Author Topic: Dos in 15KHZ.  (Read 2865 times)
cjjb98d
  • Last login:September 15, 2008, 10:08:28 pm
Dos in 15KHZ.
« on: September 13, 2008, 02:15:36 pm »
Hi everyone.
I've had a jamma cab floating for a few years, decided this summer to convert it to mame. After interfacing to the P.C card everything was running fine until the Flyback started arcing to the chassis.
Supposing I replace the flyback, is there a way to get dos to display in 15KHZ? I am using AdvanceMame. If there isn't I may stick a cheap P.C monitor in but I really want to keep the old 15KHZ due to the authentic crap resolution.
I need to run Dos as the computer I'm running is only 1 GIGHZ & 768MB Ram, so CPU power is at a pinch really.
Im using a Nividia TNT2 32MB graphics card. Everything was running fine until the Flyback went. Could it be over exposure to DOS that caused it to go? I was under the impression DOS ran under 30KHZ. It would display dos, just with no SYNC.
Many thanks.
Thenasty
  • Trade Count: (+17)
  • Last login:November 17, 2025, 12:54:16 am
Re: Dos in 15KHZ.
« Reply #1 on: September 13, 2008, 05:10:23 pm »
If your Video Card is Supported by Advamame, then yes you can run PURE DOS.
Other things you might consider, sound for DOS (make sure you have it) or get a soundcard that have support for DOS. Advmame supports ac97 no need for drivers with those.
Free VGA Breakout Cable
cjjb98d
Re: Dos in 15KHZ.
« Reply #2 on: September 13, 2008, 06:06:04 pm »
Hi mate
Yea im running pure dos already, its just that it wont display on the 15khz monitor, it has no vertical sync and rolls up and down. I have sorted the sound out.
thanks
SirPeale
  • Green Mountain Man
Re: Dos in 15KHZ.
« Reply #3 on: September 13, 2008, 06:41:36 pm »
There's a TSR called ARCMON that will help with that.  It's on my "other" site.
http://www.mameworld.net/pc2jamma/
Under downloads.
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
Re: Dos in 15KHZ.
« Reply #4 on: September 13, 2008, 06:52:31 pm »
I've had no trouble running older versions of mame (.55 and .78 or .79) on similar hardware with both win98 and xp.
Your vid card may work with soft-15khz
There are likely reasons you want/need Advmame and DOS that i'm missing though.
cjjb98d
Re: Dos in 15KHZ.
« Reply #5 on: September 13, 2008, 06:56:17 pm »
thats what I was looking for, very helpful, thank you.
Do you think that booting the P.C and seeing the BIOS startpage (quick ram test etc) could damage the 15KHZ monitor?
Also another problem I was having:
I've placed Advancemenu into the autoexec.bat but it cant recognise the advancemame emulator from start up.
When I run it from the prompt it runs fine i.e
Cd mame
Advmenu
cjjb98d
Re: Dos in 15KHZ.
« Reply #6 on: September 13, 2008, 06:59:21 pm »
I guess stuff running in the background isn't going to do the world of good for such a low end P.C. Some roms it wont run smoothly. Also I think the emulation from Advancemame and the front end Advancemenu is good, im not too botherd I cant get some modern roms to work.
Ummon
  • Trade Count: (+13)
Re: Dos in 15KHZ.
« Reply #7 on: September 15, 2008, 06:41:39 pm »
I was going to say, the bios screens are 31khz progressive, regardless of dos operation, and yes those need to be filtered out or something.
Yo. Chocolate.
Stephen Hawking
cjjb98d
Re: Dos in 15KHZ.
« Reply #8 on: September 15, 2008, 10:09:23 pm »
So your saying basically wait a few seconds before turning my monitor on?
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
Re: Dos in 15KHZ.
« Reply #9 on: September 17, 2008, 05:36:56 pm »
Cd mame
Advmenu
it might be a bit long winded but don't you have to write it out like
Code: [Select]
cd c:\
cd mame
mame.exe
i cannot remember exactly how i did it when i was running it in DOS as i greatly prefer the stripped XP setup but im sure thats how i did it
Ummon
Re: Dos in 15KHZ.
« Reply #10 on: September 17, 2008, 05:59:47 pm »
cj, yes - or try out the 'alternate video adapter' method. It's in the wiki. Also, following on david's comment, make sure you know your command line syntax.
Yo. Chocolate.
Stephen Hawking
