Author Topic: Now Ready! - "TT2 Designer Series" Knobs - GroovyGameGear  (Read 7365 times)
RandyT
    • GroovyGameGear.com
« on: February 21, 2008, 03:24:39 pm »
This idea has been kicking around awhile, and we just got the equipment and materials in to do it properly.  I'm pleased with the result, so I had to show it off  :)
This is a variation of the TokenTop knob designed for the TurboTwist2 Spinner.  It has all the same features (Accu-Twist, solid stainless construction, etc.) but instead of the inlaid token, it features a translucent graphic which captures the light reflected from the underlying spun metallic surface of the knob.  The image is heat and pressure bonded into the surface of the outdoor grade vinyl substrate, and is therefore very durable and scratch / moisture / UV resistant.
The "Web Beast" design was sent to me quite some while ago by PoDunkMoFo and is just one of several designs that are planned.  I'd like to offer a good selection of designs, so I'm looking for suggestions on what type of artwork you would like to see on a spinner knob.
I'd also like to mention to any control panel manufacturers out there that we'd be happy to provide a custom version (company logos, etc) for small quantities of these at no extra charge.
Thanks for taking the time to check it out and I look forward to hearing any comments.
RandyT
« Last Edit: April 24, 2008, 01:38:55 am by RandyT »
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
Re: Upcoming Product Variation: "TT2 Designer Series" Knobs - GroovyGameGear
« Reply #1 on: February 21, 2008, 03:36:26 pm »
Will these be the same price as the TokenTop?  I know, kinda jumping the gun...
I am looking for something more....... I guess universal is a good term.  Something nearly exactly like this but without the beast face, in other words, just the blue grid.  Stuff like that.
Looking good though.... I am sure the Artwork guys could get you about 1000 ideas!
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
Daniel B.
  • Last login:May 10, 2024, 05:08:12 pm
  • Lightgun and Point Blank enthusiast
« Reply #2 on: February 21, 2008, 03:55:32 pm »
Randy,
Is there any plans for "one offs" to be run? Obviously you would need to print many to fill the space on the stock, but say you have 20 guys all want one custom one.....
Just throwing it out there
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
RandyT
« Reply #3 on: February 21, 2008, 04:03:56 pm »
Yes, same price.
Noted.  Certainly that approach will lend itself to many designs, so it's a good direction to start in.  Thanks.
That would be the limiter.  I'd need to run "one-offs" in groups or while running other stock images.  Because of the extra time involved in doing them (File transfers, artwork adjustments, etc) , I'd be happier doing them if it was original art and the person gave permission to have it included in the stock offerings for the rest of the community to use as well, but I'll try to accommodate regardless.
RandyT
Daniel B.
« Reply #4 on: February 21, 2008, 04:16:11 pm »
Is there any design specifications that must be met? What type of file are you needing/resolution etc?
ahofle
    • Arcade Ambience Project
« Reply #5 on: February 21, 2008, 04:29:12 pm »
Ginsu Victim
  • Comanche, OK -- USA
« Reply #6 on: February 21, 2008, 04:33:02 pm »
^What I was thinking, but wanted to see who would say it first.
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
« Reply #7 on: February 21, 2008, 04:42:23 pm »
What size/colour/complexity requirements are  you looking for?
When pixelated clipart just wont do, just call for Betty
RandyT
« Reply #8 on: February 21, 2008, 04:49:16 pm »
As long as the white was to be shiny-metal and you are happy with something similar, it's a possibility.
For this model, the images can be the size of a token (.984") and the resolution should be at 1200 dpi minimum.  More is fine (even preferable), as I can always scale it down to fit.  Scaling up is not so good.
RandyT
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #9 on: February 21, 2008, 05:37:18 pm »
I know I'm going to say "duh" once someone gives an answer, but I can't think of what this is from (looks very familiar though)?
RandyT
« Reply #10 on: February 21, 2008, 06:15:08 pm »
Right click, properties  ;D
iano
  • Last login:June 15, 2011, 03:39:11 pm
« Reply #11 on: February 21, 2008, 06:32:04 pm »
Yes, i'd definitely be interested in buying a Tron one.
TheShanMan
« Reply #12 on: February 21, 2008, 06:34:28 pm »
Thx. If I had to venture a guess it would have been tron, but since I haven't yet built a swappable panel for playing tron I didn't recognize it. I might just be all over that one if it looks good in final form! I'm hoping to find an original tron stick and I was considering a token top knob for my tempest spinner, so that certainly would be very fitting for that panel!
RandyT
« Reply #13 on: February 22, 2008, 09:31:46 pm »
Ok, two more to check out.  The one on the left is obviously the MAME™ design.  The one on  the right is the "Electron" design.  This one was drawn from scratch, using the graphic shown earlier as inspiration.  It's not a copy, so if you want exactitude, look elsewhere.  But I think it conveys the essence nicely.
Any other ideas / comments?
RandyT
*MAME™ is a registered trademark of Nicola Salmoria.  This product is not endorsed by, nor affiliated with, the MAME Development Team.  Used with Permission.
« Last Edit: February 22, 2008, 09:52:47 pm by RandyT »
ahofle
« Reply #14 on: February 22, 2008, 10:25:53 pm »
OMG, how'd you do that so fast?!?!
 :notworthy:
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #15 on: February 22, 2008, 11:13:24 pm »
I would be very interested in two "one offs" that are identical for my machine.  Please let us know if that becomes a viable possibility. :applaud:
The 80s Man
  • Last login:March 21, 2019, 03:20:56 pm
  • I'm working on a Crystal Castles MAME Cab
« Reply #16 on: February 23, 2008, 12:33:35 am »
How about this one.
RandyT, if you like it you can have it.
« Last Edit: February 23, 2008, 01:53:01 am by The 80s Man »
Over Four Years and I'm still under 150 Posts (Date Registered:  January 27, 2005, 10:17:25 PM )
TheShanMan
« Reply #17 on: February 23, 2008, 02:40:41 am »
Randy, how durable is the graphic? Will the graphic wear off over time? Can it chip off? And if I got one of these and at a later time wanted to convert it to a token top, would gluing a token over it be just like a standard token top knob? In other words, is this the exact same as a token top minus the token and plus the graphic?
fjl
  • Pixels Rule!
« Reply #18 on: February 23, 2008, 02:45:13 am »
How about a knob with LED lighting so it can be used with the LEDwiz?
RandyT
« Reply #19 on: February 23, 2008, 02:24:46 pm »
Good hardware and ignoring of other projects :)
Send me an email showing what you want.
How about this one.  RandyT, if you like it you can have it.
Looks very nice.  It may be a little too subtle for the process and the size, but I'll run a couple off and see what happens.  Thanks!
Durability is tough to quantify.  Anything short of directly etching into metal will "wear off over time",  but these are very resilient.  I used a finger nail to rub about 20 times on the face of the graphic with moderate pressure and it didn't do a thing to it.  Force sufficient enough to bite into the underlying PVC substrate, will of course damage it and the image.  However, this would take an intentional act designed to destroy, and it would not be "incidental" in nature.  As further protection from incidental damage, the image is inset a little over 1/16", so you would really never come into contact with it during normal use.
I know how to do this, but it's going to take some specialized parts and materials.  I think it's eventually going to happen, just not any time soon.
RandyT
Ummon
  • Trade Count: (+13)
« Reply #20 on: February 23, 2008, 02:30:21 pm »
How about this one.
That kind of graphic I really like.
Yo. Chocolate.
Stephen Hawking
TheShanMan
« Reply #21 on: February 23, 2008, 02:34:24 pm »
If I got one of these and at a later time wanted to convert it to a token top, would gluing a token over it be just like a standard token top knob? In other words, is this the exact same as a token top minus the token and plus the graphic?
Still would like to know about this. I think based on the picture that this must be true, but would like some confirmation.
RandyT
« Reply #22 on: February 23, 2008, 05:00:33 pm »
Sorry, missed this one.  Yes, exactly the same.  But I would peel the graphic out before gluing down a token to make sure it bonds properly.
RandyT
fjl
  • Pixels Rule!
« Reply #23 on: February 24, 2008, 06:31:48 am »
RandyT
Make it so. I just hope it doesn't mean having to buy a whole new spinner. It'd be nice if I could simply by the parts that will allow me to upgrade my current TT2 to have a lighted knob.
RandyT
« Reply #24 on: February 24, 2008, 12:30:02 pm »
When I get around to doing this, the "upgrade" approach is the one I will take.
RandyT
Grasshopper
« Reply #25 on: February 24, 2008, 12:45:09 pm »
Why not design a knob that has a removable round piece of plexiglass inlaid on the top? Customers could then print out any design they wanted on a standard inkjet printer and place it under the plexiglass.
RandyT
« Reply #26 on: February 24, 2008, 02:47:41 pm »
This is something I have considered, but the challenge is the method in which the plexi "locks" into the top and is removed.  If by friction, then it would be very difficult to remove once installed.  Too loose and it could fly out when spun fast.
I'll continue to look at it as an optional configuration.  The nice thing about these graphics is that they are somewhat translucent and take on a "metallic" appearance once applied.  Something that is not as simple to achieve on an inkjet.
RandyT
Ummon
« Reply #27 on: February 25, 2008, 09:17:38 pm »
RandyT
I like the translucent idea. But changeable graphics could be cool, too. The cover disc could fit tightly, and have a very small notch or hole at the periphery that could be picked at with an awl, small screwdriver, etc.
Yo. Chocolate.
Stephen Hawking
SodaPopinksi
  • Last login:November 09, 2011, 03:38:29 pm
  • Cold, Smokey, Rich Diet Caffeine Free Coke
    • John Keeler
« Reply #28 on: February 26, 2008, 01:26:13 am »
Those look SO nice!  :cheers:
"Seimitsu LB-39's make me thirsty"- SodaPopinski
« Reply #29 on: February 26, 2008, 05:51:17 am »
How about this?:
http://www.localarcade.com/arcade_art/r-arcade-1-control-panel-overlays-6-atari-pole-position-steering-wheel-centre-badge-566.htm
It's a steering wheel badge but it could be made smaller, and the 'real' version uses silver (foil) instead of the white I used, which would look great using the metal as the silver logo.
TPB
  • Last login:March 01, 2021, 09:12:52 pm
Randy,
It's been almost 2 months since this announcement.
Yet nothing is mentioned on the TokenTop page on the GGG website :
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=86&products_id=280
Has this new product innovation been scrapped ?
Hopefully not.    :(
« Last Edit: April 18, 2008, 05:09:43 am by TPB »
RandyT
Man, time flies....apologies for the delay.
No, these are indeed going to be available very soon.  In all honesty, the web site part is the biggest hold-up on this one, as I could provide any of the designs I have shown here at any time.  But I will definitely try to have them up before the end of the weekend.
RandyT
RandyT
Sorry this took so long.  The original three designs have been added to the store.  I'll try to do more as time permits.
RandyT
fjl
  • Pixels Rule!
ahofle
Havok
  • Trade Count: (+17)
Re: Now Ready! - "TT2 Designer Series" Knobs - GroovyGameGear
« Reply #35 on: April 24, 2008, 10:23:17 pm »
Nice! I'm definitely going to pick up one of the Electron knobs!
thatitalian
  • The Revolution Is Coming...
How about this?:
I like this Atari design! Would be nice the have this in different colours (maybe red) with a space invader inside. You could even offer the same design in different colours with different arcade icons in the centre, like pacman, mame logo, etc...
