Author Topic: How do I connect my brand new "Vision Pro Happ Monitor" to JAMMA *PICS* Updated  (Read 1423 times)
mrclean
    • Guscade
Firstly it's going to be used in a vertical orientation, so just wanted to know which way i should rotate it, and what plugs into what off a brand new JAMMA Harness. Excuse my ignorance as I do have alot of experience with MAME this is my first Dedicated machine which is using JAMMA, and not a computer. I want to know what to pull from the existing cab without pulling anything that i need. This should be somewhat of an easy installation because i'm using basically brand new parts for just about everything
I'm going to post pics of the inside of my taito cabinet to see if you guys can help me identify parts of what's safe to take out so to speak
*In the last picture you can see there is an accessory outlet, i tested this with a lamp, and it works do i plug the monitor in to that outlet? but when i powered down the unit the lamp stayed lit
« Last Edit: September 24, 2008, 12:59:09 am by mrclean »
2,370,650 Gun.Smoke
Thenasty
  • Trade Count: (+17)
  • Last login:February 03, 2026, 08:27:56 pm
when powering down the system, its usually a SIWTCH outside the cab and shuts everything off. Take a look on TOP or Bottom or side or back of the cabinet, there's got to be a switch (toggle switch).
Free VGA Breakout Cable
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
No you don't want to use that outlet. That's a service outlet that's always hot. You have AC coming into your monitor. That's what you want to use.
