Author Topic: u360s not working in mala/mame...  (Read 1477 times)
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« on: February 13, 2008, 03:34:25 pm »
a bit of help needed...
i have two u360 joysticks wired up properly as joystick 1 & 2...ultramap is happy...
i kick up mala and configure mala so that the joystick controller is enabled...i can test out joystick one in the mala config...but i can not use it to scroll through the gamelist or play any games...
i have searched for help regarding this problem but so far none of the threads i have found have helped me out...
i have a magstik plus that works fine as the player one joystick...could this be causing a conflict...?
(edit)mame version 1.02 by the way...
thanks...
« Last Edit: February 13, 2008, 04:13:17 pm by fixedpigs »
fjl
  • Pixels Rule!
Re: u360s not working in mala/mame...
« Reply #1 on: February 13, 2008, 04:08:35 pm »
Maybe it has something to do with this?
fatfingers
  • Got UltraStiks?™
« Reply #2 on: February 13, 2008, 05:28:47 pm »
In the previous screenshot, make sure your joysticks are enabled in the "joystick" tab.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
fixedpigs
« Reply #3 on: February 13, 2008, 05:36:15 pm »
joysticks are enabled in the controller configuration...
i have been able to get them to move up and down in the game list by setting j1up/j1dn/etc on the joystick>basic tab...
but so far that is the only working output i have attained from them...
« Last Edit: February 13, 2008, 05:39:42 pm by fixedpigs »
fatfingers
  • Got UltraStiks?™
« Reply #4 on: February 13, 2008, 08:17:52 pm »
You did enable joysticks in MAME, didn't you?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
fixedpigs
« Reply #5 on: February 14, 2008, 03:35:01 am »
there it is...!
thanks ff... :cheers:
fatfingers
  • Got UltraStiks?™
« Reply #6 on: February 14, 2008, 07:29:41 am »
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
