, 2010, 10:46:58 pm
« Reply #13 on: February 27, 2010, 06:30:16 pm »
I have two slot cutters left in stock over at my website.
www.michiganclassicarcade.com if anyone wants to get one. Comes with Arbor, bearing and 1/4" shank.
Size:
3/32 cutter
for:
3/4" t-molding
Franco B
« Reply #14 on: February 27, 2010, 06:59:00 pm »
Nice random bump   ::)
Why don't you advertise them in the BST threads where all of your other posts are.
Maybe if you see this site as soley a sales revenue then you should pay Saint for an advertising banner. ;)
TBullet
  • Last login:February 11, 2012, 03:18:17 pm
« Reply #15 on: April 02, 2010, 01:46:20 pm »
Can you use this slot cutter on both 1/4" and 1/2" shanks?
Later.
D.E.
Franco B
« Reply #16 on: April 02, 2010, 02:22:54 pm »
I'm not entirly sure what you are asking.
The arbours are availiable in two shank sizes, 1/4" and 1/2".
T-moulding sell the A200B arbour which is for use with a router with a 1/4" collet.
If you want a Whiteside arbour with a 1/2" shank you need the A210B or A220B. The difference between them is the overall length. The A210B is 2 3/8" long whereas the A220B is 4" long. The A210B 2 3/8" version will be more than adequate for everything you want to build cab wise.
The slot cutters have a 5/16" bore so you can use the cutter if you already have a 1/2" arbour with a suitable spigot.
korbitz
  • Last login:June 30, 2017, 01:09:54 pm
« Reply #17 on: April 02, 2010, 02:38:14 pm »
Company?, getting near a crowd, just looked at me slot cutter and yup it was the wrong way round also, luckily it doesn't look damaged, just a bit burnt looking. I always wondered why my smoke alarm kept going of in the house when i cut some wood indoors  :banghead:
Franco B
« Reply #18 on: April 02, 2010, 03:17:19 pm »
Errm, well, cough cough, I have never done that, honest guv  :angel:
(Makes a lovely smell doesn't it  :-[ :laugh:)
korbitz
« Reply #19 on: April 02, 2010, 03:57:54 pm »
Makes an even lovelier smell when you dont wear a facemask and the little burnt bits do wonders for the eyes when you dont wear goggles either  ::)
TBullet
« Reply #20 on: April 03, 2010, 12:05:21 pm »
What I'm asking is: I'll have to rent a router. I don't have one. Depending on what the rented router shank size is, 1/4" or 1/2", I was wondering if the 7/64" slot cutter is universal on both 1/4" or 1/2" shanks.
I'll have to find out what size shank the rented router is and go from there. I just checked and it looks like they have a 1/2" collet on the router.
Thanks.
Later.
D.E.
Franco B
« Reply #21 on: April 03, 2010, 12:20:40 pm »
The 7/64" cutter its self is universal as it will fit on all of whitesides 1/4" and 1/2" arbours.
However, the A200B arbour that t-moulding sell will not fit a 1/2" router as it has a 1/4" shaft.
If you wanted to use a whiteside 7/64" cutter with a 1/2" router that only has a 1/2" collet you would need to buy the whiteside A210B arbour from somewhere else.
Check with the place that you are renting the router from. Most 1/2" routers will come with 1/2" and a 1/4" collet.
TBullet
« Reply #22 on: April 03, 2010, 12:28:55 pm »
Thanks. This will help a lot.
Later.
D.E.
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #23 on: April 04, 2010, 01:28:53 am »
Maybe this thread should be removed or deleted or something since the original poster had a bad experience with the product due only to his own mistake of installing the bit backwards...
SammyWI
« Reply #24 on: April 04, 2010, 09:29:00 am »
Actually, I think this thread can help others who may run into the same issue.  It's pretty easy to install the cutter backwards, especially for folks that don't have a lot of experience in woodworking.
An update to the OP and title would be helpful, though.  Right now the fix is somewhat buried in the thread.
Edit: spelin.
« Last Edit: April 04, 2010, 09:38:56 am by SammyWI »
  • Last login:February 09, 2026, 11:56:07 am
« Reply #25 on: December 14, 2010, 12:19:11 am »
Son of a..... this thread just explained why I generated a ton of smoke cutting 5 two-foot slots!  :banghead:
  • Last login:February 09, 2026, 10:26:35 am
« Reply #26 on: December 14, 2010, 09:59:19 am »
Haha!
(I did the same exact thing...    :banghead:)
« Reply #27 on: December 14, 2010, 10:19:13 am »
You should have seen my backyard last night- I was afraid the county cops were going to come get me for violating the 'no-burn' day!  :lol
farow69
  • Last login:January 27, 2011, 09:22:20 pm
« Reply #28 on: January 27, 2011, 09:19:21 pm »
That's okay.Thanks for review.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #29 on: March 17, 2011, 09:36:27 pm »
This should be moved to the woodworking forum and stickied. It could save someone from a serious injury, or at least an expensive mistake.
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
« Reply #30 on: February 29, 2012, 12:22:33 am »
They should really just etch "Upside Down STUPID" on the appropriate side to get the installer's attention, eh?   :laugh2:
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #31 on: March 15, 2012, 07:18:58 am »
At first I was like what in the world, my bit works fantastic and doesn't burn at all and then I saw the original poster put it on wrong and I was like:
johncl
  • Last login:December 31, 2012, 10:08:00 am
« Reply #32 on: September 28, 2012, 07:01:58 am »
A question to you slot-cutting-experts out there. ;)
I have 11mm (0.433071 inches) MDF which I am building my bartop in, is that too thin for 1/16" slots for t-molding to be fit? Just afraid that it might split the MDF or something and wonder if I should just perhaps paint the edges in white glossy paint to make it "look" like t-molding (Nintendo used flat t-molding from what I have learned so I could probably get away without profiling them).
