Author Topic: Can someone help me?  (Read 1892 times)
thatitalian
  • The Revolution Is Coming...
« on: April 25, 2008, 07:57:47 am »
Hi,
I was wondering if someone could draw up these plans for me in CAD? I am really bad at using this program and have attempted (horribly I might add).
I would really appreciate any help on this!!!
Thanks.
weisshaupt
  • Last login:April 12, 2024, 05:54:45 pm
    • The Ghost in the Machine Project Thread
Re: Can someone help me?
« Reply #1 on: April 25, 2008, 11:21:45 am »
Have you tried Google's Sketchup?
Its  a free 3D cad program that I found pretty easy to use provided you do the following:
1) Build the Outline of your MDF or Plywood Pieces,
2) Use the Push/Pull tool to make that outline 3-dimensional to 3/4 inch or whatever
3) Select the entire 3 Dimensional object and turn it into a "component"- this will make it so other things you draw can't interact with that "part" (you can doubleclick on a "component" to edit it independantly of the other parts
4) Repeat for each part and then "assemble" them...
Of course, I built my entire cabinet from a "plan" that looks a lot like yours there, so I don't know you NEED a CAD drawing, but I admit it probably would have been helpful to have one ....
“A government ... cannot have the right of altering itself. If it had, it would be arbitrary. It might make itself what it pleased; and wherever such a right is set up, it shews there is no constitution” - Thomas Paine, Rights of Man
thatitalian
« Reply #2 on: April 25, 2008, 12:36:52 pm »
I haven't used Google's Sketchup but will give it a go.
If anyone would still like to help please feel free!!!
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #3 on: April 25, 2008, 02:44:26 pm »
I did mine on graph paper.  Took Lucid's original design and made it bigger.
Stub
  • Last login:July 08, 2024, 10:48:14 am
  • Sensory Overload
« Reply #4 on: April 25, 2008, 03:56:02 pm »
The title should be can someone do it for me. Your not asking for help and instruction.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #5 on: April 25, 2008, 04:31:31 pm »
That was obvious in his post, but once he got some answers, he said he'd try on his own.
Be cool.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: April 25, 2008, 06:38:23 pm »
One of the most frustrating things is, if you're copying an existing cab, don't be surprised if the numbers don't add up.  Look at the numbers, the part under the marque is probably more than the 15mm written on the pdf.  Maybe a bad scan and should read 75mm?
Anyway, the angles I measure with the tools I have are usually in the +/- range of 5 degrees, if good, and +/- or 10 if "close".
Other than that, good luck, and if you need any help with sketchup, we can help.
Robin
Knowledge is Power
thatitalian
« Reply #7 on: April 29, 2008, 01:21:18 pm »
Cheers guys!  :cheers: Am attempting it! If I have any troubles I will get back to you!
