Author Topic: A New Hope... "I knew you could do it!"  (Read 40539 times)
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: A New Hope..."Here's where the fun begins."
« Reply #120 on: May 14, 2009, 12:32:11 pm »
[I'm waiting on 1/4"x1/8" foam tape for that as well as the control panel.  The foam tape is used along the edge of the marquee frame where the glass rests and along the inside edge of the control panel...
Where did you get the foam tape?  My Centipede had that on the back edge of the control panel
Ahh... good question... this stuff was a real pain to locate... I first thought mcmaster... but most of what they had was double sided...
http://www.pplmotorhomes.com
38-8608     $4.69       1     SELF ADHESIVE FOAM TAPE - 1/8 IN. X 1/4 IN. X 17 FT.
I haven't received it yet... should be here today... I'll let you know if its the right stuff.
Happy Gaming!
  • Last login:October 19, 2022, 12:01:54 pm
« Reply #121 on: May 14, 2009, 12:52:00 pm »
I thought that was just standard stuff you can get at any craft store?
RetroACTIVE
  • Gramps
« Reply #122 on: May 14, 2009, 12:54:36 pm »
Certainly could be... and shame on me for not checking... I just do so much on line (with the exception of the hardware store)... I rarely shop.
Happy Gaming!
« Reply #123 on: May 14, 2009, 01:19:35 pm »
At least you didn't order a "specialized part" and pay $50 for it.   ;D
RetroACTIVE
  • Gramps
« Reply #124 on: May 14, 2009, 02:36:41 pm »
... I can say I've not made that mistake yet... I came close a few times early on in the hobby... now I'm  usually more cautious... NOS stuff still usually kills you but most hardware and ancillary stuff is usually no big deal.
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #125 on: May 19, 2009, 06:26:11 pm »
Had chance to do a little work... I replaced the marquee light bulb only to find I needed a starter... of course Home Depot had every friggin' starter but the one I needed (BTW...  I hate Home Depot)... so across the street to Lowes and voila!
Besides that here are some pics of the foam tape... works well.. its a little firm for the marquee though... seems to push on the glass causing a bump in the decal... I'm hoping it will relax as time goes by...
I stripped and painted the marquee bracket:
Application of foam tape... nothing spectacular...
Here is the tape along the perimeter of the control panel...
"You know sometimes I amaze even myself"  (not realy... just like the comment)
Happy Gaming!
RetroACTIVE
  • Gramps
Re: A New Hope..."Almost there..."
« Reply #126 on: May 21, 2009, 03:27:05 pm »
Getting close to wrapping this up!... I need some locks for the coin and vault door and a new set of mathbox proms... all on their way
Here are some final shots...
New marquee... as you can see it worked out fine... there are absolutely no bumps or ridges... so the foam strips are good to go...
Closeup shot of the "cockpit"...
Full shots of front and side...
Innards... not "rusty" ;)
New clean base and PS block..
ARII and board cage..
Clean rebuilt 6100 deflection...
Just about ready to wrap this up...
"I don't think you boys can help"
« Last Edit: June 09, 2009, 12:02:05 pm by RetroACTIVE »
Happy Gaming!
« Reply #127 on: May 21, 2009, 03:32:52 pm »
That's really sweet.  Nice job!   :applaud:
Level42
« Reply #128 on: May 21, 2009, 03:44:57 pm »
Amazing, better than new !
 :notworthy: :notworthy: :notworthy: :notworthy:
 If you're not replacing the fan, it could use some dusting/compressed air though ;) (Amazing how tiny things strike you when all other things look so tight.)
RetroACTIVE
  • Gramps
« Reply #129 on: May 21, 2009, 03:47:41 pm »
Definitely on my list as I've already hit it once... as you can see some of the dust in on the floor... I do intend on cleaning it profusely... I just wanted to get it in and get it fired up to see what was left to do...  It was originally so dirty it looked like it was growing moss ;)
The absolute last thing I will get to... (sure) is to touch up the artwork along the base...
Happy Gaming!
Level42
« Reply #130 on: May 21, 2009, 04:13:45 pm »
It's probably just the flash that makes it show really ;)
I'm now installing the T-molding on my cockpit and it seems that when you replace/improve the worst looking part, another part that didn't catch your eye before takes it's place. I only now notice how (relatively) poor the metal retainers of the canopy and backglass are ;)
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« Reply #131 on: May 21, 2009, 10:26:53 pm »
Question for those of you who have taken apart the yokes to rebuild...
How do you get the roll pins out of the inner handles?  I disassembled both handles, but can't slide off the inner part of the handles because of the damn roll pins.   :banghead:
« Reply #132 on: May 21, 2009, 11:39:33 pm »
You guys are setting the bar really high here.  I'm going to have to go all out on mine when I get to it.   :cheers:
RetroACTIVE
  • Gramps
« Reply #133 on: May 22, 2009, 12:13:25 am »
Actually mine had no roll pins... only set screws.  Must be a different rev.
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #134 on: May 22, 2009, 12:35:59 pm »
Can't wait ... I still owe you some info... its coming soon.  I've got all the blocking done I am still transcribing the panel detail... you probably don't need these...
"Commander tear this ship apart, until you've found those plans! Bring me the passengers!  I want them alive!"
Happy Gaming!
RetroACTIVE
  • Gramps
Re: A New Hope..."He's faulty...malfunctioning!"
« Reply #135 on: June 07, 2009, 07:26:12 pm »
Good old mathbox problems are now a thing of the past!  The board was failing tests 18 and 20D of the matrix processor tests.  Turned out to be a bad LS165 of the 'A' register, IC 7A.  I went and replaced all 4 (6A, 7A, 6B, 7B) of them as they were of the same date code.
Now I'm back on the monitor.  It's too damned bright!  I cannot turn it down enough.  It's leaving green connecting vectors and a decent green dot in the center.  I've read of a couple solutions...anyone had to deal with this?
"No reward is worth this."
Happy Gaming!
RetroACTIVE
  • Gramps
Re: A New Hope... "Yahoo!"
« Reply #136 on: June 07, 2009, 08:50:06 pm »
Ok... You know that little adjustment on the HV unit called "SCREEN"?... that was it... derr.  Maybe it would have been better if it were labeled "TRY THIS YOU F'N IMBECILE!"... nah not today...
I'm now waiting on the HV cage cover to help eliminate some screen "jitters".
I still could tweak the x-y analog board adjustments and I will but for now... I'm calling this done!
"The force will be with you.... always."
Happy Gaming!
Level42
« Reply #137 on: June 08, 2009, 01:13:50 am »
Mine has the roll pins but they sure didn't prevent the covers from coming loose of the handles. You did loosen the screws on the inside of the handles that hold the covers right (since we're talking obvious things here anyway ;) ) ?
Or do you mean these:
Just read about this on the Jamma+ forum. My handles don't have that extra hole !
« Last Edit: June 08, 2009, 01:28:51 am by Level42 »
RetroACTIVE
  • Gramps
« Reply #138 on: June 08, 2009, 07:23:01 am »
My yoke does not have a 3rd hole as shown in Level42's pic.  It only has the two larger ones for the set screws.
The funny thing is the axle does not even have an indent or a hole to receive the pin... and the documentation illustrates at least one set screw and one pin.
« Last Edit: June 08, 2009, 01:53:02 pm by RetroACTIVE »
Happy Gaming!
Ninten-doh
« Reply #139 on: June 08, 2009, 11:59:52 pm »
Yep, those are the ones.  I just bought the tool to punch the pins out, but haven't tried it yet.
Level42
« Reply #140 on: June 09, 2009, 01:44:08 am »
Just to be clear: That's not my handle on that picture. My handles only has the two holes.  Quite incidentally the same question came up on a thread on Jamma+ forum and I stole the picture from there.
http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=14688&PN=1
It also has the answer what is in that third hole:
A slotted spring pin...
RetroACTIVE
  • Gramps
« Reply #141 on: June 09, 2009, 11:14:25 am »
... never thought it was your pic specifically... your pics are far too fancy! ;)
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #142 on: June 11, 2009, 09:57:13 pm »
Ok... I had Rich at TOG print me up the back door sheet... It came from http://vectorlib2.free.fr/BackDoorSheet/ which is not perfect but it printed very well and its on good heavy stock... it looks great!  I did not have one to begin with and as with most of these things they are usually missing or just messed up... so I'll take the defects in the scan just fine ;)
« Last Edit: June 11, 2009, 10:01:44 pm by RetroACTIVE »
Happy Gaming!
JeffC
  • Last login:December 19, 2013, 08:25:55 pm
    • Jeff's 720 Page
« Reply #143 on: June 13, 2009, 05:59:09 am »
Man!!! I just stubled on this thread from your sig at KLOV. What a fantastic resto job and documentation. I read every post and really enjoyed it. I love how it starts off...."I'm taking a minimalist approach to this resto" or something similar.  It seemed an all out resto to me. One thing I was glad to see....and another I'll be awaiting updates on:
The masking up to your art and the painting: I'm currently restoring a Quantum and am doing something similar. The cab had some strange bumpiness along the edges of the sides...almost all the way around. It was like very slight water damage, but all the way around all edges of the particle board. I almost thought it might have been stored somewhere very humid and absorbed moisture. Anyway, it was very slight but bothered me enought that I sanded all of the edges to flatten the bumps. I'm trying to preserve the art of course, and am going to mask around it, and just spray the white. And like you, I did some touch up to my Star Wars side art, but mostly left the small dings. That specific art is one of the most forgiving, as any small ding looks like all of the other stars and dots on the art.
The monitor replacement: I have all of the amp set-up that I need, but my tube has a small burn hole. I've also got one of the extremely well packed amp tubes from Canada. I've read enough about converging to be frightened...so I'll be keeping an eye on your progress before diving in myself.
Anyway, I digressed a bit... I really appreciate this thread. Excellent job on the Star Wars.
Level42
« Reply #144 on: June 14, 2009, 06:26:23 pm »
Please tell me that Rich did a couple of those backdoor sheets.....I need one ! (Are the upright and cockpit the same actually ?)....
JeffC, as long as you follow the steps in the Amplifone manual, you'll be fine with the converging. It's one of those things you can only learn by trying it.
I still intend to make a video how to converge an Amplifone........one day........
RetroACTIVE
  • Gramps
« Reply #145 on: June 15, 2009, 09:09:24 am »
I think they are different... but not entirely sure... as the content would be the same regardless.
... you may want to stay tuned  ;)
Thanks Jeff!
« Last Edit: June 15, 2009, 09:50:26 am by RetroACTIVE »
Happy Gaming!
Ninten-doh
« Reply #146 on: June 26, 2009, 11:31:21 am »
Hey guys,
I'm getting ready to start my own SW restoration over the July 4th weekend, and I have everything prepared -- I think -- except for one piece of the cabinet.  It's the top piece of wood that fits between the marquee and the vented/angled piece on the back.  Any chance I can get some pics and measurements?  Thanks!   :cheers:
RetroACTIVE
  • Gramps
« Reply #147 on: June 26, 2009, 02:15:05 pm »
Hey guys,
I'll see what I can do (if I can drum up some spare moments) ... I'll have to remove the marquee to get those numbers...  :cheers:
Happy Gaming!
Ninten-doh
« Reply #148 on: June 26, 2009, 04:52:35 pm »
Crap.  I was afraid of that.   :(
As you can imagine, I would be REALLY appreciative!   :notworthy:
RetroACTIVE
  • Gramps
« Reply #149 on: June 27, 2009, 08:08:09 pm »
Is this OK?
Happy Gaming!
Ninten-doh
« Reply #150 on: June 27, 2009, 08:14:45 pm »
Perfect!  Thank you so much.   :applaud:
RetroACTIVE
  • Gramps
Re: A New Hope... "When you came in here didn't you have a plan for getting out?"
« Reply #151 on: November 05, 2009, 10:38:06 pm »
I've stared to do the amplifone rebuild ... here is the HV board... Now I'm not going to take credit for the resistor mod... Level42 gave me the idea... so I'm simply riding his coat tails...
These are TO220 power resistors... 30W 50 Ohm.  You can see in the pic how badly burned the board was from the old mod... We'll see how it works...
Here is the solder side ... everything re-flowed...some bad pads had to be dealt with on the regulators.  I also added some heavy guage on the one trace that was pretty much cooked off the board from the old resistor heat!
New flyback... and all cleaned up ready to go...
I"ve the deflection board about finished...
Happy Gaming!
« Reply #152 on: November 06, 2009, 08:59:36 am »
Nice job.  I usually jump those traces with wire rather than risk heating the trace and delaminating it even more.  I seem to see that more on much smaller traces, though.  What you did looks pretty nice!
Level42
« Reply #153 on: November 06, 2009, 06:09:58 pm »
Wish I had seen those TO220 resistors before I did my mod !!!! Looks sweet ! 30W seems an awful lot of power for such a tiny package, I guess it really depends on the used heat-sink what the real wattage is. At least it is well over the 5W that Atari used.
I hope the heat will go into the heat-sink mostly, as the only doubt I have about this set-up is that the TO-220's are pretty close to the caps.....
No other way then to try it I guess :)
m_mcgover
  • Last login:December 13, 2020, 09:19:55 pm
« Reply #154 on: November 06, 2009, 08:19:14 pm »
@Spy - Do you have a link to the TO220 resistors?  Or some extras for sale?  I'd like to pick up 4 for my 2 HV PCBs...
Sinistar, 25" Smash TV, Major Havoc 720, Star Wars cockpit w/ESB kit, Robotron cocktail, Warlords cocktail, Back to the Future pinball
RetroACTIVE
  • Gramps
« Reply #155 on: November 06, 2009, 08:36:01 pm »
Here you go: Mouser #684-MP930-50
« Last Edit: November 06, 2009, 08:39:13 pm by RetroACTIVE »
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #156 on: November 06, 2009, 09:04:37 pm »
The back side of the package is exposed ceramic... and I'm betting on the size of that aluminum heat sink to spread the heat well enough... and the cooling fan of course... but like you said... we'll see ;D
Happy Gaming!
RetroACTIVE
  • Gramps
Re: A New Hope... "Thats impossible, even for a computer!"
« Reply #157 on: November 30, 2009, 10:51:22 am »
Convergence and purity... wow... has this been a real treat!
Actually, convergence... not so bad... purity is a pain (at least for me)!
Couple of things I've learned...
#1  Placement of the convergence magnets... the manual says approximately 2" from the start of the neck glass... for me, I needed to add about another 1/4", further up on the tube neck for the magnets to have the greatest range of adjustment.
#2 Expect to repeat the whole procedure many times... for me it was pass #3.  I'm sure experienced wizards could do it first shot... but there are so so many variables its hard to imagine that it would not take at least 2 passes no matter what.
#3 Adjusting blue and red convergence (magenta cross hatch)... rings would not get it "perfect" across the whole display.  I used the rings to get it close then adjusted the position of the yoke to fix the peripheral convergence... this seemed to work very well.
#4 Color purity was/is still a problem overall.  Moving the yoke forward and backward along the neck affects the purity of the colors... It is set to "optimal" using the green cross hatch pattern... too close to the tube and you end up with red and blue on either sides of the display... too far away the same thing... you are supposed to put the yoke in the middle where green is "pure" across the whole display.
With my setup I can't seem to get purity balance... I always seem to have a little purity problem in the top left and bottom right which are at odds with each other... I move the yoke away from the tube the top left gets better and the bottom right gets worse... towards the tube... vice versa.
And I've managed to stay safe and not get electrocuted... although I've felt a bit of a static charge here and there.
And those TO-220 resistors work fantastic... the HV heat sink is slightly warm to touch (I'm guessing 110-ish deg F)...and the caps are not even remotely affected by the heat... the deflection board is actually much much hotter than the HV board at this point.  I ran this for several hours 4+... aligning and playing the game with several death star explosions and the temp remains fairly constant.  I'm going to scab a thermocouple and hook it up to the fluke to get a real number (out of curiosity)
Not sure how I'm going to get this purity issue resolved... any thoughts?
"Almost there..."
« Last Edit: November 30, 2009, 02:38:25 pm by RetroACTIVE »
Happy Gaming!
RetroACTIVE
  • Gramps
Re: A New Hope... "I knew you could do it!"
« Reply #158 on: January 04, 2010, 11:35:22 am »
I'm done!... I was able to get this thing converged and the purity adjusted as well...  for the most part it is perfect!... I'll post a few pics asap.
After seeing both the WG and Amp... there is a HUGE difference between the two.   Of course game play is no better... but the medium res tube and the speed of the display is very noticeable.  I'd say you'd have to be visually impared to not notice the difference between the two!
Putting together a monitor from scratch is not a whole heck of a lot of fun... It took me many many many many tries.  I'd say I had it adjusted properly several times but purposely did it over again to be sure I was able to get the best possible outcome.  It was a lot of work... I probably would never do this again... but who knows.
Happy Gaming!
Level42
« Reply #159 on: January 04, 2010, 11:47:30 am »
 :applaud: :applaud: :applaud: :applaud: :applaud: :applaud:
