Author Topic: How to use SCART for our hobby  (Read 249924 times)
lettuce
  • Make It So!
Re: How to use SCART for our hobby
« Reply #400 on: April 08, 2012, 07:10:49 am »
@lettuce if you bridge Scart 20 - 16 then you can bypass the 5v power altogether. trouble is, it only works for some tvs. it is quite easy to make this kind of cable so it is worth a try. I have several different types of vga-scart cables on hand to use when testing tvs.
So the attached revision diagram, could work then??
lettuce
  • Make It So!
« Reply #401 on: April 08, 2012, 07:14:19 am »
So would the diagram attached be correct for a ATI card??
If you lead voltage from SCART 20 to SCART 16 (what I would not do), then why giving power from the VGA too?
Also whats the black ?wire that comes from VGA pin 10 and goes to pin 17 and bridges to pin 18 on the scart?
These are GND pins.
I noticed that a cable with the BC548B gives better picture than the one with the twisted sync wires.
Regards,
joecontra
Joe, i contacted you outside this forum before Christmas, and asked you to make me one of these VGA to Scart cables which you kindly did. But have noticed with my PC turned off, put still plugged into the wall socket that if i touch the metal socket part of the scart plug i get an mild electric shock!. Any ideas why this happens even though the PC isnt turned on?
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #402 on: April 08, 2012, 07:14:30 am »
mounting the pcb on a low profile bracket might be difficult , coz of the size of the scart plug. an alternative could be to screw it into a 3,5 or 5,25 front slot . this would make it easy to connect the 5-12 volt molex.
joecontra
  • Last login:June 12, 2013, 07:55:22 am
    • VGA-SCART -- articles by joecontra
« Reply #403 on: April 08, 2012, 07:59:32 am »
lettuce
I looked at your e-mail adress and now I remember you. :)
Even if the PC is turned off, there is some power in the system.
How's the cable working I built for you?
Paradroid
I think it might be time to retire from building VGA to SCART tables
I don't agree.  ;D
An EEPROM chip which provides EDID data and a sync merger XOR gate chip can be placed on a small PCB, and this small PCB can be placed in a nice little box, attached to the cable.
But I have to say, that PCB you linked is a good work, many will find it useful. :)
Regards,
joecontra
« Last Edit: April 08, 2012, 08:01:54 am by joecontra »
my site about VGA-SCART stuff: https://sites.google.com/site/joecontrae/home
Paradroid
  • Last login:May 12, 2024, 07:24:24 pm
    • SCART Hunter
« Reply #404 on: April 08, 2012, 08:46:26 am »
BTW, in my day job I am an economist & policy analyst
Haha! The Canberra connection... ;)
Paradroid
    • SCART Hunter
« Reply #405 on: April 08, 2012, 08:52:52 am »
So what advantages does this device have over say building your own VGA to Scart cable then?
The answer is in your question: the advantage is that you DON'T have to build your own cable. :) If you have more money than time this is the perfect solution. I'm pretty fastidious with my soldering but I'll admit that I could never make something as neat looking as that new gadget. Plus, it looks like this new solution "just works" as opposed to having to nut out schematics and make sure you don't make any mistakes during your cable build.
I reckon it looks really cool! :) Hopefully it'll open up this particular avenue of arcade gaming to people that are put off by the need to solder...
lettuce
  • Make It So!
« Reply #406 on: April 08, 2012, 10:20:41 am »
lettuce
So its getting the power from PIn 9 on the VGA then right? Yeah the system is turned of but still plugged into the wall socket. Yeah i guess theres always certain amount of power always going to the motherboard hence the status lights on the mobo are always on when the PC is powered down. So it is perfectly normal then?, i wanted to make sure it was some sort of short happening somewhere?
Yeah it does its job, or though it does pick up interference if i have the Sky Satalite box on near the cable (maybe its not shielded well enough, and the audio channels must have been soldered on to the scart plug the wrong may round. But i get a picture which is the main thing!
joecontra
« Reply #407 on: April 08, 2012, 10:24:10 am »
lettuce
Yes.
Don't you get sound or what's wrong?
Yeah!  ;D
Regards,
joecontra
« Last Edit: April 08, 2012, 10:26:14 am by joecontra »
lettuce
  • Make It So!
« Reply #408 on: April 08, 2012, 11:57:41 am »
lettuce
Yes.
Yeah!  ;D
Regards,
joecontra
Yeah i get sound, but the channels are flipped, so the right sound comes out of the left speaker, and the left sound out of the right speaker
Zebidee
  • Last login:Today at 01:41:24 am
« Reply #409 on: April 10, 2012, 07:05:07 am »
lettuce
Paradroid
I don't agree.  ;D
Regards,
joecontra
You can fit such a PCB onto a small triangle which will fit inside the Scart housing. I've seen it done before.
Zebidee
« Reply #410 on: April 10, 2012, 07:11:53 am »
Oh, well connected!
joecontra
« Reply #411 on: April 10, 2012, 07:25:59 am »
Zebidee
I also saw that solution. As I remember there was a XOR gate on the PCB, but no EEPROM chip.
The solution I mentioned needs no big place:
XOR and EEPROM
The dimensions of the box are 22×42×48.
This can be made at home, no big deal.
Regards,
joecontra
Zebidee
« Reply #412 on: April 10, 2012, 08:08:17 am »
@joe
That is impressive work.
I reckon there is further scope for miniaturisation.
joecontra
« Reply #413 on: April 10, 2012, 08:26:54 am »
Zebidee
Thanks!  :)
You may be right, but I think there's no need because it fits into the little box and that's important for me.
And attached to the cable it doesn't ruin its look.
In the future maybe I will show a picture of it.
Regards,
joecontra
lettuce
  • Make It So!
« Reply #414 on: April 10, 2012, 01:04:58 pm »
So would either of these methods work?......
joecontra
« Reply #415 on: April 10, 2012, 01:45:48 pm »
lettuce
I recommend the first one.
You told, your cable works fine. Why do you need build a new one?
Regards,
joecontra
lettuce
  • Make It So!
« Reply #416 on: April 10, 2012, 02:22:22 pm »
cos its not shielded correctly, im getting interferance
joecontra
« Reply #417 on: April 10, 2012, 02:30:04 pm »
lettuce
When your new cable is done, then please let me know if the interferances are gone or not.
Regards,
joecontra
lettuce
  • Make It So!
« Reply #418 on: April 10, 2012, 02:33:51 pm »
Ok will do. So either of the methods i posted above would work then?
joecontra
« Reply #419 on: April 10, 2012, 02:35:44 pm »
lettuce
Yes but the first one is better.
Regards,
joecontra
lettuce
  • Make It So!
« Reply #420 on: April 10, 2012, 03:54:52 pm »
lettuce
Regards,
joecontra
Thanks, so its fine to have the 2k resistor on the scart pin rather than have a 1k resistor on each of the sync wires??
joecontra
« Reply #421 on: April 10, 2012, 04:22:07 pm »
lettuce
It would be better 1k resistor in each sync line. I think 2k might be a bit too much.
The best option would be using a BC548B and 2 resistors 3,3K and 68 like this:
But if you can't, the 2x1K solution is also right.
Regards,
joecontra
lettuce
  • Make It So!
« Reply #422 on: April 10, 2012, 08:19:07 pm »
lettuce
Regards,
joecontra
So the BC548B circuit can fit inside the actually scart plug housing if soldered on to vero board?
Paradroid
    • SCART Hunter
« Reply #423 on: April 11, 2012, 12:13:06 am »
For sure! Take a look here. :)
joecontra
« Reply #424 on: April 11, 2012, 06:35:16 am »
lettuce
Yes, it does. I built a lot of cable that way and I can say that this circuit can be nicely placed into the SCART housing.
Paradroid
Thanks, this is a good example.
Regards,
joecontra
lettuce
  • Make It So!
« Reply #425 on: April 11, 2012, 06:42:01 am »
Ah good pics!!
The way im going to do the audio plug is to have it coming from the VGA end rather than the scart end, that way you wouldnt have a audio cable running along the scart cable aswell. So ill leave the pins 6,4 and 2 soldered to the scart lead and then solder the audio wires to the other end of the scart cable which will be inside the VGA house....i think it will make it look alot neater
Paradroid
    • SCART Hunter
« Reply #426 on: April 11, 2012, 06:55:20 am »
Yep. I've made cables that way before. The problem is that it's a lot more work to have to solder the SCART and VGA ends separately. Plus, it's cheaper when you can cut a VGA cable off a disused computer monitor and use that instead of finding or buying a fully loaded SCART cable. Theoretically, the audio will be better shielded with a separate cable.
I do agree that the single cable approach looks neater though. :)
lettuce
  • Make It So!
« Reply #427 on: April 11, 2012, 08:23:34 am »
Yeah i had thought about using a VGA cable to hack rather than a scart cable. But 99.9% of VGA cables are sealed units, how would you tell which wire on the hacked end was connected up to what pin on the VGA plug?
joecontra
« Reply #428 on: April 11, 2012, 08:31:11 am »
lettuce
I built cable even that way. You got to measure which wire belongs to which pin.
It's not that hard.
Regards,
joecontra
Zebidee
« Reply #429 on: April 11, 2012, 08:58:45 am »
You need to use a multimeter on diode setting, which looks something like this:    ->|-
« Last Edit: April 11, 2012, 09:11:36 am by Zebidee »
lettuce
  • Make It So!
« Reply #430 on: April 13, 2012, 09:45:32 am »
Anyone have an info on the, hantarex CT EQ/3 28" monitor, have the oppotunity to grab a hardly used one. Just wanted to know what refresh rates, resolution these support. Plus if the image can be altered via pots at all?
Paradroid
    • SCART Hunter
« Reply #431 on: April 13, 2012, 10:04:53 pm »
@lettuce: Post your question in the main monitor forum. More eyes will see it there. I'm sure the image can be altered by pots. Most arcade chassis have these as opposed to a menu system navigated using an OSD.
lettuce
  • Make It So!
« Reply #432 on: April 17, 2012, 04:40:50 pm »
good idea
Lewer
  • Newbie
  • Last login:September 07, 2012, 08:05:09 am
« Reply #433 on: September 07, 2012, 07:56:26 am »
Hello all, First time posting, long time lurking!
This thread has some really great Info, Ive learned a great deal. Thanks!
Im getting the bits together to make a vga/scart following the schematic attached.
Could anyone tell me the 'values' of the resistors used?
I get that 2 x 1k = 2 x 1000 ohm, and the 100 - is a 1 x 100 ohm but what are their wattages?
Would 0.6 Watt resistors be suitable?
Also, just to clarify, VGA pins 5 & 10 are unused so are grounded at SCART pins 17 & 18.
So,
     VGA                  SCART
       5       <---->       18
      10      <---->       17
and then bridge SCART pins 17 & 18?
Thanks,
Lewer.
joecontra
« Reply #434 on: September 17, 2012, 04:06:38 am »
Yes, they're fine. I use'em too.
VGA pins 5 & 10 are unused so are grounded at SCART pins 17 & 18[...]and then bridge SCART pins 17 & 18?
VGA pin 5 doesn't need to be connected at all. SCART pin 17 can be left also unconnected. You just connect VGA10 and SCART18 together and that's it.
Sorry for late reply I didn't get any email notifications about new messages.
I recommend you my site where you can read useful articles about this stuff:
If someone needs a VGA to SCART lead or has problems with the graphics cards settings just write me a personal message or connect me through my site.
Regards,
joecontra
adder
« Reply #435 on: September 17, 2012, 10:12:16 am »
Quote from: joecontra
I recommend you my site where you can read useful articles about this stuff...
i just checked out your site and the information looks superb, thanks for that
joecontra
« Reply #436 on: September 19, 2012, 12:33:52 pm »
I'm glad that you found it useful.  :)
Feel free to share the URL.  ;D
Regards,
joecontra
joecontra
« Reply #437 on: October 06, 2012, 04:53:05 am »
I've got a VGA to SCART lead 3 m with audio for sale.
If someone needs it, contact me.
Sold already.
Regards,
joecontra
« Last Edit: October 24, 2012, 12:28:57 pm by joecontra »
joecontra
« Reply #438 on: May 27, 2013, 07:28:00 am »
Hi!
Recently I've got some free time, so I could build some VGA to SCART leads if requested.
If someone needs my work just feel free to let me know.  :)
Regards,
joecontra
arcadeswede
  • Last login:February 28, 2022, 11:43:56 am
    • Revansch!
« Reply #439 on: June 12, 2013, 06:35:55 am »
Hi everyone! Got a little color problem!
I followed the instructions in this thread and managed to make a vga to SCART-cable. However, the colors on my CRT seems washed out. The blue color isn't very blue it's more greyish and the red is also kinda faded.
Here's the pic:
Do I need some kind of resistors on the RGB pins? I don't know anything about these things, I'm just guessing.
