Author Topic: what do you think control panel (New pics added 18/02/09)  (Read 3632 times)
redketchup
  • Last login:September 30, 2021, 09:22:45 pm
« on: February 04, 2009, 08:14:55 pm »
what do you think of this, this my first control panel is there something that i forget
« Last Edit: February 18, 2009, 01:18:52 pm by redketchup »
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: what do you think control panel
« Reply #1 on: February 04, 2009, 08:18:57 pm »
Looks good to me .. but where's the spinner?  ;)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 10:49:03 am
« Reply #2 on: February 04, 2009, 08:22:52 pm »
I think you should move the rt and lt mouse buttons below the TB so they won't interfere when playing 4 way games.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #3 on: February 04, 2009, 08:59:31 pm »
Maybe do away with the two buttons above the trackball as you could just as easy use any of the others. A spinner in the void above player 2's joystick would also be good if you can stretch to it.
Aceldamor
« Reply #4 on: February 05, 2009, 02:46:56 pm »
Overall, it's a nice compact design.
If your not a purist, you can use the TB as a spinner...Thought I agree with the removal of the two buttons that Turnarcades suggested.
Fuzzy Wuzzy was a woman!
Havok
  • Trade Count: (+17)
  • Last login:August 03, 2025, 02:34:22 am
« Reply #5 on: February 06, 2009, 10:15:45 pm »
I would say don't bother with the two mouse buttons - make them player 1 button 1 and button 2, and ditch the 7th player buttons - you really don't need them. I know if you want true neo geo and street fighter type layouts you would want both, but in reality you will probably not end using all seven.
And yes - a spinner in there somewhere!
Turnarcades
    • Turnarcades
« Reply #6 on: February 06, 2009, 10:58:48 pm »
Yeah, particularly the 7-button thing - it's easy to replicate a comfortable 'Neo-Geo curve' using 6 buttons anyway - see some of our projects to see how it looks.
redketchup
« Reply #7 on: February 09, 2009, 08:00:26 am »
thank's for your comment, I will probably go with the spinner but not sure if 1 want to remove the mouse button.
thank's Gino
redketchup
« Reply #8 on: February 13, 2009, 10:56:38 am »
this the CP overlay, not finish yet but you have a good idea.
« Last Edit: February 13, 2009, 10:58:44 am by redketchup »
Re: what do you think control panel (pics added)
« Reply #9 on: February 13, 2009, 11:13:39 am »
Where do you guys get this artwork? Or did you do it yourself?
Very impressive. My CP is plain black laminate (it fits with the theme I'm going after), but that looks very nice!
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #10 on: February 13, 2009, 11:30:09 am »
What joysticks are you using?  Can you get rid of the dedicated 4 way?  I would avoid putting anything above the trackball if you play golden tee, bowling, shuuz, etc.  So be careful where you put your spinner.  I can't count the number of times I have smacked my fingers.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
  • Last login:August 01, 2025, 09:20:08 pm
« Reply #11 on: February 13, 2009, 12:03:14 pm »
I disagree with removing the 7th button, and you cant replicated the neogeo curve with 6 buttons accurately without making the 2 rows retardedly curved. if you play a lot of neogeo keep the 7th button, it also makes a great run button in MK3 and the 7th button and first 2 buttons of the bottom row make a great NBA Jam set up too
Xiaou2
  • Last login:August 01, 2025, 11:49:43 pm
  • NOM NOM NOM
« Reply #12 on: February 13, 2009, 12:26:02 pm »
 If you move your 4way stick above the 8way... about 1.5" to the left of it,
and 1cm to 1" above it... It should be much easier to play with.
 Otherwise, you will have to place you arm on top of the 6 buttons to use
it..  and possibly have you arm running into the 8way stick.
redketchup
« Reply #13 on: February 13, 2009, 12:42:20 pm »
First for the artwork question, a friend of me help me with this stuff, So it's a custom artwork and he work in a vinyl place, so he will make the impression to.
For the 4 way joystick, I'm still not sure if I will keep it or not... and the spinner will go above the player2 joystick.
thanks for the comment, it's still not finish, so good time to make some modification.
redketchup
« Reply #14 on: February 13, 2009, 12:48:42 pm »
Question for the mouse button.
How can I  configure it with the i pac2. Is there a keyboard button equivalent to mouse button.... right know, they are part of my trackball (USB) harness, (IT's a x arcade trackball).
Thank's Gino
daok
  • Last login:July 04, 2009, 09:30:00 pm
« Reply #15 on: February 13, 2009, 01:07:07 pm »
Nice one. I really like it.  :applaud:
Turnarcades
    • Turnarcades
« Reply #16 on: February 13, 2009, 09:07:24 pm »
Thank's Gino
No not really. the mini-pac features two non-programmable inputs labelled 'mouse left' and 'mouse right' but when I asked andy he said they are pre-programmed to a couple of numberpad keys ('5' and '+' I think) which activate those mouse buttons if you turn on mousekeys in Windows. I've never found use for this though as I use the number pad arrows as the mappings for player 2's directions, and you can't have both mousekeys and nnumlock enabled at the same time.
Lecithin
  • Last login:April 04, 2012, 10:15:48 am
« Reply #17 on: February 13, 2009, 11:42:36 pm »
whats the spacing between the buttons? for my custom CP I curved the buttons (7 of them) to my own natural hand at rest. I own a few arcade machines and have played countless more and find that after awhile they mostly feel unnatural and awkward (if you keep your hand hovering over all the buttons).
I do find a lot of games where I don't hover the buttons (double dragon is a cab I own for example) but I find other games where you're using multiple buttons constantly, the spacing can become awkward (if you've ever learned to play guitar its a similar feeling.
Here's a good resource on various layouts for sticks and buttons
http://www.slagcoin.com/joystick/layout.html
redketchup
Re: what do you think control panel (New pics added 18/02/09)
« Reply #18 on: February 18, 2009, 01:21:14 pm »
marquee
Ginsu Victim
  • Last login:June 28, 2025, 10:45:55 pm
  • Comanche, OK -- USA
« Reply #19 on: February 18, 2009, 01:49:28 pm »
I would use a clone brush and remove the WARNING / DANGER from the sides.
thatitalian
  • The Revolution Is Coming...
« Reply #20 on: April 21, 2009, 01:53:35 pm »
Glad to see my CP came in handy! ;D Well done! It looks quite catchy on the Radioactive style design!:applaud:
Have you considered changing the red to a radioactive green?
Nice job on the marquee also!
