Author Topic: Refinishing an old cabinet (Paint, adhesive remover, etc.)  (Read 1316 times)
ZippySLC
  • Last login:August 10, 2003, 08:15:00 am
  • Booyah
    • ZippySLC's MAME Cab
« on: July 07, 2003, 11:39:13 am »
As some of you might know, I have an old Dynamo JAMMA cabinet that I am building into a MAME cab. The game that was in there was a crappy boxing game, "Final Blow." I pulled the old side-art off, which left a gummy mess in some areas.
I bought some goof-off, which removed some of the adhesive and some of the paint where I was getting the adhesive off. I'm pretty much thinking that I am going to just repaint the entire cabinet.
My questions are:
1) Anyone use wood putty to fix any imperfections in their cabinets? How does it hold up in MDF?
2) What sort of paint should I use? I will be rolling it on. Should I go for a gloss, semi-gloss, or flat? I'm going to paint it black.
I am getting side art done by Emdkay, so whatever I get will have to allow me to use some spray ahdesive to put the art on.
BobA
  • What Me Worry?
Re:Refinishing an old cabinet (Paint, adhesive remover, etc.)
« Reply #1 on: July 07, 2003, 01:15:12 pm »
Wood putty works well to fix small imperfections.  It sometimes helps to moisten the raw surface where it is being applied.  It can be sanded very easily.
I like semi-gloss latex.   Cleans well and does not show imperfections as much as gloss.
Flat will show every mark and dust particle and is not easy to clean.
BobA
hyiu
    • www
« Reply #2 on: July 07, 2003, 03:00:27 pm »
wood putty is easy to use and is good....
just when you're putting on... try not to put too much...
just flat is good.... or else, you'll have a little lump.. (or bump) or whatever you want to call it... and that will be hard to sand down to flat....
as for paint.... I would see flat black is just cool looking....
(but my experience with paint is limited...) you should do a search... there are quite a few threads in this main forum discussing about paints.... (and their effects) in details....
I remember its been asked before....
